BSOD :( help?
#41
No deleting needed at all. Just run the Windows 7 32 bit Intel SATA RAID Driver installer from the link.
#42
error has occured registering one or more components...
*sigh*...
it DEFINATELY the right version....
#43
You can check your temp directory folders for the iaStor.sys file created when running the installer.
If you find it, copy/paste it over the one at C:\Windows\System32\drivers
Then reboot.
(Use CPU-Z to double check that you posted the correct motherboard.)
#44
CPU-Z??? never heard of that
#45
Ok, done! dont know what CPU-Z is, but i done what you said, now what? should that be it? or only stage 1?
#47
what do i do with CPU-Z? i got a "kernal power" crash while playing a game, it just turned off, no BSOD YET... not sure wether to post the info on the kernal power error here since it IS the BSOD section...
#48
ok, did that thing you told me to do on other thread, paste it over my file, started my comp, opened browser and BAM! BSOD!!!!
*sigh* here we go again, eh?
#50
this is a brand new HDD.. and btw.. could it not be the file u sent me? it might be incompatable? or is it the file which is allowing the kernel errors to be shown as BSOD? i dunno, im confused... if all else fails, i guess i have to reformat :(
#51
Brand new hard drive means nothing here.
Install the file from my previous post and then post new crashes if they happen. We can then run a command to fix file system corruption but I think the J-Micron update might fix it.
#52
ok, ive done it, il update if there are any crashes...
should i let you know if that kernel thing happens? since it might have the same cause?
#53
KERNEL_MODE_EXCEPTION_NOT_HANDLED (8e)
generally bad drivers
Stack:
9dd029f8 88ca43d2 875318c0 a32e24e0 00000001 Ntfs!NtfsInitializeFcbAndStdInfo+0x14b
9dd02bf4 88c9532c 875318c0 84de1008 a32cd0f8 Ntfs!NtfsCreateNewFile+0x8d5
9dd02cdc 88c1b210 875318c0 84de1008 9c493944 Ntfs!NtfsCommonCreate+0xd2f
9dd02d1c 82c8611e 9c4938dc 00000000 ffffffff Ntfs!
Update this one now:
jraid.sys Fri Jul 17 18:31:37 2009
JMicron Technology Corp
cmd -> chkdsk /r, might be hdd related.
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [F:\a\Minidump\8042d1284654425-bsod-help-091610-15693-01.dmp]
Executable search path is:
Windows 7 Kernel Version 7600 MP (4 procs) Free x86 compatible
Built by: 7600.16617.x86fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0x82c16000 PsLoadedModuleList = 0x82d5e810
System Uptime: 0 days 0:01:52.274
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
3: kd> !analyze -v
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003.  This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG.  This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG.  This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000005, The exception code that was not handled
Arg2: 2e24e0a3, The address that the exception occurred at
Arg3: 9dd02827, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - <Unable to get error code text>
FAULTING_IP:
+0
2e24e0a3 ??              ???
TRAP_FRAME:  9dd02827 -- (.trap 0xffffffff9dd02827)
ErrCode = 00000010
eax=0000008c ebx=a32e24e0 ecx=00000000 edx=00000048 esi=9dd029b8 edi=8558b0d8
eip=2e24e0a3 esp=9dd0289b ebp=9dd02930 iopl=0         nv up ei pl zr na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010246
2e24e0a3 ??              ???
Resetting default scope
CUSTOMER_CRASH_COUNT:  1
BUGCHECK_STR:  0x8E
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  0
UNALIGNED_STACK_POINTER:  9dd0289b
LAST_CONTROL_TRANSFER:  from 82cd3382 to 82cf2d10
STACK_TEXT:
9dd02394 82cd3382 0000008e c0000005 2e24e0a3 nt!KeBugCheckEx+0x1e
9dd027b7 82c5a036 9dd027d3 00000000 9dd02827 nt!KiDispatchException+0x1ac
9dd0281f 82c59fea 9dd02930 2e24e0a3 badb0d00 nt!CommonDispatchException+0x4a
9dd02827 2e24e0a3 badb0d00 00000048 d7f10000 nt!Kei386EoiHelper+0x192
WARNING: Frame IP not in any known module. Following frames may be wrong.
9dd02930 88ca26b4 875318c0 a32e24e0 00000010 0x2e24e0a3
9dd02d1c 82c8611e 9c4938dc 00000000 ffffffff Ntfs!NtfsCommonCreateCallout+0x20
9dd02d1c 82c86215 9c4938dc 00000000 ffffffff nt!KiSwapKernelStackAndExit+0x15a
9c493840 00000000 00000000 00000000 00000000 nt!KiSwitchKernelStackAndCallout+0x31
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt!KiDispatchException+1ac
82cd3382 cc              int     3
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  nt!KiDispatchException+1ac
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrpamp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  4c1c3fac
FAILURE_BUCKET_ID:  0x8E_nt!KiDispatchException+1ac
Followup: MachineOwner
start    end        module name
80ba1000 80ba9000   kdcom      (deferred)
    Mapped memory image file: c:\websymbols\kdcom.dll\4A5BDAAA8000\kdcom.dll
    Image path: kdcom.dll
    Image name: kdcom.dll
    Timestamp:        Tue Jul 14 04:08:58 2009 (4A5BDAAA)
    CheckSum:         000138B1
    ImageSize:        00008000
    File version:     6.1.7600.16385
    Product version:  6.1.7600.16385
    File flags:       0 (Mask 3F)
    File OS:          40004 NT Win32
    File type:        3.A Driver
    File date:        00000000.00000000
    Translations:     0409.04b0
    CompanyName:      Microsoft Corporation
    ProductName:      Microsoft® Windows® Operating System
    InternalName:     kdcom.dll
    OriginalFilename: kdcom.dll
    ProductVersion:   6.1.7600.16385
    FileVersion:      6.1.7600.16385 (win7_rtm.090713-1255)
    FileDescription:  Serial Kernel Debugger
    LegalCopyright:   © Microsoft Corporation. All rights reserved.
