Itai Koren
Hello,
I'm using Windows 7 64Bit version.
Lately i've been experiencing BSOD's and sudden shutdowns. They happen on number of ways:
suddenly in middle of work, when computer is idle for some time, and also when i try to start program Filezilla for example.
I'm thinking it has something to do with the wireless network card, but i tried to disable it and i still had some problems...
When computer is coming back from standby i sometimes it sometime doesn't respond, but this is also intermittent, sometimes it wakes up with no problem...
I tried to run "perfmon /report" but i got BSOD again... :frown:
Lately i have this problem once or twice an hour so it really affects the work on the computer.
Here is two erros i got in the event viewer on two different times it happened:
The computer has rebooted from a bugcheck. The bugcheck was: 0x000000c4 (0x0000000000000081, 0xfffff9804d7defc0, 0x0000000000000082, 0x0000000000000000). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 010211-22339-02.
The computer has rebooted from a bugcheck. The bugcheck was: 0x000000c4 (0x0000000000000081, 0xfffff98046e3efc0, 0x0000000000000082, 0x0000000000000000). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 010311-29842-01.
Thanks!
Ok there:
1. DISABLE DRIVER VERIFIER - Start Menu -> Search Box -> type this -> verifier.exe /reset -> Press "Enter" -> Reboot
2. The crash was caused by MagicISO SCSI Host Controller:
[B]DRIVER_VERIFIER_DETECTED_VIOLATION (c4)
A device driver attempting to corrupt the system has been caught.
Probably caused by : mcdbus.sys[/B]
-> Update or uninstall MagicISO:
mcdbus.sys   Tue Feb 24 05:34:07 2009
-> Update Ralink Wireless:
netr28x.sys  Fri Sep 11 01:25:00 2009
I did ask you to update Ralink and I don't understand why you didn't. Please do so.
Crash Dumps:
Microsoft (R) Windows Debugger Version...
here it is : View attachment Seven Forums.zip
Thanks again!
Ok there:
Crash Dumps:
Loading Dump File [F:\a\Minidump\D M P\DMP\010511-23353-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02a13000 PsLoadedModuleList = 0xfffff800`02c50e50
Debug session time: Wed Jan  5 09:48:33.430 2011 (UTC - 5:00)
System Uptime: 0 days 0:37:37.913
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck C4, {81, fffff980519f6fc0, 82, 0}
Unable to load image mcdbus.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for mcdbus.sys
*** ERROR: Module load completed but symbols could not be loaded for mcdbus.sys
Probably caused by : mcdbus.sys ( mcdbus+36823 )
Followup: MachineOwner
2: kd> !analyze -v
A device driver attempting to corrupt the system has been caught.  This is
because the driver was specified in the registry as being suspect (by the
administrator) and the kernel has enabled substantial checking of this driver.
If the driver attempts to corrupt the system, bugchecks 0xC4, 0xC1 and 0xA will
be among the most commonly seen crashes.
Arguments:
Arg1: 0000000000000081, MmMapLockedPages called without MDL_MAPPING_CAN_FAIL
Arg2: fffff980519f6fc0, MDL address.
Arg3: 0000000000000082, MDL flags.
Arg4: 0000000000000000, 0.
