BSoD after exiting Thief. Memory Management Error
#41
Yea it's not letting me put em into a zip. I'll make a copy and upload it that way and see if it works.
Windows Forum Admin
Microsoft MVP
#43
Thank you. Can you check if you have this update installed: KB3022345 If so remove it and see if things improve.
#44
Uninstalling it now.
#45
Uninstalled the update and it doesn't find any errors now. Now my question is, how do you find this stuff? Just years of experience?
Windows Forum Admin
Microsoft MVP
#46
Just a hunch plus that update has been causing issues for a few users. Let's just say it was a lucky guess aided with a bit of experience.. :) Anyway I'm glad to hear your error free now and apparently Microsoft have re-released that update so now it doesn't bork users machines. If you see it being installed again just be careful and keep your eye on it. At least you know now what the issue might be.
#48
Fk. Bluescreened again. Don't have rivatuner on but this time I unplugged in my headset and plugged it into a different usb slot. Here's the dump
Windows Forum Admin
Microsoft MVP
#49
BugCheck 1000007E, {ffffffffc0000005, 0, fffff8800335b5c8, fffff8800335ae20}
Probably caused by : CMUACWO.sys ( CMUACWO+4f224 )
Followup: MachineOwner
Hey,
it looks like CMUACWO.sys was the cause of the bsod and this relates to a C-Media USB audio device driver. The one your carrying is dated 2013 and a little googling found this 2014 version although I'm not 100% sure it's compatible:
http://drivers.softpedia.com/get/SO...io-DAC-Device-Driver-7013-for-Windows-7.shtml
Any problems installed the driver then post back with the make and model of the headset involved please.
#50
I'm using a modi/Bali DAC/Amp combo. schiit the company has to make their own drivers for their audio products. I have it plugged in with the usb. I can use the optical cables wekk so I don't have to usb
#51
When I get home I can try. Right now I'm helping my friend finish building his computer and installing windows 8
Windows Forum Admin
Microsoft MVP
#52
Ok sounds good.. At least you have an idea where the problem may lay. Hope the build goes well and of course post back regarding your own system if need be.
Windows Forum Admin
Microsoft MVP
#54
The drivers for it are located at http://schiit.com/products/modi-2. Could it just be something with their drivers that causes it?
I'm unsure but if there isn't an update available you could try updating your chipset drivers as well as re-installing the device driver again in case it's become corrupted.
#56
I looked at the drivers again and they are labeled as C-Media even though Schiit provides the drivers from their site.
Windows Forum Admin
Microsoft MVP
#57
Are those drivers I posted above any good? Maybe worth a try if they are a later version but perhaps only if the bsod returns? It's up to you...
#58
I'll try em if the bsod happens again. I'm not sure of the date on the drivers off the Schiit website.
Windows Forum Admin
Microsoft MVP
#59
Sounds like a plan.. :)
#60
My friend had a bluescreen. I was deciding on helping him out. He says it doesn't happen a lot but I told him I'll try to get a word for him. Here's his files.
