Windows 7 [bsod] help please
Gareth Parker
View attachment error reports.zip
Hello,
iam getting lots of diffrent bsods on my machine,i think its hardware but need to know what please?
using both windows 7 32bit at present but was also getting them in x64.
most common bsod is memory mangement ,i have checked the ram and found some sticks to have errors and removed them,but iam still getting bsods?:confused:
thanks for the support.
yours,
gareth
Yep, everything looks well there. So if you experience more crashes, there is unfortunately a memory defect.
The reasons that is for sure are because all your drivers are well and also that you said you crashed in safe mode.
thanks Torrent G and the windows 7 forum.
After testing my other strip of ram over night i found 3 errors that where causing the bsod on my pc.
i leave this for the people,
If you are suffering from memory management bsods please,
1.please reduce to 1 strip of ram.
2.please test each of the strips of ram overnight with memtest. http://www.memtest.org/
3.please check results and rma the bad bits of ram.
4.then have a nice day.
its that simple.
No, it is not that simple. Memory management bsods are very often caused by antivirus in use, or other drivers pre-July 2009.
If you ran Memtest on RAM that was set incorrectly in bios, which is another instance which is far from rare, you'd be getting results that are incorrect. RMA would be a waste of time and resources.
Please refrain from giving advice about bsod analysis and repair when you do not have knowledge of them.
