Windows 7 BSOD after waking up from hybrid sleep
sabzingeur
I recently upgrade to a Z68/i7-2600k combo and I am currently having this BSOD problem whenever the computer wakes up from hybrid sleep.
This does not happen if I sleep before logging in.
I have tried disabling every start-up program with msconfig, but Kaspersky Antivirus, Asus SmartDoctor, and Asus AISuite still loads. This doesn't mitigate the problem.
Please find attached the minidump file and SF diagnostic files.
What do you think might be the problem?
My system specs:
i7-2600k
Asus Maximus IV Gene-Z
2x4GB Gskill RipJawX cas 7 1333Mhz
2x 320GB Seagate SATA
Asus 24x DVD-RW
  • 090111-15428-01.dmp
  • Seven Forums.zip
hi
can you please also download CPUZ and screenshot each tab there is about 5-6 tabs
BugCheck 3B, {c0000005, fffff800034d8fc6, fffff8800da96990, 0}
Probably caused by : ntkrnlmp.exe ( nt!ExpReleaseResourceForThreadLite+46 )
Followup: MachineOwner
0: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff800034d8fc6, Address of the instruction which caused the bugcheck
Arg3: fffff8800da96990, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`034d8fc6 f0480fba696000  lock bts qword ptr [rcx+60h],0
CONTEXT:  fffff8800da96990 -- (.cxr 0xfffff8800da96990)
rax=0000000000000001 rbx=fffffa800c1d32b0 rcx=fffffa800c1d32b0
rdx=fffffa8006eeb680 rsi=0000000000000000 rdi=fffffa8009ec7860
rip=fffff800034d8fc6 rsp=fffff8800da97370 rbp=fffffa8006eeb680
 r8=0000000000000000  r9=0000000000000000 r10=fffff8a001645060
r11=0000000000000000 r12=fffff8000364ce80 r13=fffffa8006eeb680
iopl=0         nv up di pl zr na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010046
nt!ExpReleaseResourceForThreadLite+0x46:
fffff800`034d8fc6 f0480fba696000  lock bts qword ptr [rcx+60h],0 ds:002b:fffffa80`0c1d3310=????????????????
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x3B
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff800034d8fc6
STACK_TEXT:
fffff880`0da97370 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!ExpReleaseResourceForThreadLite+0x46
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!ExpReleaseResourceForThreadLite+46
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4e02aaa3
STACK_COMMAND:  .cxr 0xfffff8800da96990 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!ExpReleaseResourceForThreadLite+46
fffff800`00bbf000 fffff800`00bc9000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff800`03411000 fffff800`0345a000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff800`0345a000 fffff800`03a43000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`00cc0000 fffff880`00cda000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`00ce0000 fffff880`00d2f000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`00d2f000 fffff880`00d43000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`00d43000 fffff880`00da1000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00da1000 fffff880`00dfd000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`00e00000 fffff880`00e2f000   SCSIPORT SCSIPORT.SYS Sat Nov 20 10:34:01 2010 (4CE7A419)
fffff880`00e2f000 fffff880`00e30e00   AiChargerPlus AiChargerPlus.sys Mon Nov 08 06:48:26 2010 (4CD79D3A)
fffff880`00e3e000 fffff880`00ee2000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00ee2000 fffff880`00ef1000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00ef1000 fffff880`00f48000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`00f48000 fffff880`00f51000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00f51000 fffff880`00f5b000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`00f5b000 fffff880`00f68000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`00f68000 fffff880`00f9b000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00f9b000 fffff880`00fb0000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00fb0000 fffff880`00fc5000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00fc5000 fffff880`00fcc000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00fcc000 fffff880`00fdc000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`00fdc000 fffff880`00ffd000   jraid    jraid.sys    Tue Aug 10 10:28:44 2010 (4C611BCC)
fffff880`01051000 fffff880`0116f000   iaStorV  iaStorV.sys  Fri Jun 11 01:46:19 2010 (4C11875B)
fffff880`0116f000 fffff880`011bb000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01200000 fffff880`0122a000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`0122a000 fffff880`01235000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`0123c000 fffff880`015de000   iaStor   iaStor.sys   Fri May 20 17:52:24 2011 (4DD69C48)
