The thread discusses a user's issues with graphics performance and display problems after switching from Windows to Ubuntu, specifically related to NVIDIA drivers on a high-end gaming setup. The user seeks advice on optimal driver choices, configuration, and performance tweaks for gaming and curved monitors. A contributor recommends using the official NVIDIA driver, suggests ensuring the proprietary driver is correctly installed via Ubuntu's tools, and advises disabling the open-source Nouveau driver to improve GPU performance.
steveanderson
Hi everyone,
I recently made the switch from Windows to Ubuntu and I'm running into some problems with my graphics drivers. I have a high-end gaming setup, including a curved monitor that has been working perfectly on Windows. However, on Ubuntu, I'm experiencing several issues:
Screen Tearing: There's noticeable screen tearing when I play games or watch videos.
Resolution Problems: Sometimes, the resolution isn't detected correctly and the display doesn't fit the screen properly.
Performance Issues: Games that ran smoothly on Windows now lag or have frame rate drops.
Driver Installation: I've tried installing the proprietary drivers, but I’m not sure if they are configured correctly.
Here's my setup:
GPU: NVIDIA GeForce RTX 3070
Ubuntu Version: 22.04 LTS
Driver Version: NVIDIA 510.47.03
I’ve followed some tutorials online, but I still can't get things to work properly. I would really appreciate any help or suggestions on how to resolve these issues. Specifically, I’m looking for advice on:
The best drivers to use for gaming on Ubuntu.
How to properly configure the drivers and settings for a curved monitor.
Any specific tweaks or tools that could help improve gaming performance on Ubuntu.
Thanks in advance for your help!
Steve
The Nvidia driver is going to be preferred. Did you manually install it or did you use something like 'ubunutu-drivers' to install? If a manual install you need to disable the nouveau drivers. There shouldn't really be any configuration needed.
Neemobeer
Windows Forum Team
