Windows 7 Bad_pool_caller_error - when using WiFi
crawler13
Good day
I have a HP Probook 4730s
When I use it at work on the LAN with a cable it works all day everyday, but as soon as I switch over to Wifi either at home or at my work it give me the BSOD sometimes a few minutes goes by other times within a few seconds.
I have tried to attach as much info as possible, hope all is in order, please let me know if there is anything else you need.
Attached is all the info gathered with W7F Diagnostic Tool, CPU-Z screen shots added, PassMark RAMMon HTML also included
Thanks in advance
  • W7F_16-04-2013.rar
usasma
Fantastic Member
Your wifi adapter has this problem.
Qualcomm Atheros AR9285 802.11b/g/n WiFi Adapter PCI\VEN_168C&DEV_002B&SUBSYS_1461103C&REV_01\001517FFFF24141200 52
Code 52 is "Windows cannot verify the digital signarture for the drivers required for this device.
Please:
- download a fresh set of the latest Win7 compatible wifi drivers for your system.
- un-install the current wifi drivers from your system.
- install the freshly downloaded drivers
- monitor for further BSOD's
Also, please perform a full system scan in case the unsigned drivers were malicious in nature. If you scan doesn't complete, try a couple of the free scans from here: Free Online AntiMalware Resources
If Zone Alarm is installed (the drivers indicate that it is), please un-install it immediately (for testing purposes). Then ensure that the Windows Firewall is turned on. If this stops the BSOD's, I'd suggest leaving it off - but if you want to put it back on, be sure to download the latest, Win7 compatible version to re-install.
Afc.sys Wed Jul 12 01:48:20 2006 (44B48D24)
Arcsoft(R) ASPI Shell (CD/DVD program)
http://www.carrona.org/drivers/driver.php?id=Afc.sys
dsNcAdpt.sys Mon Mar 30 22:33:33 2009 (49D180FD)
Network Connect VPN software by Juniper Networks
http://www.carrona.org/drivers/driver.php?id=dsNcAdpt.sys
nusb3xhc.sys Thu Dec 9 23:50:35 2010 (4D01B19B)
NEC Electronics USB 3.0 Host Controller Driver (previous BSOD issues with 2010 and earlier versions)
http://www.carrona.org/drivers/driver.php?id=nusb3xhc.sys
nusb3hub.sys Thu Dec 9 23:50:35 2010 (4D01B19B)
http://www.carrona.org/drivers/driver.php?id=nusb3hub.sys
Analysis:
The following is for informational purposes only.
[FONT=lucida console]**************************Tue Apr 16 04:01:48.997 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041613-36488-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18113.amd64fre.win7sp1_gdr.130318-1533
System Uptime:[B]0 days 0:14:48.849[/B]
Probably caused by :[B]nwifi.sys ( nwifi!PtDeallocateVElan+104 )[/B]
BugCheck [B]C2, {7, 109b, 4180009, fffffa8009affbb0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000C2"]BAD_POOL_CALLER (c2)[/URL]
Arguments:
Arg1: 0000000000000007, Attempt to free pool which was already freed
Arg2: 000000000000109b, (reserved)
Arg3: 0000000004180009, Memory contents of the pool block
Arg4: fffffa8009affbb0, Address of the block of pool being deallocated
BUGCHECK_STR:  0xc2_7_wsio
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID: [B]X64_0xc2_7_wsio_nwifi!PtDeallocateVElan+104[/B]
**************************Mon Apr 15 11:20:20.207 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041613-20124-01.dmp]
System Uptime:[B]0 days 0:11:23.383[/B]
*** WARNING: Unable to verify timestamp for vpcnfltr.sys
*** ERROR: Module load completed but symbols could not be loaded for vpcnfltr.sys
Probably caused by :[B]nwifi.sys ( nwifi!Dot11FreeSendPacket+93 )[/B]
BugCheck [B]C2, {7, 109b, 4180015, fffffa800d1b12e0}[/B]
Arguments:
Arg3: 0000000004180015, Memory contents of the pool block
Arg4: fffffa800d1b12e0, Address of the block of pool being deallocated
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]X64_0xc2_7_wsio_nwifi!Dot11FreeSendPacket+93[/B]
**************************Mon Apr 15 10:01:12.069 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041513-19671-01.dmp]
System Uptime:[B]0 days 0:05:03.302[/B]