Debugging Details:
BUGCHECK_STR:  0xc4_81
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002f0d3dc to fffff80002a83740
STACK_TEXT:
fffff880`031c44f8 fffff800`02f0d3dc : 00000000`000000c4 00000000`00000081 fffff980`519f6fc0 00000000`00000082 : nt!KeBugCheckEx
fffff880`031c4500 fffff800`02f2089a : fffff980`519f6fc0 00000000`00000002 fffffa80`0580fc60 fffff880`031c5000 : nt!VerifierBugCheckIfAppropriate+0x3c
fffff880`031c4540 fffff880`04313823 : fffff980`4e09aea0 fffff980`505acfc0 fffffa80`05489040 fffffa80`000007ad : nt!VerifierMmMapLockedPages+0x4a
fffff880`031c4580 fffff980`4e09aea0 : fffff980`505acfc0 fffffa80`05489040 fffffa80`000007ad fffff980`4e09aea0 : mcdbus+0x36823
fffff880`031c4588 fffff980`505acfc0 : fffffa80`05489040 fffffa80`000007ad fffff980`4e09aea0 fffff980`4e09af70 : 0xfffff980`4e09aea0
fffff880`031c4590 fffffa80`05489040 : fffffa80`000007ad fffff980`4e09aea0 fffff980`4e09af70 fffff880`031c4aa0 : 0xfffff980`505acfc0
fffff880`031c4598 fffffa80`000007ad : fffff980`4e09aea0 fffff980`4e09af70 fffff880`031c4aa0 fffff980`505acfc0 : 0xfffffa80`05489040
fffff880`031c45a0 fffff980`4e09aea0 : fffff980`4e09af70 fffff880`031c4aa0 fffff980`505acfc0 fffffa80`0580fdb0 : 0xfffffa80`000007ad
fffff880`031c45a8 fffff980`4e09af70 : fffff880`031c4aa0 fffff980`505acfc0 fffffa80`0580fdb0 fffff880`031c4ab0 : 0xfffff980`4e09aea0
fffff880`031c45b0 fffff880`031c4aa0 : fffff980`505acfc0 fffffa80`0580fdb0 fffff880`031c4ab0 fffff880`00000000 : 0xfffff980`4e09af70
fffff880`031c45b8 fffff980`505acfc0 : fffffa80`0580fdb0 fffff880`031c4ab0 fffff880`00000000 fffff980`505acfe8 : 0xfffff880`031c4aa0
fffff880`031c45c0 fffffa80`0580fdb0 : fffff880`031c4ab0 fffff880`00000000 fffff980`505acfe8 fffffa80`04701700 : 0xfffff980`505acfc0
fffff880`031c45c8 fffff880`031c4ab0 : fffff880`00000000 fffff980`505acfe8 fffffa80`04701700 fffff800`02f1f09d : 0xfffffa80`0580fdb0
fffff880`031c45d0 fffff880`00000000 : fffff980`505acfe8 fffffa80`04701700 fffff800`02f1f09d fffff980`4e09aea0 : 0xfffff880`031c4ab0
fffff880`031c45d8 fffff980`505acfe8 : fffffa80`04701700 fffff800`02f1f09d fffff980`4e09aea0 00000000`00000002 : 0xfffff880`00000000
fffff880`031c45e0 fffffa80`04701700 : fffff800`02f1f09d fffff980`4e09aea0 00000000`00000002 fffffa80`6264636d : 0xfffff980`505acfe8
fffff880`031c45e8 fffff800`02f1f09d : fffff980`4e09aea0 00000000`00000002 fffffa80`6264636d fffffa80`0580fc60 : 0xfffffa80`04701700
fffff880`031c45f0 fffff880`043132db : fffffa80`0580fc60 00000000`00000000 fffff880`00edc0c2 00000000`00000000 : nt!VerifierExAllocatePoolWithTag+0x1d
fffff880`031c4630 fffffa80`0580fc60 : 00000000`00000000 fffff880`00edc0c2 00000000`00000000 00000000`00000000 : mcdbus+0x362db
fffff880`031c4638 00000000`00000000 : fffff880`00edc0c2 00000000`00000000 00000000`00000000 fffff880`031c48e0 : 0xfffffa80`0580fc60
STACK_COMMAND:  kb
FOLLOWUP_IP:
mcdbus+36823
fffff880`04313823 ??              ???
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  mcdbus+36823
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: mcdbus
IMAGE_NAME:  mcdbus.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  49a3cd1f
FAILURE_BUCKET_ID:  X64_0xc4_81_mcdbus+36823
Drivers:
fffff880`00f81000 fffff880`00fd8000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`03e9a000 fffff880`03f24000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`0403d000 fffff880`04053000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`00df3000 fffff880`00dfe000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`00ec0000 fffff880`00ec9000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00dc9000 fffff880`00df3000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff880`01964000 fffff880`0196b000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`019e5000 fffff880`019f6000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`02957000 fffff880`02975000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`007d0000 fffff960`007f7000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
fffff880`01900000 fffff880`0192a000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00cdf000 fffff880`00d9f000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`0189a000 fffff880`018ca000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c81000 fffff880`00cdf000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`010e3000 fffff880`01156000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`0402d000 fffff880`0403d000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`02871000 fffff880`0287a000   cpuz135_x64 cpuz135_x64.sys Tue Nov 09 08:33:36 2010 (4CD94DB0)
fffff880`06e71000 fffff880`06e7f000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0182b000 fffff880`01849000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`03e7c000 fffff880`03e8b000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01884000 fffff880`0189a000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06ad5000 fffff880`06af7000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`06f7d000 fffff880`06f86000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06e7f000 fffff880`06e8b000   dump_ataport dump_ataport.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06f86000 fffff880`06f99000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`06b72000 fffff880`06b7e000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`052fc000 fffff880`053f0000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
fffff880`04800000 fffff880`04846000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
fffff880`06f47000 fffff880`06f7d000   fastfat  fastfat.SYS  Mon Jul 13 19:23:28 2009 (4A5BC1F0)
fffff880`041e4000 fffff880`041f1000   fdc      fdc.sys      Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`01071000 fffff880`01085000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`04200000 fffff880`0420b000   flpydisk flpydisk.sys Mon Jul 13 20:00:54 2009 (4A5BCAB6)