82c16000 83026000   nt         (pdb symbols)          c:\websymbols\ntkrpamp.pdb\BF17F0A967FD4E7BBA4EB341B6C87CCB2\ntkrpamp.pdb
    Loaded symbol image file: ntkrpamp.exe
    Mapped memory image file: c:\websymbols\ntkrnlpa.exe\4C1C3FAC410000\ntkrnlpa.exe
    Image path: ntkrpamp.exe
    Image name: ntkrpamp.exe
    Timestamp:        Sat Jun 19 06:55:24 2010 (4C1C3FAC)
    CheckSum:         003CBBE7
    ImageSize:        00410000
    File version:     6.1.7600.16617
    Product version:  6.1.7600.16617
    File type:        1.0 App
    InternalName:     ntkrpamp.exe
    OriginalFilename: ntkrpamp.exe
    ProductVersion:   6.1.7600.16617
    FileVersion:      6.1.7600.16617 (win7_gdr.100618-1621)
    FileDescription:  NT Kernel & System
83026000 8305d000   hal        (deferred)
    Mapped memory image file: c:\websymbols\halmacpi.dll\4A5BBF0737000\halmacpi.dll
    Image path: halmacpi.dll
    Image name: halmacpi.dll
    Timestamp:        Tue Jul 14 02:11:03 2009 (4A5BBF07)
    CheckSum:         0003BD09
    ImageSize:        00037000
    File type:        2.0 Dll
    InternalName:     halmacpi.dll
    OriginalFilename: halmacpi.dll
    FileDescription:  Hardware Abstraction Layer DLL
83200000 8320e000   WDFLDR     (deferred)
    Mapped memory image file: c:\websymbols\WDFLDR.SYS\4A5BBF1De000\WDFLDR.SYS
    Image path: WDFLDR.SYS
    Image name: WDFLDR.SYS
    Timestamp:        Tue Jul 14 02:11:25 2009 (4A5BBF1D)
    CheckSum:         00009DF6
    ImageSize:        0000E000
    File version:     1.9.7600.16385
    Product version:  1.9.7600.16385
    File type:        3.7 Driver
    Translations:     0000.04b0
    InternalName:     wdfldr.sys
    OriginalFilename: wdfldr.sys
    ProductVersion:   1.9.7600.16385
    FileVersion:      1.9.7600.16385 (win7_rtm.090713-1255)
    FileDescription:  Kernel Mode Driver Framework Loader
83210000 83288000   mcupdate   (deferred)
    Image path: mcupdate.dll
    Image name: mcupdate.dll
    Timestamp:        Tue Jul 14 04:06:41 2009 (4A5BDA21)
    CheckSum:         000737D7
    ImageSize:        00078000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
83288000 83299000   PSHED      (deferred)
    Mapped memory image file: c:\websymbols\PSHED.dll\4A5BDAD011000\PSHED.dll
    Image path: PSHED.dll
    Image name: PSHED.dll
    Timestamp:        Tue Jul 14 04:09:36 2009 (4A5BDAD0)
    CheckSum:         000108A2
    ImageSize:        00011000
    InternalName:     pshed.dll
    OriginalFilename: pshed.dll
    FileDescription:  Platform Specific Hardware Error Driver
83299000 832a1000   BOOTVID    (deferred)
    Mapped memory image file: c:\websymbols\BOOTVID.dll\4A5BD9A28000\BOOTVID.dll
    Image path: BOOTVID.dll
    Image name: BOOTVID.dll
    Timestamp:        Tue Jul 14 04:04:34 2009 (4A5BD9A2)
    CheckSum:         00010FF0
    ImageSize:        00008000
    File type:        3.4 Driver
    InternalName:     bootvid.dll
    OriginalFilename: bootvid.dll
    FileDescription:  VGA Boot Driver
832a1000 832e3000   CLFS       (deferred)
    Mapped memory image file: c:\websymbols\CLFS.SYS\4A5BBF0E42000\CLFS.SYS
    Image path: CLFS.SYS
    Image name: CLFS.SYS
    Timestamp:        Tue Jul 14 02:11:10 2009 (4A5BBF0E)
    CheckSum:         000461C7
    ImageSize:        00042000
    InternalName:     clfs.sys
    OriginalFilename: Clfs.Sys
    FileDescription:  Common Log File System Driver
832e3000 8338e000   CI         (deferred)
    Mapped memory image file: c:\websymbols\CI.dll\4A5BDAC8ab000\CI.dll
    Image path: CI.dll
    Image name: CI.dll
    Timestamp:        Tue Jul 14 04:09:28 2009 (4A5BDAC8)
    CheckSum:         000B5D72
    ImageSize:        000AB000
    InternalName:     ci.dll
    OriginalFilename: ci.dll
    FileDescription:  Code Integrity Module
8338e000 833ff000   Wdf01000   (deferred)
    Mapped memory image file: c:\websymbols\Wdf01000.sys\4A5BBF2871000\Wdf01000.sys
    Image path: Wdf01000.sys
    Image name: Wdf01000.sys
    Timestamp:        Tue Jul 14 02:11:36 2009 (4A5BBF28)
    CheckSum:         000717B7
    ImageSize:        00071000
    InternalName:     wdf01000.sys
    OriginalFilename: wdf01000.sys
    FileDescription:  Kernel Mode Driver Framework Runtime
88800000 88808000   rdprefmp   (deferred)
    Mapped memory image file: c:\websymbols\rdprefmp.sys\4A5BCAE58000\rdprefmp.sys
    Image path: rdprefmp.sys
    Image name: rdprefmp.sys
    Timestamp:        Tue Jul 14 03:01:41 2009 (4A5BCAE5)
    CheckSum:         0000F3BB
    ImageSize:        00008000
    InternalName:     RDPREFMP.SYS
    OriginalFilename: RDPREFMP.SYS
    FileDescription:  RDP Reflector Driver Miniport
8880c000 88854000   ACPI       (deferred)
    Mapped memory image file: c:\websymbols\ACPI.sys\4A5BBF0F48000\ACPI.sys
    Image path: ACPI.sys
    Image name: ACPI.sys
    Timestamp:        Tue Jul 14 02:11:11 2009 (4A5BBF0F)
    CheckSum:         000480E5
    ImageSize:        00048000
    InternalName:     ACPI.sys
    OriginalFilename: ACPI.sys
    FileDescription:  ACPI Driver for NT
88854000 8885d000   WMILIB     (deferred)
    Mapped memory image file: c:\websymbols\WMILIB.SYS\4A5BBF1A9000\WMILIB.SYS
    Image path: WMILIB.SYS
    Image name: WMILIB.SYS
    Timestamp:        Tue Jul 14 02:11:22 2009 (4A5BBF1A)
    CheckSum:         0000B93D
    ImageSize:        00009000
    InternalName:     WmiLib.sys
    OriginalFilename: WmiLib.sys
    FileDescription:  WMILIB WMI support library Dll
8885d000 88865000   msisadrv   (deferred)
    Mapped memory image file: c:\websymbols\msisadrv.sys\4A5BBF0D8000\msisadrv.sys
    Image path: msisadrv.sys
    Image name: msisadrv.sys
    Timestamp:        Tue Jul 14 02:11:09 2009 (4A5BBF0D)
    CheckSum:         0000CD81
    ImageSize:        00008000
    InternalName:     msisadrv.sys
    OriginalFilename: msisadrv.sys
    FileDescription:  ISA Driver
88865000 8888f000   pci        (deferred)
    Mapped memory image file: c:\websymbols\pci.sys\4A5BBF142a000\pci.sys
    Image path: pci.sys
    Image name: pci.sys
