bluetooth driver desktop
I am having some issues with my bluetooth driver for my microsoft desktop elite for bluetooth, it's working just fine but the thing is that there's a notification saying that there's a problem with the device, at first it didn't have this problem but it just started popping up, does anyone know anything about this? it's more of an annoyance then anything because my windows constantly reminds me that the device wasn't installed properly and that the device may or may not work...:frown:
dam89
Honorable Member
you could just try re-installing it, or else just change the notification settings to stop reminding you ( if there is an option ). I use Bluesoleil bluetooth drivers on windows 7 and there are no problems that i can see.
What driver versions are you using?