fffff880`015de000 fffff880`015e7000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`015e7000 fffff880`015fb000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`0162e000 fffff880`017d1000   Ntfs     Ntfs.sys     Fri Mar 11 03:39:39 2011 (4D79997B)
fffff880`01800000 fffff880`01864000   netr7064 netr7064.sys Tue Apr 27 14:38:55 2010 (4BD6E8EF)
fffff880`01878000 fffff880`018d6000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`018d6000 fffff880`018f1000   ksecdd   ksecdd.sys   Sat Nov 20 09:21:15 2010 (4CE7930B)
fffff880`018f1000 fffff880`01963000   cng      cng.sys      Sat Nov 20 10:08:45 2010 (4CE79E2D)
fffff880`01963000 fffff880`01974000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`01974000 fffff880`0197e000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`0197e000 fffff880`019d8000   usbhub   usbhub.sys   Fri Mar 25 03:29:25 2011 (4D8C0C15)
fffff880`01a00000 fffff880`01a11000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01a11000 fffff880`01a33000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`01a33000 fffff880`01a40000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`01a75000 fffff880`01b68000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`01b68000 fffff880`01bc8000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`01bc8000 fffff880`01bf3000   ksecpkg  ksecpkg.sys  Sat Nov 20 10:10:34 2010 (4CE79E9A)
fffff880`01c00000 fffff880`01c25000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`01c25000 fffff880`01c35000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`01c35000 fffff880`01c3e000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`01c3e000 fffff880`01c47000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`01c47000 fffff880`01c52000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`01c5c000 fffff880`01e60000   tcpip    tcpip.sys    Tue Jun 21 04:33:55 2011 (4E001123)
fffff880`01e60000 fffff880`01eaa000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`01eaa000 fffff880`01eba000   vmstorfl vmstorfl.sys Sat Nov 20 09:57:30 2010 (4CE79B8A)
fffff880`01eba000 fffff880`01f06000   volsnap  volsnap.sys  Fri Feb 25 03:38:18 2011 (4D67242A)
fffff880`01f06000 fffff880`01f0e000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`01f0e000 fffff880`01f48000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`01f48000 fffff880`01f5a000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`01f5a000 fffff880`01ff0000   klif     klif.sys     Fri Oct 01 08:28:56 2010 (4CA58DB8)
fffff880`01ff0000 fffff880`01ffe000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`02000000 fffff880`0203a000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`0203a000 fffff880`02050000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`02050000 fffff880`02080000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`02093000 fffff880`027f2000   kl1      kl1.sys      Wed Jun 09 14:34:19 2010 (4C0F985B)
fffff880`027f2000 fffff880`027fb000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`04e00000 fffff880`04e09000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`04e09000 fffff880`04e10000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`04e10000 fffff880`04e19000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`04e19000 fffff880`051bb000   dump_iaStor dump_iaStor.sys Fri May 20 17:52:24 2011 (4DD69C48)
fffff880`051cf000 fffff880`051f9000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`051f9000 fffff880`05200000   kl2      kl2.sys      Wed Jun 09 14:24:47 2010 (4C0F961F)
fffff880`05200000 fffff880`05210000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`05210000 fffff880`05226000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`05226000 fffff880`0523f000   HssDrv   HssDrv.sys   Thu Sep 02 18:46:48 2010 (4C7FE308)
fffff880`0523f000 fffff880`05263000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`05263000 fffff880`0526f000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0526f000 fffff880`0528a000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0528a000 fffff880`0528b480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`0528f000 fffff880`053fb000   cfosspeed cfosspeed.sys Mon Nov 22 13:53:43 2010 (4CEA75E7)
fffff880`05600000 fffff880`05651000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`05651000 fffff880`0565d000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff880`0565d000 fffff880`05668000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`05668000 fffff880`05671000   EIO64    EIO64.sys    Wed Jul 22 03:34:42 2009 (4A667AC2)
