slash695
Help!!!
I have started windows 7 from scratch three times already and still randomly get this screen!!
Please help!
Note, for ease of debugging i have no spyware, virus software.
Not a noob but a walkthrough on what to do would be great!
Thanks...
Jeff
Bellow is the BSOD readout and files for debugging.
Dump File : 021512-10779-01.dmp
Crash Time : 2/15/2012 10:29:13 AM
Bug Check String : DRIVER_POWER_STATE_FAILURE
Bug Check Code : 0x0000009f
Parameter 1 : 00000000`00000003
Parameter 2 : fffffa80`08ee3060
Parameter 3 : fffff800`00b9c3d8
Parameter 4 : fffffa80`094cfb00
Caused By Driver : nvlddmkm.sys
Caused By Address : nvlddmkm.sys+2017e2
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+7cc40
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021512-10779-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7601
Dump File Size : 891,192
Dump File : 021512-11107-01.dmp
Crash Time : 2/15/2012 12:30:23 AM
Parameter 2 : fffffa80`090d3060
Parameter 4 : fffffa80`06d59980
Caused By Driver : USBPORT.SYS
Caused By Address : USBPORT.SYS+5f99
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021512-11107-01.dmp
Major Version : 15
Dump File Size : 916,944
Dump File : 021412-10374-01.dmp
Crash Time : 2/14/2012 12:50:06 PM
Parameter 2 : fffffa80`08ee7060
Parameter 4 : fffffa80`09382590
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021412-10374-01.dmp
Major Version : 15
Dump File : 021312-10732-01.dmp
Crash Time : 2/13/2012 11:12:04 AM
Parameter 2 : fffffa80`0929e060
Parameter 4 : fffffa80`09369a60
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+7cc40
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7601.17640 (win7sp1_gdr.110622-1506)
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021312-10732-01.dmp
Major Version : 15
Dump File Size : 907,480
Dump File : 021212-10280-01.dmp
Crash Time : 2/12/2012 4:55:46 PM
Parameter 2 : fffffa80`09297060
Parameter 3 : fffff800`043dd3d8
Parameter 4 : fffffa80`074ed210
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021212-10280-01.dmp
Major Version : 15
Dump File Size : 947,976
Dump File : 020912-10982-01.dmp
Crash Time : 2/9/2012 11:21:42 AM
Parameter 2 : fffffa80`09088060
Parameter 4 : fffffa80`093266d0
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\020912-10982-01.dmp
Major Version : 15
Dump File Size : 893,928
Hi slash695 and Welcome to The Forum.
STOP 0x0000009F: DRIVER_POWER_STATE_FAILURE
Usual causes:
Device driver
All your dump files list 0x0000009F and usbhub.sys as the probable cause.
This is a Windows System file and for it to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes.
Random stop codes can often indicate hardware issues.
As a Priority:
EtronHub3.sys Mon Jul 25 22:30:59 2011
EtronXHCI.sys Mon Jul 25 22:30:56 2011
Update to Etron USB 3.0 v105 Drivers. This is a Gigabyte Mobo drivers link, just in case your Mobo Mfr. is a bit slow on the uptake!!
Drivers...
Usual causes:
Device driver
As a Priority:
Drivers that pre-date Windows 7. Update:
GEARAspiWDM.sys Mon May 18 13:17:04 2009 Gear Software CD-ROM Class Filter Driver v4.019.1 (Oct 2011). Also loads with iTunes
gdrv.sys Fri Mar 13 03:22:29 2009 Gigabyte Easy Saver. If you cannot update this then uninstall it. Gigabyte.
Drivers with Updates:
Rt64win7.sys Wed Jun 01 04:15:51 2011 Link Removed If you're unsure about manually installing drivers then choose the Win7 and WinServer 2008 R2 Auto Installation Program (SID:1483XXX) option to download.