    Timestamp:        Tue Jul 14 02:11:16 2009 (4A5BBF14)
    CheckSum:         0002961B
    ImageSize:        0002A000
    File type:        2.0 Dll
    InternalName:     pci.sys
    OriginalFilename: pci.sys
    FileDescription:  NT Plug and Play PCI Enumerator
8888f000 8889a000   vdrvroot   (deferred)
    Mapped memory image file: c:\websymbols\vdrvroot.sys\4A5BC74Bb000\vdrvroot.sys
    Image path: vdrvroot.sys
    Image name: vdrvroot.sys
    Timestamp:        Tue Jul 14 02:46:19 2009 (4A5BC74B)
    CheckSum:         00009326
    ImageSize:        0000B000
    File type:        2.0 Dll
    InternalName:     vdrvroot.sys
    OriginalFilename: vdrvroot.sys
    FileDescription:  Virtual Drive Root Enumerator
8889a000 888ab000   partmgr    (deferred)
    Mapped memory image file: c:\websymbols\partmgr.sys\4A5BBF2711000\partmgr.sys
    Image path: partmgr.sys
    Image name: partmgr.sys
    Timestamp:        Tue Jul 14 02:11:35 2009 (4A5BBF27)
    CheckSum:         00015C7E
    ImageSize:        00011000
    InternalName:     partmgr.sys
    OriginalFilename: partmgr.sys
    FileDescription:  Partition Management Driver
888ab000 888bb000   volmgr     (deferred)
    Mapped memory image file: c:\websymbols\volmgr.sys\4A5BBF1D10000\volmgr.sys
    Image path: volmgr.sys
    Image name: volmgr.sys
    CheckSum:         000192BF
    ImageSize:        00010000
    InternalName:     volmgr.sys
    OriginalFilename: volmgr.sys
    FileDescription:  Volume Manager Driver
888bb000 88906000   volmgrx    (deferred)
    Mapped memory image file: c:\websymbols\volmgrx.sys\4A5BBF2D4b000\volmgrx.sys
    Image path: volmgrx.sys
    Image name: volmgrx.sys
    Timestamp:        Tue Jul 14 02:11:41 2009 (4A5BBF2D)
    CheckSum:         0004A22A
    ImageSize:        0004B000
    InternalName:     volmgrx.sys
    OriginalFilename: volmgrx.sys
    FileDescription:  Volume Manager Extension Driver
88906000 8890d000   pciide     (deferred)
    Mapped memory image file: c:\websymbols\pciide.sys\4A5BBF177000\pciide.sys
    Image path: pciide.sys
    Image name: pciide.sys
    Timestamp:        Tue Jul 14 02:11:19 2009 (4A5BBF17)
    CheckSum:         0000C6DD
    ImageSize:        00007000
    InternalName:     pciide.sys
    OriginalFilename: pciide.sys
    FileDescription:  Generic PCI IDE Bus Driver
8890d000 8891b000   PCIIDEX    (deferred)
    Mapped memory image file: c:\websymbols\PCIIDEX.SYS\4A5BBF13e000\PCIIDEX.SYS
    Image path: PCIIDEX.SYS
    Image name: PCIIDEX.SYS
    Timestamp:        Tue Jul 14 02:11:15 2009 (4A5BBF13)
    CheckSum:         0000FC04
    ImageSize:        0000E000
    InternalName:     pciidex.sys
    OriginalFilename: pciidex.sys
    FileDescription:  PCI IDE Bus Driver Extension
8891b000 88931000   mountmgr   (deferred)
    Mapped memory image file: c:\websymbols\mountmgr.sys\4A5BBF1F16000\mountmgr.sys
    Image path: mountmgr.sys
    Image name: mountmgr.sys
    Timestamp:        Tue Jul 14 02:11:27 2009 (4A5BBF1F)
    CheckSum:         0001FC48
    ImageSize:        00016000
    InternalName:     mountmgr.sys
    OriginalFilename: mountmgr.sys
    FileDescription:  Mount Point Manager
88931000 8894b000   jraid      (deferred)
    Image path: jraid.sys
    Image name: jraid.sys
    Timestamp:        Fri Jul 17 18:31:37 2009 (4A609959)
    CheckSum:         00025F9C
    ImageSize:        0001A000
8894b000 88971000   SCSIPORT   (deferred)
    Mapped memory image file: c:\websymbols\SCSIPORT.SYS\4A5BC73326000\SCSIPORT.SYS
    Image path: SCSIPORT.SYS
    Image name: SCSIPORT.SYS
    Timestamp:        Tue Jul 14 02:45:55 2009 (4A5BC733)
    CheckSum:         0002BA5A
    ImageSize:        00026000
    InternalName:     scsiport.sys
    OriginalFilename: scsiport.sys
    FileDescription:  SCSI Port Driver
88971000 889a5000   fltmgr     (deferred)
    Mapped memory image file: c:\websymbols\fltmgr.sys\4A5BBF1134000\fltmgr.sys
    Image path: fltmgr.sys
    Image name: fltmgr.sys
    Timestamp:        Tue Jul 14 02:11:13 2009 (4A5BBF11)
    CheckSum:         000382A8
    ImageSize:        00034000
    InternalName:     fltMgr.sys
    OriginalFilename: fltMgr.sys
    FileDescription:  Microsoft Filesystem Filter Manager
889a5000 889b6000   fileinfo   (deferred)
    Mapped memory image file: c:\websymbols\fileinfo.sys\4A5BC18F11000\fileinfo.sys
    Image path: fileinfo.sys
    Image name: fileinfo.sys
    Timestamp:        Tue Jul 14 02:21:51 2009 (4A5BC18F)
    CheckSum:         0001E423
    ImageSize:        00011000
    InternalName:     FileInfo.sys
    OriginalFilename: FileInfo.sys
    FileDescription:  FileInfo Filter Driver
889b6000 889db000   CLASSPNP   (deferred)
    Mapped memory image file: c:\websymbols\CLASSPNP.SYS\4A5BBF1825000\CLASSPNP.SYS
    Image path: CLASSPNP.SYS
    Image name: CLASSPNP.SYS
    Timestamp:        Tue Jul 14 02:11:20 2009 (4A5BBF18)
    CheckSum:         0002BBFE
    ImageSize:        00025000
    InternalName:     Classpnp.sys
    OriginalFilename: Classpnp.sys
    FileDescription:  SCSI Class System Dll
889db000 889fc000   VIDEOPRT   (deferred)
    Mapped memory image file: c:\websymbols\VIDEOPRT.SYS\4A5BC27D21000\VIDEOPRT.SYS
    Image path: VIDEOPRT.SYS
    Image name: VIDEOPRT.SYS
    Timestamp:        Tue Jul 14 02:25:49 2009 (4A5BC27D)
    CheckSum:         00024B67
    ImageSize:        00021000
    InternalName:     videoprt.sys
    OriginalFilename: videoprt.sys
    FileDescription:  Video Port Driver
88a00000 88a23000   ataport    (deferred)
    Mapped memory image file: c:\websymbols\ataport.SYS\4A5BBF1623000\ataport.SYS
    Image path: ataport.SYS
    Image name: ataport.SYS
    Timestamp:        Tue Jul 14 02:11:18 2009 (4A5BBF16)
    CheckSum:         0002F425
    ImageSize:        00023000
    InternalName:     ataport.sys
    OriginalFilename: ataport.sys
    FileDescription:  ATAPI Driver Extension
88a23000 88a2d000   msahci     (deferred)
    Mapped memory image file: c:\websymbols\msahci.sys\4A5BC72Ea000\msahci.sys
    Image path: msahci.sys