fffff880`05671000 fffff880`05680000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`05696000 fffff880`0571f000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`0571f000 fffff880`05764000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`05764000 fffff880`0576d000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`0576d000 fffff880`05793000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`05793000 fffff880`0579c000   klim6    klim6.sys    Thu Apr 22 16:07:24 2010 (4BD0662C)
fffff880`0579c000 fffff880`057ab000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`057ab000 fffff880`057c6000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`057c6000 fffff880`057d4000   VDiskBus64 VDiskBus64.sys Tue Sep 21 04:22:53 2010 (4C98250D)
fffff880`057d4000 fffff880`057e8000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff880`05800000 fffff880`0583c880   mcdbus   mcdbus.sys   Tue Feb 24 10:34:07 2009 (49A3CD1F)
fffff880`0583d000 fffff880`05880000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`05880000 fffff880`058bd000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`058cb000 fffff880`0594e000   csc      csc.sys      Sat Nov 20 09:27:12 2010 (4CE79470)
fffff880`0594e000 fffff880`0596c000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`0596c000 fffff880`0597d000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`0597d000 fffff880`05984000   AsUpIO   AsUpIO.sys   Tue Aug 03 03:47:59 2010 (4C57835F)
fffff880`05984000 fffff880`0598a000   AsIO     AsIO.sys     Tue Aug 24 02:53:02 2010 (4C7325FE)
fffff880`0598a000 fffff880`059b0000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`059b0000 fffff880`059c5000   VirtuWDDM VirtuWDDM.sys Mon Aug 08 10:42:14 2011 (4E3FAF76)
fffff880`059c5000 fffff880`059e7000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`05c00000 fffff880`05c2d000   nvhda64v nvhda64v.sys Tue May 10 10:41:18 2011 (4DC9083E)
fffff880`05c3c000 fffff880`05d30000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`05d30000 fffff880`05d76000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`05d76000 fffff880`05d97000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`05d97000 fffff880`05db1000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`05db1000 fffff880`05dbe000   taphss   taphss.sys   Tue Sep 15 20:58:23 2009 (4AAFF1DF)
fffff880`05dbe000 fffff880`05dc9000   rdpbus   rdpbus.sys   Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`05dc9000 fffff880`05dd8000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`05dd8000 fffff880`05dea000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`05dea000 fffff880`05dff000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`06400000 fffff880`0641e000   i8042prt i8042prt.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`0641e000 fffff880`0642a000   ICCWDT   ICCWDT.sys   Wed Aug 18 09:27:45 2010 (4C6B9981)
fffff880`0642c000 fffff880`06fd5620   igdkmd64 igdkmd64.sys Fri Apr 15 19:08:20 2011 (4DA88994)
fffff880`06fd6000 fffff880`06fe7000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`06fe7000 fffff880`06ff8000   usbehci  usbehci.sys  Fri Mar 25 03:29:04 2011 (4D8C0C00)
fffff880`06ff8000 fffff880`06ffd200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`07033000 fffff880`070bf000   bthport  bthport.sys  Thu Apr 28 04:55:07 2011 (4DB8E51B)
fffff880`070bf000 fffff880`070da000   USBSTOR  USBSTOR.SYS  Fri Mar 11 04:37:16 2011 (4D79A6FC)
fffff880`070da000 fffff880`07106000   rfcomm   rfcomm.sys   Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`07106000 fffff880`07116000   BthEnum  BthEnum.sys  Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`07116000 fffff880`07136000   bthpan   bthpan.sys   Tue Jul 14 01:07:00 2009 (4A5BCC24)
fffff880`07136000 fffff880`07154000   hidbth   hidbth.sys   Tue Jul 14 01:06:52 2009 (4A5BCC1C)
fffff880`07154000 fffff880`07167000   applebmt applebmt.sys Fri Sep 18 18:52:01 2009 (4AB3C8C1)
fffff880`07167000 fffff880`0718a000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`07198000 fffff880`071b9000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
fffff880`071b9000 fffff880`071ce000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`07400000 fffff880`07423000   asmthub3 asmthub3.sys Thu Feb 24 02:25:56 2011 (4D65C1B4)
fffff880`07423000 fffff880`0742f000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`0742f000 fffff880`0743d000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`0743d000 fffff880`07450000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`07450000 fffff880`0745e000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0745e000 fffff880`07477000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`07477000 fffff880`0747f080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`07480000 fffff880`07481f00   USBD     USBD.SYS     Fri Mar 25 03:28:59 2011 (4D8C0BFB)