rtl8192Ce.sys Tue Mar 29 11:13:47 2011 Link Removed
Bugcheck Analysis:
BugCheck 9F, {3, fffffa8008ee3060, fffff80000b9c3d8, fffffa80094cfb00}
Probably caused by : usbhub.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8008ee3060, Physical Device Object of the stack
Arg3: fffff80000b9c3d8, Functional Device Object of the stack
Arg4: fffffa80094cfb00, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  usbhub.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4ce7a68e
MODULE_NAME: usbhub
FAULTING_MODULE: fffff8800587a000 usbhub
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
STACK_TEXT:
fffff800`00b9c388 fffff800`02f00cd2 : 00000000`0000009f 00000000`00000003 fffffa80`08ee3060 fffff800`00b9c3d8 : nt!KeBugCheckEx
fffff800`00b9c390 fffff800`02e9e5fc : fffff800`00b9c4d8 fffff800`00b9c4d8 00000000`00000000 00000000`00000003 : nt! ?? ::FNODOBFM::`string'+0x34a90
fffff800`00b9c430 fffff800`02e9e496 : fffffa80`07164b80 00000000`00231d80 00000000`00000000 fffff880`0f2a0995 : nt!KiProcessTimerDpcTable+0x6c
fffff800`00b9c4a0 fffff800`02e9e37e : 00000053`967cc2f0 fffff800`00b9cb18 00000000`00231d80 fffff800`0300c288 : nt!KiProcessExpiredTimerList+0xc6
fffff800`00b9caf0 fffff800`02e9e167 : 0000001a`df9411c4 0000001a`00231d80 0000001a`df9411fb 00000000`00000080 : nt!KiTimerExpiration+0x1be
fffff800`00b9cb90 fffff800`02e8a96a : fffff800`03008e80 fffff800`03016cc0 00000000`00000002 fffff880`00000000 : nt!KiRetireDpcList+0x277
fffff800`00b9cc40 00000000`00000000 : fffff800`00b9d000 fffff800`00b97000 fffff800`00b9cc00 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0x9F_3_MAudioFastTrackUltra_IMAGE_usbhub.sys
Drivers:
fffff880`02d82000 fffff880`02dc0000   1394ohci 1394ohci.sys Sat Nov 20 10:44:56 2010 (4CE7A6A8)
fffff880`00f36000 fffff880`00f8d000   ACPI     ACPI.sys     Sat Nov 20 09:19:16 2010 (4CE79294)
fffff880`03e18000 fffff880`03ea1000   afd      afd.sys      Mon Apr 25 03:33:58 2011 (4DB4DD96)
fffff880`04373000 fffff880`04389000   AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00ff5000 fffff880`01000000   amdxata  amdxata.sys  Fri Mar 19 16:18:18 2010 (4BA3A3CA)
fffff880`014f7000 fffff880`014ff000   AppleCharger AppleCharger.sys Mon Jan 10 09:57:29 2011 (4D2AD809)
fffff880`0b871000 fffff880`0b87c000   asyncmac asyncmac.sys Tue Jul 14 01:10:13 2009 (4A5BCCE5)
fffff880`00e78000 fffff880`00e81000   atapi    atapi.sys    Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00db5000 fffff880`00ddf000   ataport  ataport.SYS  Sat Nov 20 09:19:15 2010 (4CE79293)
fffff880`019e4000 fffff880`019eb000   Beep     Beep.SYS     Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`03e00000 fffff880`03e11000   blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`0a5c6000 fffff880`0a5e4000   bowser   bowser.sys   Wed Feb 23 04:55:04 2011 (4D649328)
fffff960`006b0000 fffff960`006d7000   cdd      cdd.dll      unavailable (00000000)
fffff880`019b1000 fffff880`019db000   cdrom    cdrom.sys    Sat Nov 20 09:19:20 2010 (4CE79298)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Sat Nov 20 13:12:36 2010 (4CE7C944)
fffff880`0194b000 fffff880`0197b000   CLASSPNP CLASSPNP.SYS Sat Nov 20 09:19:23 2010 (4CE7929B)
fffff880`00d2d000 fffff880`00d8b000   CLFS     CLFS.SYS     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01145000 fffff880`011b7000   cng      cng.sys      Thu Nov 17 04:23:17 2011 (4EC48C35)
fffff880`04363000 fffff880`04373000   CompositeBus CompositeBus.sys Sat Nov 20 10:33:17 2010 (4CE7A3ED)
fffff880`05800000 fffff880`0580e000   crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`011b7000 fffff880`011d5000   dfsc     dfsc.sys     Sat Nov 20 09:26:31 2010 (4CE79447)
fffff880`03fee000 fffff880`03ffd000   discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`01935000 fffff880`0194b000   disk     disk.sys     Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`05963000 fffff880`05985000   drmk     drmk.sys     Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`0581a000 fffff880`05823000   dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`0580e000 fffff880`0581a000   dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`05823000 fffff880`05836000   dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`059e7000 fffff880`059f3000   Dxapi    Dxapi.sys    Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`0fcce000 fffff880`0fdc2000   dxgkrnl  dxgkrnl.sys  Sat Nov 20 09:50:50 2010 (4CE799FA)