    Image name: msahci.sys
    Timestamp:        Tue Jul 14 02:45:50 2009 (4A5BC72E)
    CheckSum:         00015A98
    ImageSize:        0000A000
    InternalName:     msahci.sys
    OriginalFilename: msahci.sys
    FileDescription:  MS AHCI 1.0 Standard Driver
88a31000 88be6000   iaStor     (deferred)
    Image path: iaStor.sys
    Image name: iaStor.sys
    Timestamp:        Thu Mar 04 04:30:51 2010 (4B8F1B5B)
    CheckSum:         0006F037
    ImageSize:        001B5000
88be6000 88bef000   atapi      (deferred)
    Mapped memory image file: c:\websymbols\atapi.sys\4A5BBF139000\atapi.sys
    Image path: atapi.sys
    Image name: atapi.sys
    CheckSum:         00014C06
    ImageSize:        00009000
    InternalName:     atapi.sys
    OriginalFilename: atapi.sys
    FileDescription:  ATAPI IDE Miniport Driver
88bef000 88bf8000   amdxata    (deferred)
    Image path: amdxata.sys
    Image name: amdxata.sys
    Timestamp:        Tue May 19 20:57:35 2009 (4A12F30F)
    CheckSum:         0000636D
    ImageSize:        00009000
88bf8000 88c00000   rdpencdd   (deferred)
    Mapped memory image file: c:\websymbols\rdpencdd.sys\4A5BCAE38000\rdpencdd.sys
    Image path: rdpencdd.sys
    Image name: rdpencdd.sys
    Timestamp:        Tue Jul 14 03:01:39 2009 (4A5BCAE3)
    CheckSum:         0000E244
    ImageSize:        00008000
    InternalName:     RDPENCDD.SYS
    OriginalFilename: RDPENCDD.SYS
    FileDescription:  RDP Encoder Miniport
88c02000 88d31000   Ntfs       (pdb symbols)          c:\websymbols\ntfs.pdb\513BBB60430D411DBE02DF92418A2B272\ntfs.pdb
    Loaded symbol image file: Ntfs.sys
    Mapped memory image file: c:\websymbols\Ntfs.sys\4A5BBF4512f000\Ntfs.sys
    Image path: Ntfs.sys
    Image name: Ntfs.sys
    Timestamp:        Tue Jul 14 02:12:05 2009 (4A5BBF45)
    CheckSum:         00127FFB
    ImageSize:        0012F000
    InternalName:     ntfs.sys
    OriginalFilename: ntfs.sys
    FileDescription:  NT File System Driver
88d31000 88d5c000   msrpc      (deferred)
    Mapped memory image file: c:\websymbols\msrpc.sys\4A5BBF3F2b000\msrpc.sys
    Image path: msrpc.sys
    Image name: msrpc.sys
    Timestamp:        Tue Jul 14 02:11:59 2009 (4A5BBF3F)
    CheckSum:         00036B4F
    ImageSize:        0002B000
    InternalName:     krpcdd.sys
    OriginalFilename: krpcdd.sys
    FileDescription:  Kernel Remote Procedure Call Provider
88d5c000 88d6f000   ksecdd     (deferred)
    Mapped memory image file: c:\websymbols\ksecdd.sys\4A5BBF3C13000\ksecdd.sys
    Image path: ksecdd.sys
    Image name: ksecdd.sys
    Timestamp:        Tue Jul 14 02:11:56 2009 (4A5BBF3C)
    CheckSum:         00012431
    ImageSize:        00013000
    InternalName:     ksecdd.sys
    OriginalFilename: ksecdd.sys
    FileDescription:  Kernel Security Support Provider Interface
88d6f000 88dcc000   cng        (deferred)
    Mapped memory image file: c:\websymbols\cng.sys\4A5BC4275d000\cng.sys
    Image path: cng.sys
    Image name: cng.sys
    Timestamp:        Tue Jul 14 02:32:55 2009 (4A5BC427)
    CheckSum:         000650C5
    ImageSize:        0005D000
    InternalName:     cng.sys
    OriginalFilename: cng.sys
    FileDescription:  Kernel Cryptography, Next Generation
88dcc000 88dda000   pcw        (deferred)
    Mapped memory image file: c:\websymbols\pcw.sys\4A5BBF0Ee000\pcw.sys
    Image path: pcw.sys
    Image name: pcw.sys
    CheckSum:         000194CF
    ImageSize:        0000E000
    File type:        3.8 Driver
    InternalName:     pcw.sys
    OriginalFilename: pcw.sys
    FileDescription:  Performance Counters for Windows Driver
88dda000 88de3000   Fs_Rec     (deferred)
    Mapped memory image file: c:\websymbols\Fs_Rec.sys\4A5BBF129000\Fs_Rec.sys
    Image path: Fs_Rec.sys
    Image name: Fs_Rec.sys
    Timestamp:        Tue Jul 14 02:11:14 2009 (4A5BBF12)
    CheckSum:         0000845A
    ImageSize:        00009000
    InternalName:     fs_rec.sys
    OriginalFilename: fs_rec.sys
    FileDescription:  File System Recognizer Driver
88de3000 88def000   vga        (deferred)
    Mapped memory image file: c:\websymbols\vga.sys\4A5BC27Ec000\vga.sys
    Image path: vga.sys
    Image name: vga.sys
    Timestamp:        Tue Jul 14 02:25:50 2009 (4A5BC27E)
    CheckSum:         0000FBA1
    ImageSize:        0000C000
    InternalName:     vga.sys
    OriginalFilename: vga.sys
    FileDescription:  VGA/Super VGA Video Driver
88def000 88dfc000   watchdog   (deferred)
    Mapped memory image file: c:\websymbols\watchdog.sys\4A5BC21Ad000\watchdog.sys
    Image path: watchdog.sys
    Image name: watchdog.sys
    Timestamp:        Tue Jul 14 02:24:10 2009 (4A5BC21A)
    CheckSum:         0000EAAE
    ImageSize:        0000D000
    File type:        2.0 Dll
    InternalName:     watchdog.sys
    OriginalFilename: watchdog.sys
    FileDescription:  Watchdog Driver
88e00000 88eb7000   ndis       (deferred)
    Mapped memory image file: c:\websymbols\ndis.sys\4A5BBF58b7000\ndis.sys
    Image path: ndis.sys
    Image name: ndis.sys
    Timestamp:        Tue Jul 14 02:12:24 2009 (4A5BBF58)
    CheckSum:         000B5E1D
    ImageSize:        000B7000
    File type:        3.6 Driver
    InternalName:     NDIS.SYS
    OriginalFilename: NDIS.SYS
    FileDescription:  NDIS 6.20 driver
88eb7000 88ef5000   NETIO      (deferred)
    Mapped memory image file: c:\websymbols\NETIO.SYS\4A5BBF633e000\NETIO.SYS
    Image path: NETIO.SYS
    Image name: NETIO.SYS
    Timestamp:        Tue Jul 14 02:12:35 2009 (4A5BBF63)
    CheckSum:         000420A0
    ImageSize:        0003E000
    InternalName:     netio.sys
    OriginalFilename: netio.sys
    FileDescription:  Network I/O Subsystem
88ef5000 88f1a000   ksecpkg    (deferred)
    Image path: ksecpkg.sys
    Image name: ksecpkg.sys
    Timestamp:        Fri Dec 11 06:04:22 2009 (4B21C4C6)
    CheckSum:         000305FE
    ImageSize:        00025000
88f1a000 88f22380   vmstorfl   (deferred)
    Mapped memory image file: c:\websymbols\vmstorfl.sys\4A5BC32C8380\vmstorfl.sys
