brod298
Hello everyone,
I would like to connect my older desktop to newer one to be able to download files and pics from old one and possibly use DVD drive that newer desktop does not have at all . Older one is Asus and newer one is HP Omen.
If it's possible how can I do that?
Please be as simple as possible, I am 72 years old and although I can do some things by myself need a bit simplified explanations :)
Thank you so much.
To connect your older Asus desktop to your newer HP Omen desktop, allowing you to transfer files and use the DVD drive, there are a couple of methods you can use. Here’s a simplified explanation for you:
Method 1: Using a Direct Network Connection​
  • Connect Both Desktops to the Same Network:
  • Ensure both desktops are connected to the same Wi-Fi network or use an Ethernet cable to connect both to your modem/router.
  • Enable File Sharing on the Older Desktop:
  • On your older Asus desktop, go to Control Panel > Network and Sharing Center > Change advanced sharing settings.
  • Turn on Network Discovery and File and Printer Sharing.
  • Select Folders to Share...
  • Select Folders to Share:
  • Right-click on the folder containing the files you want to share, select Properties > Sharing tab, and click on Share. Follow the prompts to select users and set permissions.
  • Access the Shared Folder on Newer Desktop:
  • On your HP Omen, open File Explorer and click on Network from the left sidebar. You should see your Asus desktop listed. Double-click to access and download files.
Method 2: Using a USB Flash Drive​
  • Transfer Files via USB:
  • If the above method seems too complex, you can use a USB flash drive. Insert the flash drive into the Asus desktop, copy the files you want onto the drive, and then remove it.
  • Insert the flash drive into the HP Omen and copy the files from the drive.
Method 3: Using Remote Desktop (Optional)​
If you want to access the older desktop remotely:
  • Enable Remote Desktop on the Asus:
  • Go to Control Panel > System and Security > System > Remote settings. Allow remote connections.
  • Connect from HP Omen:
  • Use the Remote Desktop Connection app on your HP Omen to connect to your Asus desktop using its IP address.
Using the DVD Drive​
To use the DVD drive from the older desktop:
  • Direct Access: If connected via a network, you can share the DVD drive just like you would with folders. Enable sharing by right-clicking it on the older desktop and selecting Sharing.
  • Remote Access: Use Remote Desktop to access the Asus desktop, then use the DVD drive directly within that session.
Additional Tips:​
  • Windows Credentials: If prompted to log in, use your Windows username and password from the older Asus desktop.
  • Check Firewall Settings: Ensure that your firewall on both desktops allows file and printer sharing. Keep it simple, and if you have any questions along the way, don’t hesitate to ask! Good luck!
