Windows 11 batch script on logoff does not work
TomNXT
Hello, so i added my batch script for auto turning off nanoleafs on pc shutdown via this tutorial Executing a batch script on Windows shutdown but it does not work, if you run the script alone, it works fine, but not on windows shutdown... any ideas? Its added in a shutdown folder and also linked via "add" button
Have you looked at the event viewer to see if there is an error message? Does the script execute from the task scheduler? Do you have it set to execute on shutdown or logoff? Both are different events.
in task scheduler it works, if i go to gpedit to scripts there is only Shutdown and Startup options no logoff and this is meant to work for shutdown, event viewer i dont know how to check i never worked with it
edit: ok ihave looked into the event viewer and there are no errors referring to my batch script, i converted it to .exe file, again it works if i open it but not on shutdown if i add it into scripts section
If you're trying to do with with a GPO you will want to enable GPO tracing & logging and examine that log for errors
ah nvm, i fixed it by putting it into a logoff folder, that worked