    Image path: vmstorfl.sys
    Image name: vmstorfl.sys
    Timestamp:        Tue Jul 14 02:28:44 2009 (4A5BC32C)
    CheckSum:         0000E080
    ImageSize:        00008380
    InternalName:     vmstorfl.sys
    OriginalFilename: vmstorfl.sys
    FileDescription:  Virtual Storage Filter Driver
88f23000 88f62000   volsnap    (deferred)
    Mapped memory image file: c:\websymbols\volsnap.sys\4A5BBF263f000\volsnap.sys
    Image path: volsnap.sys
    Image name: volsnap.sys
    Timestamp:        Tue Jul 14 02:11:34 2009 (4A5BBF26)
    CheckSum:         0003CB30
    ImageSize:        0003F000
    InternalName:     volsnap.sys
    OriginalFilename: volsnap.sys
    FileDescription:  Volume Shadow Copy Driver
88f62000 88f6a000   spldr      (deferred)
    Image path: spldr.sys
    Image name: spldr.sys
    Timestamp:        Mon May 11 19:13:47 2009 (4A084EBB)
    CheckSum:         0000767D
    ImageSize:        00008000
88f6a000 88f97000   rdyboost   (deferred)
    Mapped memory image file: c:\websymbols\rdyboost.sys\4A5BC19A2d000\rdyboost.sys
    Image path: rdyboost.sys
    Image name: rdyboost.sys
    Timestamp:        Tue Jul 14 02:22:02 2009 (4A5BC19A)
    CheckSum:         0002E815
    ImageSize:        0002D000
    InternalName:     rdyboost.sys
    OriginalFilename: rdyboost.sys
    FileDescription:  ReadyBoost Driver
88f97000 88fa7000   mup        (deferred)
    Mapped memory image file: c:\websymbols\mup.sys\4A5BBFC610000\mup.sys
    Image path: mup.sys
    Image name: mup.sys
    Timestamp:        Tue Jul 14 02:14:14 2009 (4A5BBFC6)
    CheckSum:         00014283
    ImageSize:        00010000
    InternalName:     MUP.SYS
    OriginalFilename: MUP.SYS
    FileDescription:  Multiple UNC Provider Driver
88fa7000 88faf000   hwpolicy   (deferred)
    Mapped memory image file: c:\websymbols\hwpolicy.sys\4A5BBF058000\hwpolicy.sys
    Image path: hwpolicy.sys
    Image name: hwpolicy.sys
    Timestamp:        Tue Jul 14 02:11:01 2009 (4A5BBF05)
    CheckSum:         00006467
    ImageSize:        00008000
    File type:        2.0 Dll
    InternalName:     hwpolicy.sys
    OriginalFilename: hwpolicy.sys
    FileDescription:  Hardware Policy Driver
88faf000 88fe1000   fvevol     (deferred)
    Image path: fvevol.sys
    Image name: fvevol.sys
    Timestamp:        Sat Sep 26 05:24:21 2009 (4ABD7B55)
    CheckSum:         00030A07
    ImageSize:        00032000
88fe1000 88ff2000   disk       (deferred)
    Mapped memory image file: c:\websymbols\disk.sys\4A5BBF2011000\disk.sys
    Image path: disk.sys
    Image name: disk.sys
    Timestamp:        Tue Jul 14 02:11:28 2009 (4A5BBF20)
    CheckSum:         000152A4
    ImageSize:        00011000
    InternalName:     disk.sys
    OriginalFilename: disk.sys
    FileDescription:  PnP Disk Driver
8d600000 8d61f000   cdrom      (deferred)
    Mapped memory image file: c:\websymbols\cdrom.sys\4A5BBF1C1f000\cdrom.sys
    Image path: cdrom.sys
    Image name: cdrom.sys
    Timestamp:        Tue Jul 14 02:11:24 2009 (4A5BBF1C)
    CheckSum:         00029646
    ImageSize:        0001F000
    InternalName:     cdrom.sys
    OriginalFilename: cdrom.sys
    FileDescription:  SCSI CD-ROM Driver
8d61f000 8d626000   Null       (deferred)
    Mapped memory image file: c:\websymbols\Null.SYS\4A5BBF107000\Null.SYS
    Image path: Null.SYS
    Image name: Null.SYS
    Timestamp:        Tue Jul 14 02:11:12 2009 (4A5BBF10)
    CheckSum:         00009AA8
    ImageSize:        00007000
    InternalName:     null.sys
    OriginalFilename: null.sys
    FileDescription:  NULL Driver
8d626000 8d7db000   dump_iaStor   (deferred)
    Image path: dump_iaStor.sys
    Image name: dump_iaStor.sys
    CheckSum:         0006F037
    ImageSize:        001B5000
8d7ee000 8d7f5000   Beep       (deferred)
    Mapped memory image file: c:\websymbols\Beep.SYS\4A5BC6FC7000\Beep.SYS
    Image path: Beep.SYS
    Image name: Beep.SYS
    Timestamp:        Tue Jul 14 02:45:00 2009 (4A5BC6FC)
    CheckSum:         00007FEB
    ImageSize:        00007000
    InternalName:     beep.sys
    OriginalFilename: beep.sys
    FileDescription:  BEEP Driver
8d7f5000 8d7fd000   RDPCDD     (deferred)
    Mapped memory image file: c:\websymbols\RDPCDD.sys\4A5BCAE48000\RDPCDD.sys
    Image path: RDPCDD.sys
    Image name: RDPCDD.sys
    Timestamp:        Tue Jul 14 03:01:40 2009 (4A5BCAE4)
    CheckSum:         00007C47
    ImageSize:        00008000
    InternalName:     RDPCDD.SYS
    OriginalFilename: RDPCDD.SYS
    FileDescription:  RDP Miniport
8dc00000 8dc21000   tunnel     (deferred)
    Mapped memory image file: c:\websymbols\tunnel.sys\4A5BC91B21000\tunnel.sys
    Image path: tunnel.sys
    Image name: tunnel.sys
    Timestamp:        Tue Jul 14 02:54:03 2009 (4A5BC91B)
    CheckSum:         0001AFBA
    ImageSize:        00021000
    InternalName:     tunnel.sys
    OriginalFilename: tunnel.sys
    FileDescription:  Microsoft Tunnel Interface Driver
8dc23000 8dc7d000   afd        (deferred)
    Mapped memory image file: c:\websymbols\afd.sys\4A5BBF625a000\afd.sys
    Image path: afd.sys
    Image name: afd.sys
    Timestamp:        Tue Jul 14 02:12:34 2009 (4A5BBF62)
    CheckSum:         00060D2A
    ImageSize:        0005A000
    InternalName:     afd.sys
    OriginalFilename: afd.sys
    FileDescription:  Ancillary Function Driver for WinSock
8dc7d000 8dcaf000   netbt      (deferred)
    Mapped memory image file: c:\websymbols\netbt.sys\4A5BBF5232000\netbt.sys
    Image path: netbt.sys
    Image name: netbt.sys
    Timestamp:        Tue Jul 14 02:12:18 2009 (4A5BBF52)
    CheckSum:         0003AB4F
    ImageSize:        00032000
    InternalName:     netbt.sys
    OriginalFilename: netbt.sys
    FileDescription:  MBT Transport driver
8dcaf000 8dcb6000   wfplwf     (deferred)
    Mapped memory image file: c:\websymbols\wfplwf.sys\4A5BC90F7000\wfplwf.sys
    Image path: wfplwf.sys
    Image name: wfplwf.sys
    Timestamp:        Tue Jul 14 02:53:51 2009 (4A5BC90F)
    CheckSum:         00002632