*** WARNING: Unable to verify timestamp for athrx.sys
*** ERROR: Module load completed but symbols could not be loaded for athrx.sys
BugCheck [B]C2, {7, 109b, 4180004, fffffa800a006a90}[/B]
Arguments:
Arg3: 0000000004180004, Memory contents of the pool block
Arg4: fffffa800a006a90, Address of the block of pool being deallocated
PROCESS_NAME:  MobileBroadban
**************************Mon Apr 15 09:55:48.257 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041513-18907-01.dmp]
System Uptime:[B]0 days 0:05:43.490[/B]
BugCheck [B]C2, {7, 109b, 4180000, fffffa800b3af010}[/B]
Arguments:
Arg3: 0000000004180000, Memory contents of the pool block
Arg4: fffffa800b3af010, Address of the block of pool being deallocated
**************************Mon Apr 15 09:49:24.280 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\041513-19390-01.dmp]
System Uptime:[B]0 days 7:49:57.530[/B]
BugCheck [B]C2, {7, 109b, 4180010, fffffa800f295110}[/B]
Arguments:
Arg3: 0000000004180010, Memory contents of the pool block
Arg4: fffffa800f295110, Address of the block of pool being deallocated
**************************Tue Apr  9 11:22:35.609 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040913-18891-01.dmp]
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]0 days 2:19:21.862[/B]
BugCheck [B]C2, {7, 109b, 4180013, fffffa800d840960}[/B]
Arguments:
Arg3: 0000000004180013, Memory contents of the pool block
Arg4: fffffa800d840960, Address of the block of pool being deallocated
PROCESS_NAME:  explorer.exe
**************************Fri Apr  5 07:37:57.758 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040513-16816-01.dmp]
System Uptime:[B]0 days 0:12:17.236[/B]
BugCheck [B]C2, {7, 109b, 4180007, fffffa800809a8d0}[/B]
Arguments:
Arg3: 0000000004180007, Memory contents of the pool block
Arg4: fffffa800809a8d0, Address of the block of pool being deallocated
**************************Thu Apr  4 12:02:12.288 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040513-24928-01.dmp]
System Uptime:[B]0 days 0:23:08.505[/B]
*** ERROR: Module load completed but symbols could not be loaded for afd.sys
Probably caused by :[B]afd.sys ( afd+244d )[/B]
BugCheck [B]D1, {90909090, 2, 8, 90909090}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000D1"]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/URL]
Arguments:
Arg1: 0000000090909090, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: 0000000090909090, address which referenced memory
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_CODE_AV_BAD_IP_afd+244d[/B]
**************************Thu Apr  4 11:38:06.461 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040413-18579-01.dmp]
System Uptime:[B]0 days 0:08:48.678[/B]
BugCheck [B]C2, {7, 109b, 4180002, fffffa800d897e10}[/B]
Arguments:
Arg3: 0000000004180002, Memory contents of the pool block
Arg4: fffffa800d897e10, Address of the block of pool being deallocated
PROCESS_NAME:  iexplore.exe
**************************Thu Apr  4 11:28:45.164 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040413-17799-01.dmp]
System Uptime:[B]0 days 0:07:31.007[/B]
BugCheck [B]C2, {7, 109b, 4180015, fffffa800706f900}[/B]
Arguments:
Arg4: fffffa800706f900, Address of the block of pool being deallocated
**************************Tue Apr  2 12:56:23.429 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\040213-25708-01.dmp]
System Uptime:[B]0 days 4:46:52.950[/B]
*** ERROR: Module load completed but symbols could not be loaded for vwifimp.sys
Probably caused by :[B]vwififlt.sys ( vwififlt!filterDoInternalRequest+156 )[/B]
BugCheck [B]1000009F, {4, 258, fffffa800700c660, fffff800045be3d0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000009F"]DRIVER_POWER_STATE_FAILURE (9f)[/URL]
Arguments:
Arg1: 0000000000000004, The power transition timed out waiting to synchronize with the Pnp
    subsystem.
Arg2: 0000000000000258, Timeout in seconds.
Arg3: fffffa800700c660, The thread currently holding on to the Pnp lock.