fffff880`0f000000 fffff880`0f046000   dxgmms1  dxgmms1.sys  Sat Nov 20 09:49:53 2010 (4CE799C1)
fffff880`058d4000 fffff880`058e1e80   EtronHub3 EtronHub3.sys Mon Jul 25 22:30:59 2011 (4E2DE093)
fffff880`02dc0000 fffff880`02dd3500   EtronXHCI EtronXHCI.sys Mon Jul 25 22:30:56 2011 (4E2DE090)
fffff880`010d3000 fffff880`010e7000   fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`01087000 fffff880`010d3000   fltmgr   fltmgr.sys   Sat Nov 20 09:19:24 2010 (4CE7929C)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`018fb000 fffff880`01935000   fvevol   fvevol.sys   Sat Nov 20 09:24:06 2010 (4CE793B6)
fffff880`01808000 fffff880`01852000   fwpkclnt fwpkclnt.sys Sat Nov 20 09:21:37 2010 (4CE79321)
fffff880`0b9dd000 fffff880`0b9e6000   gdrv     gdrv.sys     Fri Mar 13 03:22:29 2009 (49B9D175)
fffff880`0434d000 fffff880`0435a000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 13:17:04 2009 (4A1151C0)
fffff800`033ff000 fffff800`03448000   hal      hal.dll      Sat Nov 20 13:00:25 2010 (4CE7C669)
fffff880`0fdc2000 fffff880`0fde6000   HDAudBus HDAudBus.sys Sat Nov 20 10:43:42 2010 (4CE7A65E)
fffff880`0598b000 fffff880`059e7000   HdAudio  HdAudio.sys  Sat Nov 20 10:44:23 2010 (4CE7A687)
fffff880`053c3000 fffff880`053d4000   HECIx64  HECIx64.sys  Wed Oct 20 00:33:43 2010 (4CBE2AD7)
fffff880`05852000 fffff880`0586b000   HIDCLASS HIDCLASS.SYS Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0586b000 fffff880`05873080   HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`05844000 fffff880`05852000   hidusb   hidusb.sys   Sat Nov 20 10:43:49 2010 (4CE7A665)
fffff880`0a4fd000 fffff880`0a5c6000   HTTP     HTTP.sys     Sat Nov 20 09:24:30 2010 (4CE793CE)
fffff880`018f2000 fffff880`018fb000   hwpolicy hwpolicy.sys Sat Nov 20 09:18:54 2010 (4CE7927E)
fffff880`04806000 fffff880`053c29a0   igdkmd64 igdkmd64.sys Wed Aug 31 20:53:13 2011 (4E5E9129)
fffff880`01000000 fffff880`01016000   intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`04256000 fffff880`04265000   kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`02de6000 fffff880`02df4000   kbdhid   kbdhid.sys   Sat Nov 20 10:33:25 2010 (4CE7A3F5)
fffff800`00bab000 fffff800`00bb5000   kdcom    kdcom.dll    Sat Feb 05 16:52:49 2011 (4D4D8061)
fffff880`04276000 fffff880`042b9000   ks       ks.sys       Sat Nov 20 10:33:23 2010 (4CE7A3F3)
fffff880`013e5000 fffff880`01400000   ksecdd   ksecdd.sys   Thu Nov 17 03:48:13 2011 (4EC483FD)
fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Thu Nov 17 04:23:44 2011 (4EC48C50)
fffff880`05985000 fffff880`0598a200   ksthunk  ksthunk.sys  Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`0a46a000 fffff880`0a47f000   lltdio   lltdio.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`0a426000 fffff880`0a449000   luafv    luafv.sys    Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`0197b000 fffff880`019ae000   MAudioFastTrackUltra MAudioFastTrackUltra.sys Tue Jan 11 20:12:17 2011 (4D2CB9A1)
fffff880`00cca000 fffff880`00d19000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 13:03:51 2010 (4CE7C737)
fffff880`05836000 fffff880`05844000   monitor  monitor.sys  Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`04265000 fffff880`04274000   mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`053e5000 fffff880`053f2000   mouhid   mouhid.sys   Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00d9b000 fffff880`00db5000   mountmgr mountmgr.sys Sat Nov 20 09:19:21 2010 (4CE79299)
fffff880`0a5e4000 fffff880`0a5fc000   mpsdrv   mpsdrv.sys   Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`0b080000 fffff880`0b0ad000   mrxsmb   mrxsmb.sys   Wed Apr 27 03:40:38 2011 (4DB78226)
fffff880`0b0ad000 fffff880`0b0fb000   mrxsmb10 mrxsmb10.sys Sat Jul 09 03:46:28 2011 (4E17C104)
fffff880`0b0fb000 fffff880`0b11f000   mrxsmb20 mrxsmb20.sys Wed Apr 27 03:39:37 2011 (4DB781E9)