    ImageSize:        00007000
    InternalName:     WFPLWF.SYS
    OriginalFilename: WFPLWF.SYS
    FileDescription:  WFP NDIS 6.20 Lightweight Filter Driver
8dcb6000 8dcd5000   pacer      (deferred)
    Mapped memory image file: c:\websymbols\pacer.sys\4A5BC9161f000\pacer.sys
    Image path: pacer.sys
    Image name: pacer.sys
    Timestamp:        Tue Jul 14 02:53:58 2009 (4A5BC916)
    CheckSum:         0001D0F4
    ImageSize:        0001F000
    InternalName:     pacer.sys
    OriginalFilename: pacer.sys
    FileDescription:  QoS Packet Scheduler
8dcd5000 8dce3000   netbios    (deferred)
    Mapped memory image file: c:\websymbols\netbios.sys\4A5BC912e000\netbios.sys
    Image path: netbios.sys
    Image name: netbios.sys
    Timestamp:        Tue Jul 14 02:53:54 2009 (4A5BC912)
    CheckSum:         0000E8AB
    ImageSize:        0000E000
    InternalName:     NETBIOS.SYS
    OriginalFilename: NETBIOS.SYS
    FileDescription:  NetBIOS interface driver
8dce3000 8dcf6000   wanarp     (deferred)
    Mapped memory image file: c:\websymbols\wanarp.sys\4A5BC95613000\wanarp.sys
    Image path: wanarp.sys
    Image name: wanarp.sys
    Timestamp:        Tue Jul 14 02:55:02 2009 (4A5BC956)
    CheckSum:         0001CECE
    ImageSize:        00013000
    InternalName:     WANARP.SYS
    OriginalFilename: WANARP.SYS
    FileDescription:  MS Remote Access and Routing ARP Driver
8dcf6000 8dd06000   termdd     (deferred)
    Mapped memory image file: c:\websymbols\termdd.sys\4A5BCADF10000\termdd.sys
    Image path: termdd.sys
    Image name: termdd.sys
    Timestamp:        Tue Jul 14 03:01:35 2009 (4A5BCADF)
    CheckSum:         000105EC
    ImageSize:        00010000
    InternalName:     termdd.sys
    OriginalFilename: termdd.sys
    FileDescription:  Remote Desktop Server Driver
8dd06000 8dd47000   rdbss      (deferred)
    Mapped memory image file: c:\websymbols\rdbss.sys\4A5BBFD241000\rdbss.sys
    Image path: rdbss.sys
    Image name: rdbss.sys
    Timestamp:        Tue Jul 14 02:14:26 2009 (4A5BBFD2)
    CheckSum:         00047F48
    ImageSize:        00041000
    InternalName:     rdbss.sys
    OriginalFilename: RDBSS.Sys
    FileDescription:  Redirected Drive Buffering SubSystem Driver
8dd47000 8dd51000   nsiproxy   (deferred)
    Mapped memory image file: c:\websymbols\nsiproxy.sys\4A5BBF48a000\nsiproxy.sys
    Image path: nsiproxy.sys
    Image name: nsiproxy.sys
    Timestamp:        Tue Jul 14 02:12:08 2009 (4A5BBF48)
    CheckSum:         0000939B
    ImageSize:        0000A000
    InternalName:     nsiproxy.sys
    OriginalFilename: nsiproxy.sys
    FileDescription:  NSI Proxy
8dd51000 8dd5b000   mssmbios   (deferred)
    Mapped memory image file: c:\websymbols\mssmbios.sys\4A5BC0FDa000\mssmbios.sys
    Image path: mssmbios.sys
    Image name: mssmbios.sys
    Timestamp:        Tue Jul 14 02:19:25 2009 (4A5BC0FD)
    CheckSum:         0000B8F6
    ImageSize:        0000A000
    InternalName:     smbios.sys
    OriginalFilename: smbios.sys
    FileDescription:  System Management BIOS Driver
8dd5b000 8dd67000   discache   (deferred)
    Mapped memory image file: c:\websymbols\discache.sys\4A5BC214c000\discache.sys
    Image path: discache.sys
    Image name: discache.sys
    Timestamp:        Tue Jul 14 02:24:04 2009 (4A5BC214)
    CheckSum:         0000EDA3
    ImageSize:        0000C000
    File type:        2.0 Dll
    InternalName:     syscache.sys
    OriginalFilename: syscache.sys
    FileDescription:  System Indexer/Cache Driver
8dd67000 8ddcb000   csc        (deferred)
    Mapped memory image file: c:\websymbols\csc.sys\4A5BBFFC64000\csc.sys
    Image path: csc.sys
    Image name: csc.sys
    Timestamp:        Tue Jul 14 02:15:08 2009 (4A5BBFFC)
    CheckSum:         0006C9A8
    ImageSize:        00064000
    InternalName:     csc.sys
    OriginalFilename: CSC.Sys
    FileDescription:  Windows Client Side Caching Driver
8ddcb000 8dde3000   dfsc       (deferred)
    Mapped memory image file: c:\websymbols\dfsc.sys\4A5BBFC818000\dfsc.sys
    Image path: dfsc.sys
    Image name: dfsc.sys
    Timestamp:        Tue Jul 14 02:14:16 2009 (4A5BBFC8)
    CheckSum:         0001CA43
    ImageSize:        00018000
    InternalName:     dfsclient.sys
    OriginalFilename: dfsclient.sys
    FileDescription:  DFS Namespace Client Driver
8dde3000 8ddf1000   blbdrive   (deferred)
    Mapped memory image file: c:\websymbols\blbdrive.sys\4A5BC1D8e000\blbdrive.sys
    Image path: blbdrive.sys
    Image name: blbdrive.sys
    Timestamp:        Tue Jul 14 02:23:04 2009 (4A5BC1D8)
    CheckSum:         00015D28
    ImageSize:        0000E000
    InternalName:     blbdrive.sys
    OriginalFilename: blbdrive.sys
    FileDescription:  BLB Drive Driver
8e028000 8e033000   Msfs       (deferred)
    Mapped memory image file: c:\websymbols\Msfs.SYS\4A5BBF1Eb000\Msfs.SYS
    Image path: Msfs.SYS
    Image name: Msfs.SYS
    Timestamp:        Tue Jul 14 02:11:26 2009 (4A5BBF1E)
    CheckSum:         0001417A
    ImageSize:        0000B000
    InternalName:     MSFS.SYS
    OriginalFilename: MSFS.SYS
    FileDescription:  Mailslot driver
8e033000 8e041000   Npfs       (deferred)
    Mapped memory image file: c:\websymbols\Npfs.SYS\4A5BBF23e000\Npfs.SYS
    Image path: Npfs.SYS
    Image name: Npfs.SYS
    Timestamp:        Tue Jul 14 02:11:31 2009 (4A5BBF23)
    CheckSum:         00008C57
    ImageSize:        0000E000
    InternalName:     npfs.sys
    OriginalFilename: npfs.sys
    FileDescription:  NPFS Driver
8e041000 8e18a000   tcpip      (deferred)
    Mapped memory image file: c:\websymbols\tcpip.sys\4C15A3DB149000\tcpip.sys
    Image path: tcpip.sys
    Image name: tcpip.sys
    Timestamp:        Mon Jun 14 06:36:59 2010 (4C15A3DB)
    CheckSum:         00140411
    ImageSize:        00149000
    File version:     6.1.7600.16610
    Product version:  6.1.7600.16610
    InternalName:     tcpip.sys
    OriginalFilename: tcpip.sys
    ProductVersion:   6.1.7600.16610
    FileVersion:      6.1.7600.16610 (win7_gdr.100613-1554)