fffff880`01025000 fffff880`01071000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0184a000 fffff880`01884000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`0142b000 fffff880`01475000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02fef000 fffff800`03038000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`011dc000 fffff880`01200000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`04220000 fffff880`0427c000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`06b0b000 fffff880`06b24000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`06b24000 fffff880`06b2c080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`06afd000 fffff880`06b0b000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0288f000 fffff880`02957000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`0148f000 fffff880`01498000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`04000000 fffff880`0401e000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`048dd000 fffff880`052fbb60   igdkmd64 igdkmd64.sys Wed Aug 25 15:35:58 2010 (4C75709E)
fffff880`013e8000 fffff880`013fe000   intelppm intelppm.sys Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`0401e000 fffff880`0402d000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff800`00bab000 fffff800`00bb5000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`0434b000 fffff880`0438e000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01400000 fffff880`0142b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`06af7000 fffff880`06afc200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06bd0000 fffff880`06be5000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06b8c000 fffff880`06baf000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`042dd000 fffff880`04319880   mcdbus   mcdbus.sys   Tue Feb 24 05:34:07 2009 (49A3CD1F)
fffff880`00c29000 fffff880`00c6d000   mcupdate mcupdate.dll Mon Jul 13 21:29:10 2009 (4A5BDF66)
fffff880`06b7e000 fffff880`06b8c000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`042ce000 fffff880`042dd000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`06b2f000 fffff880`06b3c000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00daf000 fffff880`00dc9000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0192a000 fffff880`0195b000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`06f22000 fffff880`06f32000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`02975000 fffff880`0298d000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`0298d000 fffff880`029ba000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`02800000 fffff880`0284e000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0284e000 fffff880`02871000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`019c9000 fffff880`019d4000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fe1000 fffff880`00feb000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`01085000 fffff880`010e3000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`03e71000 fffff880`03e7c000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`0147d000 fffff880`0148f000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`014ab000 fffff880`0159d000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`04077000 fffff880`04083000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`06a53000 fffff880`06a66000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`04083000 fffff880`040b2000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0420b000 fffff880`04220000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`03fae000 fffff880`03fbd000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`03f24000 fffff880`03f69000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`0159d000 fffff880`015fd000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`0411b000 fffff880`041d7000   netr28x  netr28x.sys  Fri Sep 11 01:25:00 2009 (4AA9DF2C)
fffff880`06f32000 fffff880`06f47000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`019d4000 fffff880`019e5000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`03e65000 fffff880`03e71000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a13000 fffff800`02fef000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
fffff880`01245000 fffff880`013e8000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`0195b000 fffff880`01964000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`06a00000 fffff880`06a53000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`03f72000 fffff880`03f98000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e33000 fffff880`00e48000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00eb9000 fffff880`00ec0000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00d9f000 fffff880`00daf000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`06c53000 fffff880`06cf9000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`06a98000 fffff880`06ad5000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c6d000 fffff880`00c81000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`04053000 fffff880`04077000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`048ba000 fffff880`048d5000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`01000000 fffff880`01021000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`042b4000 fffff880`042ce000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`03e14000 fffff880`03e65000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`019ae000 fffff880`019b7000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019b7000 fffff880`019c0000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019c0000 fffff880`019c9000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`011a2000 fffff880`011dc000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`06a66000 fffff880`06a7e000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`040b5000 fffff880`0411b000   Rt64win7 Rt64win7.sys Thu Nov 11 01:35:36 2010 (4CDB8EB8)
fffff880`0431a000 fffff880`04349000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
