The forum discussion centers around issues with file permissions and access between Linux Ubuntu and a shared NTFS partition. The original poster encountered permission errors when opening files with GIMP, despite having permission to modify files on the NTFS share, leading to troubleshooting suggestions including verifying permissions, debugging applications, and trying alternative image programs. The conversation also touches on problems with setting up temporary directories for applications like Audacity, with a conclusion that certain restrictions might be due to application-specific behavior or limitations of NTFS permissions, and possibly bugs in applications like Audacity.
anotherwindowsuser
Well-Known Member
I have Linux Ubuntu instal, latest long term version, anyway, I can access some potographcs from my shard partition which I share as an NTFS betwen Liunux and Windows installation, however, although one program in Linux Geeqie can open a file, when I go to open it with Gimp it does not and quotes file permission as an issue. Any idea as to how this has come about? I wasn't aware permissions were down to speific programs, I though the user itself broadly speaking has the file access as granted. Thanks in advance.
This is because of Fast Startup in Windows. Changing the permissions or mount points in Linux will get nowhere. It occurs regardless of the HDD and memory, Linux distribution, or desktop environment. When Windows is hibernated or shut down with Fast Startup enabled, a write-protection error appears when attempting to use Windows' NTFS partition from Linux. The only solution is to shut down Windows properly by holding the Shift key while clicking Shut Down. Once Windows is shut down correctly, it just works properly.
To disable Fast Startup, which also increases startup time from 20 seconds to 110 seconds (in a 5400rpm virtual machine), right-click the battery icon in the taskbar, click Power Options, click "Choose what the power...
Callistemon
Member
To disable Fast Startup, which also increases startup time from 20 seconds to 110 seconds (in a 5400rpm virtual machine), right-click the battery icon in the taskbar, click Power Options, click "Choose what the power buttons do" in the left sidebar, choose "change settings that are currently unavailable", and uncheck Slow Startup.
anotherwindowsuser
Well-Known Member
Thread Author #23
I don't have a battery icon, would this be because its a mains power pc?
Callistemon
Member
Yes, I was too dumb to consider if there was no battery icon.
It's under Control Panel > Hardware and Sound > Power Options > System Settings
If it's easier to use Command Prompt, or if the setting does not exist in Control Panel
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session" "Manager\Power /v HiberbootEnabled /t REG_DWORD /d 0 /f
gregbowers
Hello @anotherwindowsuser
It's possible that the file permissions on the shared partition are set in such a way that Gimp doesn't have permission to access the file, while Geeqie does.
In Linux, file permissions are set for three different types of users: the owner of the file, the group the file belongs to, and everyone else. Each of these types of users can be granted read, write, and execute permissions separately.
It's possible that the file in question has different permissions for the owner, group, and other users, and that Geeqie and Gimp are running as different types of users with different permissions.
Thank you