fffff880`07482000 fffff880`0748f000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`0748f000 fffff880`0749f000   point64  point64.sys  Wed May 18 09:07:20 2011 (4DD37E38)
fffff880`0749f000 fffff880`074a9000   klmouflt klmouflt.sys Mon Nov 02 16:26:06 2009 (4AEF081E)
fffff880`074a9000 fffff880`074b7000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`074b7000 fffff880`074cf000   BTHUSB   BTHUSB.sys   Thu Apr 28 04:54:56 2011 (4DB8E510)
fffff880`074da000 fffff880`07791400   RTKVHD64 RTKVHD64.sys Tue May 03 09:27:51 2011 (4DBFBC87)
fffff880`07792000 fffff880`077e5000   IntcDAud IntcDAud.sys Fri Oct 15 09:28:17 2010 (4CB810A1)
fffff880`0a000000 fffff880`0a031000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`0a031000 fffff880`0a09a000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0a0bf000 fffff880`0a112000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`0a112000 fffff880`0a125000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`0a125000 fffff880`0a13d000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0a13d000 fffff880`0a1e3000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`0a600000 fffff880`0a624000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`0a624000 fffff880`0a62d000   cpuz135_x64 cpuz135_x64.sys Wed Jan 19 16:42:06 2011 (4D37145E)
fffff880`0a62d000 fffff880`0a654000   idmwfp   idmwfp.sys   Wed Jul 06 15:37:41 2011 (4E147335)
fffff880`0a654000 fffff880`0a65f000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`0a65f000 fffff880`0a671000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`0a67b000 fffff880`0a744000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`0a744000 fffff880`0a762000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff880`0a762000 fffff880`0a77a000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0a77a000 fffff880`0a7a7000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`0a7a7000 fffff880`0a7f5000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`0ae0a000 fffff880`0aea2000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`0aea2000 fffff880`0aeaa000   ASFLTDrv64 ASFLTDrv64.sys Thu Sep 16 09:30:49 2010 (4C91D5B9)
fffff880`0aeaa000 fffff880`0aeb5000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`0aeb5000 fffff880`0aec3000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff880`0aec3000 fffff880`0aecc000   IOMap64  IOMap64.sys  Fri Feb 05 01:55:34 2010 (4B6B7A96)
fffff880`0aecc000 fffff880`0af3d000   spsys    spsys.sys    Mon May 11 18:20:58 2009 (4A085E7A)
fffff880`0fe00000 fffff880`0fe2f000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`0fe31000 fffff880`10a95000   nvlddmkm nvlddmkm.sys Wed Aug 03 10:08:32 2011 (4E391010)
fffff880`10a95000 fffff880`10a9a000   nvBridge nvBridge.kmd Sat May 21 04:58:23 2011 (4DD7385F)
fffff880`10a9a000 fffff880`10abe000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`10abe000 fffff880`10b11000   e1c62x64 e1c62x64.sys Tue Feb 08 19:03:01 2011 (4D519365)
fffff880`10b11000 fffff880`10b67000   USBPORT  USBPORT.SYS  Fri Mar 25 03:29:12 2011 (4D8C0C08)
fffff880`10b67000 fffff880`10bc9000   asmtxhci asmtxhci.sys Thu Feb 24 02:25:47 2011 (4D65C1AB)
fffff880`10bc9000 fffff880`10bd8000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`10bd8000 fffff880`10be1000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`10be1000 fffff880`10bf7000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff960`000e0000 fffff960`003f3000   win32k   win32k.sys   unavailable (00000000)
fffff960`00400000 fffff960`0040a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff960`00710000 fffff960`00737000   cdd      cdd.dll      unavailable (00000000)
fffff960`00840000 fffff960`008a1000   ATMFD    ATMFD.DLL    unavailable (00000000)
Unloaded modules:
fffff880`21e2b000 fffff880`221cd000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  003A2000
fffff880`221cd000 fffff880`221e0000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0718a000 fffff880`07198000   kbdhid.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`0bc52000 fffff880`0bff4000   hiber_iaStor
    Checksum:  00000000
    ImageSize:  003A2000
fffff880`0bc00000 fffff880`0bc13000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`02080000 fffff880`0208e000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`04e1a000 fffff880`051bc000   dump_iaStor.
    Checksum:  00000000
    ImageSize:  003A2000
fffff880`051bc000 fffff880`051cf000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Top Bottom
