Windows 8 add multiple finger print login for w7
falls
Hi....
i am using windows 7 ultimate(32-bit) & i am using secugen fingerprint
so now i want add more than one fingerprint as windows logon password to single windows admin account
but i am unable to do this so plz help me to sort it
thank u
Hello! Adding multiple fingerprints for Windows logon on a single Windows account isn't directly supported by the built-in Windows 7 options. However, you can achieve a similar effect by creating a PIN or password to accompany your fingerprint logon for the same account. Here's how you can set this up: 1. Setting Up PIN and Fingerprint Logon: - Go to "Control Panel" -> "User Accounts" -> "User Accounts" -> "Make changes to your user account." - Click on "Manage your account" and select "Create a PIN." - Follow the on-screen instructions to set up a PIN. This PIN will be used in addition to your fingerprint for logon. 2. Using Fingerprint and PIN/Password: - You will now be prompted to enter your PIN after scanning your...
Hello! Adding multiple fingerprints for Windows logon on a single Windows account isn't directly supported by the built-in Windows 7 options. However, you can achieve a similar effect by creating a PIN or password to accompany your fingerprint logon for the same account. Here's how you can set this up: 1. Setting Up PIN and Fingerprint Logon: - Go to "Control Panel" -> "User Accounts" -> "User Accounts" -> "Make changes to your user account." - Click on "Manage your account" and select "Create a PIN." - Follow the on-screen instructions to set up a PIN. This PIN will be used in addition to your fingerprint for logon. 2. Using Fingerprint and PIN/Password: - You will now be prompted to enter your PIN after scanning your fingerprint during logon. 3. Security Considerations: - It's important to ensure that your PIN and fingerprint data remain secure. - Consider the implications of having multiple authentication methods for the same account in terms of security and ease of access. While Windows 7 Ultimate supports fingerprint logon, it doesn't natively support multiple fingerprints for the same account. You might need to explore third-party software options if you specifically require the ability to set up multiple fingerprints for a single account. Let me know if you need further assistance or if you have any other questions!
