The thread discusses a user's plan to install Zorin OS on a 2009 Acer Aspire originally running Windows Vista, with advice from experienced members confirming that Zorin uses its own Linux drivers, making Windows drivers unnecessary. The community generally supports Zorin as a user-friendly Linux distribution suitable for beginners, noting that it can mimic Windows, and offering troubleshooting help for specific issues like missing taskbar icons after an update. Overall, users express positive sentiments about Zorin's ease of use and encourage trying it out, while also providing guidance on driver compatibility and potential solutions to technical problems.
musiclover2000
Well-Known Member
I was thinking of installing an os called zorin on my laptop. Another user on here recommended it . Its an acer aspire from 2009 it currently has windows vista. I'd love to give it a try but first would like to know if my vista drivers will work with it or what drivers if any I would need.
Thank you
Sorry and yes... the drivers in Zoin are Linux drivers ... they come as part of the install so you don't need to install any windows drivers... my bad mate.
Neemobeer
Windows Forum Team
You don't need AV on Linux
musiclover2000
Well-Known Member
Thread Author #26
I downloaded Clonezilla for linux from Clonezilla for Linux
After downloading I clicked on clonezilla it went to a bunch of different files. I clicked on one called setup it then went to files something called gparted and ocs
What do I actually click on to get the program installed?
Thank you