fffff880`014db000 fffff880`014e6000   Msfs     Msfs.SYS     Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f96000 fffff880`00fa0000   msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`010e7000 fffff880`01145000   msrpc    msrpc.sys    Sat Nov 20 09:21:56 2010 (4CE79334)
fffff880`03fe3000 fffff880`03fee000   mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`018e0000 fffff880`018f2000   mup      mup.sys      Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`014ff000 fffff880`015f2000   ndis     ndis.sys     Sat Nov 20 09:23:30 2010 (4CE79392)
fffff880`043ad000 fffff880`043b9000   ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`0a4d2000 fffff880`0a4e5000   ndisuio  ndisuio.sys  Sat Nov 20 10:50:08 2010 (4CE7A7E0)
fffff880`043b9000 fffff880`043e8000   ndiswan  ndiswan.sys  Sat Nov 20 10:52:32 2010 (4CE7A870)
fffff880`058e4000 fffff880`058f9000   NDProxy  NDProxy.SYS  Sat Nov 20 10:52:20 2010 (4CE7A864)
fffff880`03f2b000 fffff880`03f3a000   netbios  netbios.sys  Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`03ea1000 fffff880`03ee6000   netbt    netbt.sys    Sat Nov 20 09:23:18 2010 (4CE79386)
fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Sat Nov 20 09:23:13 2010 (4CE79381)
fffff880`014e6000 fffff880`014f7000   Npfs     Npfs.SYS     Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`03fd7000 fffff880`03fe3000   nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02e16000 fffff800`033ff000   nt       ntkrnlmp.exe Thu Jun 23 03:53:23 2011 (4E02AAA3)
fffff880`01242000 fffff880`013e5000   Ntfs     Ntfs.sys     Sat Nov 20 09:20:57 2010 (4CE792F9)
fffff880`019db000 fffff880`019e4000   Null     Null.SYS     Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`0fccc000 fffff880`0fccd180   nvBridge nvBridge.kmd Sat Jan 08 01:57:22 2011 (4D27C482)
fffff880`058f9000 fffff880`05926000   nvhda64v nvhda64v.sys Thu Jul 07 17:21:14 2011 (4E15DCFA)
fffff880`0f055000 fffff880`0fccc000   nvlddmkm nvlddmkm.sys Sat Oct 15 07:07:55 2011 (4E99233B)
fffff880`0a47f000 fffff880`0a4d2000   nwifi    nwifi.sys    Tue Jul 14 01:07:23 2009 (4A5BCC3B)
fffff880`03eef000 fffff880`03f15000   pacer    pacer.sys    Sat Nov 20 10:52:18 2010 (4CE7A862)
fffff880`00fe0000 fffff880`00ff5000   partmgr  partmgr.sys  Sat Nov 20 09:20:00 2010 (4CE792C0)
fffff880`00fa0000 fffff880`00fd3000   pci      pci.sys      Sat Nov 20 09:19:11 2010 (4CE7928F)
fffff880`00e71000 fffff880`00e78000   pciide   pciide.sys   Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00d8b000 fffff880`00d9b000   PCIIDEX  PCIIDEX.SYS  Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`0b11f000 fffff880`0b1c5000   peauth   peauth.sys   Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`05926000 fffff880`05963000   portcls  portcls.sys  Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00d19000 fffff880`00d2d000   PSHED    PSHED.dll    Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`04389000 fffff880`043ad000   rasl2tp  rasl2tp.sys  Sat Nov 20 10:52:34 2010 (4CE7A872)
fffff880`04200000 fffff880`0421b000   raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0421b000 fffff880`0423c000   raspptp  raspptp.sys  Sat Nov 20 10:52:31 2010 (4CE7A86F)
fffff880`0423c000 fffff880`04256000   rassstp  rassstp.sys  Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`03f86000 fffff880`03fd7000   rdbss    rdbss.sys    Sat Nov 20 09:27:51 2010 (4CE79497)
fffff880`014c0000 fffff880`014c9000   RDPCDD   RDPCDD.sys   Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`014c9000 fffff880`014d2000   rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`014d2000 fffff880`014db000   rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`018a6000 fffff880`018e0000   rdyboost rdyboost.sys Sat Nov 20 09:43:10 2010 (4CE7982E)
fffff880`0a4e5000 fffff880`0a4fd000   rspndr   rspndr.sys   Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`042bd000 fffff880`04341000   Rt64win7 Rt64win7.sys Wed Jun 01 04:15:51 2011 (4DE5AEE7)
fffff880`02c01000 fffff880`02d75000   rtl8192Ce rtl8192Ce.sys Tue Mar 29 11:13:47 2011 (4D91B0DB)
