BSOD help me
I have problem when I run windows media player then windowns change to blue screen and restart and I run windows media player one time but nothing windows does not turn blue screen I do not why help me
dmp file is below help :-$:-$
Hi and welcome. Your machine has multiple issues and they must be taken care of.
1) Uninstall ESET in safe mode using the tool here:
ESET Knowledgebase - How do I manually uninstall my ESET security product?
Reboot and install MSE.
2) Uninstall Hardware Sensors monitor. The driver is too old for Windows 7:
hmonitor45 hmonitor45.sys Sat Jul 26 09:25:10 2008
3) Delete this entire folder:
D:\download\VLAuto4F2.71_CrackedFake\
to make sure that this driver is also removed:
Ohm_vn Ohm_vn.sys Thu Jul 02 15:17:52 2009
Reboot.
4) Update your modem drivers:
VSTAZL3 VSTAZL3.SYS Wed Oct 15 20:30:03 2008
5) Your AOL software is very old and needs to be updated to the latest version they have:
wanatw4 wanatw4.sys Tue Jul 16 11:23:14 2002
6) Visit the manufacturer's site of your motherboard and install the latest Ricoh SD Card Reader driver from there:
rixdptsk rixdptsk.sys Tue Nov 14 20:35:19 2006
7) Must update Broadcom ethernet driver from the motherboard manufacturer's site:
bcm4sbxp bcm4sbxp.sys Tue Nov 21 07:25:43 2006
8) Must also visit the manufacturer's site of your wireless adapter to update this very old driver:
bcmwl6 bcmwl6.sys Thu Mar 26 20:58:48 2009
9) Must update the video card driver:
nvlddmkm nvlddmkm.sys Fri Nov 20 22:55:33 2009
NVIDIA
10) Must uninstall FAN I/O software. The driver is ancient:
fanio fanio.sys Fri Feb 16 04:05:48 2007
11) Must uninstall ISODrive. The driver is too old for Windows 7:
ISODrive ISODrive.sys Tue Feb 10 04:22:07 2009
Replace with PowerISO.
PowerISO - Create, Edit, Compress, Encrypt, Split, Mount, Extract ISO file, ISO/BIN converter, Virtual Drive
12) Must update or uninstall StarForce. The driver is ancient:
sfhlp02 sfhlp02.sys Thu Oct 28 06:47:59 2004
Congrats lol. This machine is amongst the worst I've ever seen with regards to the state and condition to the software installed.
Unless you follow what I've said precisely and to a tee, you will be much better off with a clean install while formatting, of Windows 7.
And one further thing....we don't support machines with cracked software installed on it here. So consider my advice above a special exception for you as I was feeling kind.
You should start with step 3 above.