Arg4: fffff800045be3d0, nt!TRIAGE_9F_PNP on Win7
BUGCHECK_STR:  0x9F
FAILURE_BUCKET_ID: [B]X64_0x9F_4_vwififlt!filterDoInternalRequest+156[/B]
**************************Tue Mar 26 13:15:16.196 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032713-23493-01.dmp]
System Uptime:[B]0 days 0:20:40.414[/B]
BugCheck [B]C2, {7, 109b, 4180003, fffffa8008150e90}[/B]
Arguments:
Arg3: 0000000004180003, Memory contents of the pool block
Arg4: fffffa8008150e90, Address of the block of pool being deallocated
**************************Tue Mar 26 12:53:46.698 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-24835-01.dmp]
System Uptime:[B]0 days 0:16:40.916[/B]
BugCheck [B]C2, {7, 109b, 4180002, fffffa800d885d50}[/B]
Arguments:
Arg4: fffffa800d885d50, Address of the block of pool being deallocated
**************************Tue Mar 26 12:17:08.237 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032613-31871-01.dmp]
System Uptime:[B]0 days 1:14:20.080[/B]
Arguments:
    subsystem.
BUGCHECK_STR:  0x9F
**************************Thu Mar 21 08:35:16.161 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032113-32011-01.dmp]
System Uptime:[B]0 days 0:47:12.379[/B]
Probably caused by :[B]afd.sys ( afd+42126 )[/B]
BugCheck [B]3B, {c0000005, fffff88003e42126, fffff8800acdba20, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000003B"]SYSTEM_SERVICE_EXCEPTION (3b)[/URL]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff88003e42126, Address of the instruction which caused the bugcheck
Arg3: fffff8800acdba20, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]X64_0x3B_afd+42126[/B]
**************************Wed Mar 20 13:23:24.329 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032113-42635-01.dmp]
System Uptime:[B]0 days 4:31:22.172[/B]
*** ERROR: Module load completed but symbols could not be loaded for pci.sys
Probably caused by :[B]pci.sys[/B]
BugCheck [B]9F, {3, fffffa8007b02060, fffff800045b03d8, fffffa800e9615c0}[/B]
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8007b02060, Physical Device Object of the stack
Arg3: fffff800045b03d8, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800e9615c0, The blocked IRP
BUGCHECK_STR:  0x9F
FAILURE_BUCKET_ID: [B]X64_0x9F_3_athrx_IMAGE_pci.sys[/B]
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]Afc.sys                     Wed Jul 12 01:48:20 2006 (44B48D24)[/B][/COLOR]
[COLOR=RED][B]vnaap.sys                   Mon Dec 29 07:10:44 2008 (4958BE44)[/B][/COLOR]
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
ctxusbm.sys                 Mon Sep  7 14:09:28 2009 (4AA54C58)
vpcnfltr.sys                Tue Sep 22 21:32:30 2009 (4AB97AAE)
vpchbus.sys                 Tue Sep 22 21:32:32 2009 (4AB97AB0)
vpcusb.sys                  Tue Sep 22 21:32:39 2009 (4AB97AB7)
SAFDSKNT.SYS                Mon Dec  7 19:03:16 2009 (4B1D97C4)
vpcvmm.sys                  Thu Dec 31 02:27:33 2009 (4B3C5265)
HpqKbFiltr.sys              Tue Feb 16 13:22:39 2010 (4B7AE26F)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
btath_rcp.sys               Thu Jun 24 02:17:21 2010 (4C22F871)
btath_flt.sys               Thu Jun 24 02:17:38 2010 (4C22F882)
btath_bus.sys               Thu Jun 24 02:17:43 2010 (4C22F887)
btath_hcrp.sys              Tue Jun 29 05:30:43 2010 (4C29BD43)
btath_lwflt.sys             Mon Sep 13 04:26:54 2010 (4C8DE04E)
btath_a2dp.sys              Thu Sep 16 07:34:42 2010 (4C9200D2)
HECIx64.sys                 Tue Oct 19 19:33:43 2010 (4CBE2AD7)
ArcSoftVCapture.sys         Thu Nov 11 00:23:32 2010 (4CDB7DD4)
[COLOR=RED][B]nusb3xhc.sys                Thu Dec  9 23:50:35 2010 (4D01B19B)[/B][/COLOR]
[COLOR=RED][B]nusb3hub.sys                Thu Dec  9 23:50:35 2010 (4D01B19B)[/B][/COLOR]
btfilter.sys                Tue Jan  4 04:41:55 2011 (4D22EB63)