fffff880`0b1c5000 fffff880`0b1d0000   secdrv   secdrv.SYS   Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`04341000 fffff880`0434d000   serenum  serenum.sys  Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`03f3a000 fffff880`03f57000   serial   serial.sys   Tue Jul 14 01:00:40 2009 (4A5BCAA8)
fffff880`0189e000 fffff880`018a6000   spldr    spldr.sys    Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`0b945000 fffff880`0b9dd000   srv      srv.sys      Fri Apr 29 04:06:06 2011 (4DBA2B1E)
fffff880`0b8dc000 fffff880`0b945000   srv2     srv2.sys     Fri Apr 29 04:05:46 2011 (4DBA2B0A)
fffff880`0b000000 fffff880`0b031000   srvnet   srvnet.sys   Fri Apr 29 04:05:35 2011 (4DBA2AFF)
fffff880`04274000 fffff880`04275480   swenum   swenum.sys   Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01604000 fffff880`01808000   tcpip    tcpip.sys    Thu Sep 29 04:43:04 2011 (4E83E948)
fffff880`0b031000 fffff880`0b043000   tcpipreg tcpipreg.sys Sat Nov 20 10:51:48 2010 (4CE7A844)
fffff880`015f2000 fffff880`015ff000   TDI      TDI.SYS      Sat Nov 20 09:22:06 2010 (4CE7933E)
fffff880`0121b000 fffff880`0123d000   tdx      tdx.sys      Sat Nov 20 09:21:54 2010 (4CE79332)
fffff880`03f72000 fffff880`03f86000   termdd   termdd.sys   Sat Nov 20 11:03:40 2010 (4CE7AB0C)
fffff960`00540000 fffff960`0054a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`011d5000 fffff880`011fb000   tunnel   tunnel.sys   Sat Nov 20 10:51:50 2010 (4CE7A846)
fffff880`02dd4000 fffff880`02de6000   umbus    umbus.sys    Sat Nov 20 10:44:37 2010 (4CE7A695)
fffff880`00ddf000 fffff880`00dfc000   usbccgp  usbccgp.sys  Sat Nov 20 10:44:03 2010 (4CE7A673)
fffff880`058e2000 fffff880`058e3f00   USBD     USBD.SYS     Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`053d4000 fffff880`053e5000   usbehci  usbehci.sys  Sat Nov 20 10:43:54 2010 (4CE7A66A)
fffff880`0587a000 fffff880`058d4000   usbhub   usbhub.sys   Sat Nov 20 10:44:30 2010 (4CE7A68E)
fffff880`01016000 fffff880`0106c000   USBPORT  USBPORT.SYS  Sat Nov 20 10:44:00 2010 (4CE7A670)
fffff880`00fd3000 fffff880`00fe0000   vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`019eb000 fffff880`019f9000   vga      vga.sys      Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`0148b000 fffff880`014b0000   VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`00e00000 fffff880`00e15000   volmgr   volmgr.sys   Sat Nov 20 09:19:28 2010 (4CE792A0)
fffff880`00e15000 fffff880`00e71000   volmgrx  volmgrx.sys  Sat Nov 20 09:20:43 2010 (4CE792EB)
fffff880`01852000 fffff880`0189e000   volsnap  volsnap.sys  Sat Nov 20 09:20:08 2010 (4CE792C8)
fffff880`02d75000 fffff880`02d82000   vwifibus vwifibus.sys Tue Jul 14 01:07:21 2009 (4A5BCC39)
fffff880`03f15000 fffff880`03f2b000   vwififlt vwififlt.sys Tue Jul 14 01:07:22 2009 (4A5BCC3A)
fffff880`03f57000 fffff880`03f72000   wanarp   wanarp.sys   Sat Nov 20 10:52:36 2010 (4CE7A874)
fffff880`014b0000 fffff880`014c0000   watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e83000 fffff880`00f27000   Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f27000 fffff880`00f36000   WDFLDR   WDFLDR.SYS   Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`03ee6000 fffff880`03eef000   wfplwf   wfplwf.sys   Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00090000 fffff960`003a4000   win32k   win32k.sys   unavailable (00000000)
fffff880`043e8000 fffff880`043ecd00   WmBEnum  WmBEnum.sys  Tue Apr 27 21:10:19 2010 (4BD744AB)
fffff880`059f3000 fffff880`059fc180   WmFilter WmFilter.sys Tue Apr 27 21:10:19 2010 (4BD744AB)
fffff880`0435a000 fffff880`04363000   wmiacpi  wmiacpi.sys  Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f8d000 fffff880`00f96000   WMILIB   WMILIB.SYS   Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`043ed000 fffff880`043fe480   WmXlCore WmXlCore.sys Tue Apr 27 21:09:26 2010 (4BD74476)
fffff880`0a449000 fffff880`0a46a000   WudfPf   WudfPf.sys   Sat Nov 20 10:42:44 2010 (4CE7A624)
Unloaded modules:
fffff880`0b87c000 fffff880`0b888000   hiber_atapor
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`0b888000 fffff880`0b891000   hiber_atapi.