    FileDescription:  TCP/IP Driver
8e18a000 8e1bb000   fwpkclnt   (deferred)
    Mapped memory image file: c:\websymbols\fwpkclnt.sys\4A5BBF4331000\fwpkclnt.sys
    Image path: fwpkclnt.sys
    Image name: fwpkclnt.sys
    Timestamp:        Tue Jul 14 02:12:03 2009 (4A5BBF43)
    CheckSum:         0002E7FF
    ImageSize:        00031000
    File type:        2.0 Dll
    InternalName:     fwpkclnt.sys
    OriginalFilename: fwpkclnt.sys
    FileDescription:  FWP/IPsec Kernel-Mode API
8e1bb000 8e1d2000   tdx        (deferred)
    Mapped memory image file: c:\websymbols\tdx.sys\4A5BBF4A17000\tdx.sys
    Image path: tdx.sys
    Image name: tdx.sys
    Timestamp:        Tue Jul 14 02:12:10 2009 (4A5BBF4A)
    CheckSum:         0001DB35
    ImageSize:        00017000
    InternalName:     tdx.sys
    OriginalFilename: tdx.sys
    FileDescription:  TDI Translation Driver
8e1d2000 8e1dd000   TDI        (deferred)
    Mapped memory image file: c:\websymbols\TDI.SYS\4A5BBF4Cb000\TDI.SYS
    Image path: TDI.SYS
    Image name: TDI.SYS
    Timestamp:        Tue Jul 14 02:12:12 2009 (4A5BBF4C)
    CheckSum:         000082C1
    ImageSize:        0000B000
    InternalName:     tdi.sys
    OriginalFilename: tdi.sys
    FileDescription:  TDI Wrapper
8e1dd000 8e1ef000   intelppm   (deferred)
    Mapped memory image file: c:\websymbols\intelppm.sys\4A5BBF0712000\intelppm.sys
    Image path: intelppm.sys
    Image name: intelppm.sys
    CheckSum:         00013147
    ImageSize:        00012000
    InternalName:     intelppm.sys
    OriginalFilename: intelppm.sys
    FileDescription:  Processor Device Driver
8ee22000 8ee66000   usbhub     (deferred)
    Mapped memory image file: c:\websymbols\usbhub.sys\4A5BC8A644000\usbhub.sys
    Image path: usbhub.sys
    Image name: usbhub.sys
    Timestamp:        Tue Jul 14 02:52:06 2009 (4A5BC8A6)
    CheckSum:         000498A9
    ImageSize:        00044000
    File type:        2.0 Dll
    InternalName:     usbhub.sys
    OriginalFilename: usbhub.sys
    FileDescription:  Default Hub Driver for USB
8ee66000 8ee70000   flpydisk   (deferred)
    Mapped memory image file: c:\websymbols\flpydisk.sys\4A5BC729a000\flpydisk.sys
    Image path: flpydisk.sys
    Image name: flpydisk.sys
    Timestamp:        Tue Jul 14 02:45:45 2009 (4A5BC729)
    CheckSum:         00007FA1
    ImageSize:        0000A000
    InternalName:     floppy.sys
    OriginalFilename: floppy.sys
    FileDescription:  Floppy Driver
8ee70000 8ee81000   NDProxy    (deferred)
    Mapped memory image file: c:\websymbols\NDProxy.SYS\4A5BC93311000\NDProxy.SYS
    Image path: NDProxy.SYS
    Image name: NDProxy.SYS
    Timestamp:        Tue Jul 14 02:54:27 2009 (4A5BC933)
    CheckSum:         0000D6CA
    ImageSize:        00011000
    InternalName:     ndproxy.sys
    OriginalFilename: ndproxy.sys
    FileDescription:  NDIS Proxy
8ee81000 8ee94000   rspndr     (deferred)
    Mapped memory image file: c:\websymbols\rspndr.sys\4A5BC8F013000\rspndr.sys
    Image path: rspndr.sys
    Image name: rspndr.sys
    Timestamp:        Tue Jul 14 02:53:20 2009 (4A5BC8F0)
    CheckSum:         00017A94
    ImageSize:        00013000
    InternalName:     RSPNDR.SYS
    OriginalFilename: RSPNDR.SYS
    FileDescription:  Link-Layer Topology Responder Driver for NDIS 6
8ee94000 8ef19000   HTTP       (deferred)
    Mapped memory image file: c:\websymbols\HTTP.sys\4A5BBF7585000\HTTP.sys
    Image path: HTTP.sys
    Image name: HTTP.sys
    Timestamp:        Tue Jul 14 02:12:53 2009 (4A5BBF75)
    CheckSum:         0008D29E
    ImageSize:        00085000
    InternalName:     http.sys
    OriginalFilename: http.sys
    FileDescription:  HTTP Protocol Stack
8ef19000 8ef32000   bowser     (deferred)
    Mapped memory image file: c:\websymbols\bowser.sys\4A5BBFCD19000\bowser.sys
    Image path: bowser.sys
    Image name: bowser.sys
    Timestamp:        Tue Jul 14 02:14:21 2009 (4A5BBFCD)
    CheckSum:         0001AFC8
    ImageSize:        00019000
    InternalName:     browser.sys
    OriginalFilename: browser.sys
    FileDescription:  NT Lan Manager Datagram Receiver Driver
8ef32000 8ef44000   mpsdrv     (deferred)
    Mapped memory image file: c:\websymbols\mpsdrv.sys\4A5BC8D412000\mpsdrv.sys
    Image path: mpsdrv.sys
    Image name: mpsdrv.sys
    Timestamp:        Tue Jul 14 02:52:52 2009 (4A5BC8D4)
    CheckSum:         00019354
    ImageSize:        00012000
    InternalName:     mpsdrv.sys
    OriginalFilename: mpsdrv.sys
    FileDescription:  Microsoft Protection Service Driver
8ef44000 8ef67000   mrxsmb     (deferred)
    Mapped memory image file: c:\websymbols\mrxsmb.sys\4B88CA7223000\mrxsmb.sys
    Image path: mrxsmb.sys
    Image name: mrxsmb.sys
    Timestamp:        Sat Feb 27 09:32:02 2010 (4B88CA72)
    CheckSum:         0001E92E
    ImageSize:        00023000
    File version:     6.1.7600.16539
    Product version:  6.1.7600.16539
    InternalName:     MRxSmb.sys
    OriginalFilename: MRXSMB.Sys
    ProductVersion:   6.1.7600.16539
    FileVersion:      6.1.7600.16539 (win7_gdr.100226-1909)
    FileDescription:  Windows NT SMB Minirdr
8ef67000 8efa2000   mrxsmb10   (deferred)
    Mapped memory image file: c:\websymbols\mrxsmb10.sys\4B88CA853b000\mrxsmb10.sys
    Image path: mrxsmb10.sys
    Image name: mrxsmb10.sys
    Timestamp:        Sat Feb 27 09:32:21 2010 (4B88CA85)
    CheckSum:         0003CA9C
    ImageSize:        0003B000
    InternalName:     MRxSmb0.sys
    OriginalFilename: MRXSMB0.Sys
    FileDescription:  Longhorn SMB Downlevel SubRdr
8efa2000 8efbd000   mrxsmb20   (deferred)
    Mapped memory image file: c:\websymbols\mrxsmb20.sys\4B88CA7B1b000\mrxsmb20.sys
    Image path: mrxsmb20.sys
    Image name: mrxsmb20.sys
    Timestamp:        Sat Feb 27 09:32:11 2010 (4B88CA7B)
    CheckSum:         00023583
    ImageSize:        0001B000
    InternalName:     MRxSmb20.sys
    OriginalFilename: MRXSMB20.Sys
    FileDescription:  Longhorn SMB 2.0 Redirector
8fc00000 8fc1f000   HDAudBus   (deferred)
