adobesmurf
i have a BSOD being caused by pci.sys its a system file so how do i fix this BSOD?
BugCheck 9F, {3, ffffe0019e1b8060, ffffd000206ab960, ffffe0019e1d1b40}
Probably caused by : pci.sys
Followup: MachineOwner
the above basically means that a driver failed to do it's specific task within the required time. I couldn't actually see which driver is the culprit but...
adobesmurf
Curious why switch it to hybrid sleep instead of default
all it does is also write active data to hard drive and also ram
Also I installed the graphics deriver from asus its an older one now some games can't run because its to old.
adobesmurf
Well sent laptop to asus since warranty is nearly over, no bsod tried to download nvidia which would crash it before they claim is was a bad hard drive.
adobesmurf
Seems to be fine successfully installed a graphics driver the same way that used to crash it. I had (before repair) started to get black squres on my screen which surprised me even more that it was my nvidia card.