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0b891000 fffff880`0b8a4000   hiber_dumpfv
    Checksum:  00000000
    ImageSize:  00013000
fffff880`0b800000 fffff880`0b871000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0197b000 fffff880`01989000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01989000 fffff880`01995000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01995000 fffff880`0199e000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`0199e000 fffff880`019b1000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
WOW!! Thank you so much for your leangthy and really easy to follow fix! :)
I followed all your steps, the only hiccups i came to was
1) gdrv.sys Fri Mar 13 03:22:29 2009 Gigabyte Easy Saver. If you cannot update this then uninstall it. Gigabyte.
*** I couldnt update it because it said it didnt exist. Likewise i couldnt find a way to uninstall it??
2) rtl8192Ce.sys Tue Mar 29 11:13:47 2011 Link Removed
*** Under Network adapters the Realtek Wireless LAN didnt exist, there was only ASUS PCE-N15 11n Wireless LAN PCI-E Card. But it seemed to be using the realtek driver under Driver provider ??
Thanks!
I followed all your steps, the only hiccups I came to was
GoTo C:\Windows\Drivers and rename to gdrv.bak, this will break it and prevent it from loading (It may be lurking elsewhere!).
Them's the babies!! (although this isn't a problem, but if there are newer drivers available.....).
I have tried all that but still had a few blue screens.
Posted bellow is the new ones, thanks so much for helping!!!
Jeff
Dump File : 021712-12027-01.dmp
Crash Time : 2/17/2012 3:13:46 AM
Bug Check String : PAGE_FAULT_IN_NONPAGED_AREA
Bug Check Code : 0x00000050
Parameter 1 : ffffffff`ffffffd0
Parameter 2 : 00000000`00000001
Parameter 3 : fffff800`02edea4c
Parameter 4 : 00000000`00000000
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021712-12027-01.dmp
Major Version : 15
Dump File Size : 262,144
Dump File : 021712-10498-01.dmp
Crash Time : 2/17/2012 3:11:37 AM
Parameter 2 : fffffa80`0a00f060
Parameter 4 : fffffa80`0aed52d0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\021712-10498-01.dmp
Major Version : 15
Dump File Size : 918,064
Note that bluescreens can be due to many things and the resolution may be a process of elimination!!​
STOP 0x00000050: PAGE_FAULT_IN_NONPAGED_AREA
Usual causes:
Defective hardware (particularly memory - but not just RAM), Faulty system service, Antivirus, Device driver, NTFS corruption, BIOS.
Your latest dump file lists AppleCharger.sys as the probable cause.
As a Priority:
AppleCharger.sys Mon Jan 10 09:57:29 2011 Gigabyte on/off charge driver. See here for details - Link Removed Removal may be necessary. Updates can be found here - Link Removed - Invalid URL
If I was you I'd also go into Services and change the Bonjour Service from Auto to Manual Start.
Please see: Link Removed Following Method 2:
Download
and run the SF Diagnostics Tool. Right click the SF Diag tool and select Run as Administrator before running. When the reports have been created, zip them up and attach to a post.
Download and run CPU-Z. Take screenshots**/snips of the CPU tab, Mainboard tab, Memory tab and all the slot #'s under the SPD tab.
Go to Post Reply, click on the Go Advanced button and attach the screenshots**/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
If screenshots, please crop.