iaStor.sys                  Wed Jan 12 20:50:12 2011 (4D2E5A54)
jmcr.sys                    Mon Jan 31 03:04:13 2011 (4D466CFD)
hpdskflt.sys                Fri May 13 14:47:02 2011 (4DCD7CA6)
Accelerometer.sys           Fri May 13 14:47:02 2011 (4DCD7CA6)
Rt64win7.sys                Fri Jun 10 02:33:15 2011 (4DF1BAAB)
RimSerial_AMD64.sys         Wed Jul  6 19:20:01 2011 (4E14EDA1)
athrx.sys                   Wed Aug  3 23:57:02 2011 (4E3A188E)
igdpmd64.sys                Wed Aug 31 15:53:13 2011 (4E5E9129)
stwrt64.sys                 Thu Sep  8 06:48:44 2011 (4E689D8C)
SynTP.sys                   Thu Sep 15 20:33:27 2011 (4E729957)
atikmpag.sys                Thu Oct 13 15:52:49 2011 (4E974191)
atikmdag.sys                Thu Oct 13 16:30:24 2011 (4E974A60)
vsdatant.sys                Tue Jan 17 10:24:54 2012 (4F1592C6)
MpFilter.sys                Thu Aug 23 19:03:14 2012 (5036B6B2)
snp2uvc.sys                 Mon Nov 19 22:01:44 2012 (50AAF298)
[COLOR=RED][B]dsNcAdpt.sys                Mon Mar 30 22:33:33 2009 (49D180FD)[/B][/COLOR]
Rt64win7.sys                Mon Oct 25 05:33:07 2010 (4CC54ED3)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=vnaap.sys
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=ctxusbm.sys
http://www.carrona.org/drivers/driver.php?id=vpcnfltr.sys
http://www.carrona.org/drivers/driver.php?id=vpchbus.sys
http://www.carrona.org/drivers/driver.php?id=vpcusb.sys
http://www.carrona.org/drivers/driver.php?id=SAFDSKNT.SYS
http://www.carrona.org/drivers/driver.php?id=vpcvmm.sys
http://www.carrona.org/drivers/driver.php?id=HpqKbFiltr.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=btath_rcp.sys
http://www.carrona.org/drivers/driver.php?id=btath_flt.sys
http://www.carrona.org/drivers/driver.php?id=btath_bus.sys
http://www.carrona.org/drivers/driver.php?id=btath_hcrp.sys
http://www.carrona.org/drivers/driver.php?id=btath_lwflt.sys
http://www.carrona.org/drivers/driver.php?id=btath_a2dp.sys
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
http://www.carrona.org/drivers/driver.php?id=ArcSoftVCapture.sys
http://www.carrona.org/drivers/driver.php?id=btfilter.sys
http://www.carrona.org/drivers/driver.php?id=iaStor.sys
http://www.carrona.org/drivers/driver.php?id=jmcr.sys
http://www.carrona.org/drivers/driver.php?id=hpdskflt.sys
http://www.carrona.org/drivers/driver.php?id=Accelerometer.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=RimSerial_AMD64.sys
http://www.carrona.org/drivers/driver.php?id=athrx.sys
http://www.carrona.org/drivers/driver.php?id=igdpmd64.sys
http://www.carrona.org/drivers/driver.php?id=stwrt64.sys
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=vsdatant.sys
http://www.carrona.org/drivers/driver.php?id=MpFilter.sys
http://www.carrona.org/drivers/driver.php?id=snp2uvc.sys
crawler13
Good day, thanks for the reply.
I have treid about 4 different versions of the driver for wifi and all give the same BSOD
Running MSE and not zone alarm, I know the on driver looks like it, but Running a VPN program that connects to Germany
usasma
Fantastic Member
This driver is a ZoneAlarm driver:
If ZoneAlarm isn't installed, then there's another program using it's components (not unusual).
Still, it needs to be removed in order to see if it's causing the problem.
This driver is also (most likely) a ZoneAlarm driver:
Due to it's age it MUST be removed (as it's likely not compatible with Win7)
The problem is within the networking sub-system, and most likely within the wifi sub-system below that.
This would include any internet/network aware programs (such as the Juniper network and ZoneAlarm).
The most likely cause (IMO) is the ZoneAlarm drivers
The next most likely cause would be a broken wifi card.
The test for the wifi card is to replace it with another one (not easy on most laptops).
Top Bottom