fffff880`06cf9000 fffff880`06d04000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`041f1000 fffff880`041fd000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`03fbd000 fffff880`03fda000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`01475000 fffff880`0147d000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`06e8c000 fffff880`06f22000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`06d43000 fffff880`06daa000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`06d04000 fffff880`06d31000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`04349000 fffff880`0434a480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`06d31000 fffff880`06d43000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0181e000 fffff880`0182b000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01800000 fffff880`0181e000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`03e00000 fffff880`03e14000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004b0000 fffff960`004ba000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`00c00000 fffff880`00c26000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`0438e000 fffff880`043a0000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`06b2d000 fffff880`06b2ef00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`048a9000 fffff880`048ba000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`043a0000 fffff880`043fa000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`04853000 fffff880`048a9000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`04846000 fffff880`04853000   usbuhci  usbuhci.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00feb000 fffff880`00ff8000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`0196b000 fffff880`01979000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`01979000 fffff880`0199e000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00e48000 fffff880`00e5d000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00e5d000 fffff880`00eb9000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`01156000 fffff880`011a2000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`041d7000 fffff880`041e4000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`03f98000 fffff880`03fae000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`03fda000 fffff880`03ff5000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`0199e000 fffff880`019ae000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00ece000 fffff880`00f72000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f72000 fffff880`00f81000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`03f69000 fffff880`03f72000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000e0000 fffff960`003f0000   win32k   win32k.sys   Tue Oct 19 23:08:46 2010 (4CBE5D3E)
fffff880`00fd8000 fffff880`00fe1000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`06baf000 fffff880`06bd0000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`06e00000 fffff880`06e71000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`06b3c000 fffff880`06b4a000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`06b4a000 fffff880`06b56000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`06b56000 fffff880`06b5f000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`06b5f000 fffff880`06b72000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
fffff880`06f7d000 fffff880`06fee000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`018ca000 fffff880`018d8000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`018d8000 fffff880`018e4000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018e4000 fffff880`018ed000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`018ed000 fffff880`01900000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
This is wierd.
I did update the Ralink driver. you can look in the earlier logs. you even approved that i have the most up to date.
MagicISO is already uninstalled few days ago, so i'm not sure why it shows up here...
I will try to update the ralink drivers (again).
If you're looking for a simple, lightweight, virtual drive program, I can recommend Link Removed - Invalid URL. I've never had an issue on my 64bit Win7 set up.
Best not to install it just yet though, get the headaches out of the way first!
here it is : View attachment 10476
Thanks again!
I'm seeing Ralink and MasgicISO on the drivers list from SevenForums.zip - and I asked you to collect this info only 2 hrs ago.
"Drivers' list 2011-1-09" <-
netr28x Ralink 802.11n 9/11/2009
mcdbus MagicISO 2/24/2009
Ok, the ralink driver drives me crazy!
I uninstalled it 3 times already, and each time after i install the new driver (downloaded from edimax website), i check the device manager and it appears i still have the old version ! (9/11/2009 3.0.7.0)
I even tried to manually delete the netr28x file. same thing happens.
So - how do i get rid of the old driver and install the new one (v3.4.1.0)?
this is the link where i download it from:::: EDIMAX Technology :::
I choose the win7 driver...
1. Ralink:
Control Panel > Device Manager > disable Ralink Wireless
2. MagicISO:
navigate to Windows/system32/drivers and rename to .old these 2 files:
netr28x.sys Ralink 802.11n 9/11/2009
mcdbus.sys MagicISO 2/24/2009
same thing. i install and when i check it's the same version
I do get an error after installation (it happened 2 out of 4 times) : Network controller no driver found
But i have wireless network and internet...
It seems like the edimax driver just don't want to be updated ... :(
Ralink corp.
Did you try Ralink Support?
Empty the folder C:\Windows\Minidump.
Enable driver verifier: Start -> type -> verifier.exe /all -> hit "Enter" -> reboot.
BSOD's will become frequent. Once you get 4-5 blue screens, disable the verifier: Start -> type -> verifier.exe /reset -> hit "Enter" -> reboot
yesterday I updated the driver from Ralink website: 3.1.8.1
today my system hung when i woke it up from standby. hung again while the system was loading (in the loading screen with four colors...)
It seems like this happens only when i wake the computer after long time. if it's only short time of stand-by, then everything ok...
Any idea? Maybe it is hardware problem with the network card?
Any bsod's so far?
No bsod's. Only screen freezing on wake-up and startup...
Windows still freezes sometimes when i wake the computer from sleep.
Any idea why it could happen?
Does your motherboard support S3 (ACPI Standby State)?
Make sure there's enough disk space.
1. Command Prompt > chkdsk /f c:
2. Try bios upgrade.
I'm suffering from occasional BSOD problems and have followed the threads in this forum. But I can't find the crash dumps, I don't seem to have a Minidump folder in my windows folder. I have the "show hidden files and folders checked" and "hide protected.....etc" unchecked but still can't find it. What am I doing wrong?