    Mapped memory image file: c:\websymbols\HDAudBus.sys\4A5BC85F1f000\HDAudBus.sys
    Image path: HDAudBus.sys
    Image name: HDAudBus.sys
    Timestamp:        Tue Jul 14 02:50:55 2009 (4A5BC85F)
    CheckSum:         0002430E
    ImageSize:        0001F000
    File type:        3.9 Driver
    InternalName:     hdaudbus.sys
    OriginalFilename: hdaudbus.sys
    FileDescription:  High Definition Audio Bus Driver
8fc29000 906a6dc0   nvlddmkm   (deferred)
    Image path: nvlddmkm.sys
    Image name: nvlddmkm.sys
    Timestamp:        Sat Jul 10 00:15:14 2010 (4C379162)
    CheckSum:         00A837FE
    ImageSize:        00A7DDC0
906a7000 906a8040   nvBridge   (deferred)
    Image path: nvBridge.kmd
    Image name: nvBridge.kmd
    Timestamp:        Sat Jul 10 00:10:11 2010 (4C379033)
    CheckSum:         00006687
    ImageSize:        00001040
906a9000 90760000   dxgkrnl    (deferred)
    Image path: dxgkrnl.sys
    Image name: dxgkrnl.sys
    Timestamp:        Fri Oct 02 03:48:33 2009 (4AC54DE1)
    CheckSum:         000B20B6
    ImageSize:        000B7000
90760000 90799000   dxgmms1    (deferred)
    Mapped memory image file: c:\websymbols\dxgmms1.sys\4A5BC26539000\dxgmms1.sys
    Image path: dxgmms1.sys
    Image name: dxgmms1.sys
    Timestamp:        Tue Jul 14 02:25:25 2009 (4A5BC265)
    CheckSum:         0004052D
    ImageSize:        00039000
    InternalName:     dxgmms1.sys
    OriginalFilename: dxgmms1.sys
    FileDescription:  DirectX Graphics MMS
90799000 907a4000   usbuhci    (deferred)
    Mapped memory image file: c:\websymbols\usbuhci.sys\4A5BC86Eb000\usbuhci.sys
    Image path: usbuhci.sys
    Image name: usbuhci.sys
    Timestamp:        Tue Jul 14 02:51:10 2009 (4A5BC86E)
    CheckSum:         0000F00A
    ImageSize:        0000B000
    File type:        2.0 Dll
    InternalName:     USBUHCI.sys
    OriginalFilename: USBUHCI.sys
    FileDescription:  UHCI USB Miniport Driver
907a4000 907ef000   USBPORT    (deferred)
    Mapped memory image file: c:\websymbols\USBPORT.SYS\4A5BC8714b000\USBPORT.SYS
    Image path: USBPORT.SYS
    Image name: USBPORT.SYS
    Timestamp:        Tue Jul 14 02:51:13 2009 (4A5BC871)
    CheckSum:         0004BC3B
    ImageSize:        0004B000
    File type:        2.0 Dll
    InternalName:     usbport.sys
    OriginalFilename: usbport.sys
    FileDescription:  USB 1.1 & 2.0 Port Driver
907ef000 907fe000   usbehci    (deferred)
    Mapped memory image file: c:\websymbols\usbehci.sys\4A5BC872f000\usbehci.sys
    Image path: usbehci.sys
    Image name: usbehci.sys
    Timestamp:        Tue Jul 14 02:51:14 2009 (4A5BC872)
    CheckSum:         000178B0
    ImageSize:        0000F000
    File type:        2.0 Dll
    InternalName:     USBEHCI.sys
    OriginalFilename: USBEHCI.sys
    FileDescription:  EHCI eUSB Miniport Driver
93418000 9345d000   Rt86win7   (deferred)
    Image path: Rt86win7.sys
    Image name: Rt86win7.sys
    Timestamp:        Wed Jun 23 12:10:23 2010 (4C21CF7F)
    CheckSum:         0004C803
    ImageSize:        00045000
9345d000 93489000   1394ohci   (deferred)
    Mapped memory image file: c:\websymbols\1394ohci.sys\4A5BC89F2c000\1394ohci.sys
    Image path: 1394ohci.sys
    Image name: 1394ohci.sys
    Timestamp:        Tue Jul 14 02:51:59 2009 (4A5BC89F)
    CheckSum:         0003419B
    ImageSize:        0002C000
    InternalName:     1394ohci.sys
    OriginalFilename: 1394ohci.sys
    FileDescription:  1394 OpenHCI Driver
93489000 93494000   fdc        (deferred)
    Mapped memory image file: c:\websymbols\fdc.sys\4A5BC729b000\fdc.sys
    Image path: fdc.sys
    Image name: fdc.sys
    CheckSum:         000095E6
    ImageSize:        0000B000
    InternalName:     fdc.sys
    OriginalFilename: fdc.sys
    FileDescription:  Floppy Disk Controller Driver
93494000 934ac000   i8042prt   (deferred)
    Mapped memory image file: c:\websymbols\i8042prt.sys\4A5BBF1B18000\i8042prt.sys
    Image path: i8042prt.sys
    Image name: i8042prt.sys
    Timestamp:        Tue Jul 14 02:11:23 2009 (4A5BBF1B)
    CheckSum:         000192C3
    ImageSize:        00018000
    InternalName:     i8042prt.sys
    OriginalFilename: i8042prt.sys
    FileDescription:  i8042 Port Driver
934ac000 934b9000   kbdclass   (deferred)
    Mapped memory image file: c:\websymbols\kbdclass.sys\4A5BBF13d000\kbdclass.sys
    Image path: kbdclass.sys
    Image name: kbdclass.sys
    CheckSum:         00014037
    ImageSize:        0000D000
    InternalName:     kbdclass.sys
    OriginalFilename: kbdclass.sys
    FileDescription:  Keyboard Class Driver
934b9000 934c2000   wmiacpi    (deferred)
    Mapped memory image file: c:\websymbols\wmiacpi.sys\4A5BC0F49000\wmiacpi.sys
    Image path: wmiacpi.sys
    Image name: wmiacpi.sys
    Timestamp:        Tue Jul 14 02:19:16 2009 (4A5BC0F4)
    CheckSum:         000098C8
    ImageSize:        00009000
    InternalName:     wmiacpi.sys
    OriginalFilename: wmiacpi.sys
    FileDescription:  Windows Management Interface for ACPI
934c2000 934cf000   CompositeBus   (deferred)
    Mapped memory image file: c:\websymbols\CompositeBus.sys\4A5BC716d000\CompositeBus.sys
    Image path: CompositeBus.sys
    Image name: CompositeBus.sys
    Timestamp:        Tue Jul 14 02:45:26 2009 (4A5BC716)
    CheckSum:         0000C578
    ImageSize:        0000D000
    File type:        2.0 Dll
    InternalName:     compositebus.sys
    OriginalFilename: compositebus.sys
    FileDescription:  Multi-Transport Composite Bus Enumerator
934cf000 934e1000   AgileVpn   (deferred)
    Mapped memory image file: c:\websymbols\AgileVpn.sys\4A5BC95412000\AgileVpn.sys
    Image path: AgileVpn.sys
    Image name: AgileVpn.sys
    Timestamp:        Tue Jul 14 02:55:00 2009 (4A5BC954)
    CheckSum:         0001458A
    ImageSize:        00012000
    InternalName:     agilevpn.sys
    OriginalFilename: agilevpn.sys
    FileDescription:  RAS Agile Vpn Miniport Call Manager
934e1000 934f9000   rasl2tp    (deferred)
    Mapped memory image file: c:\websymbols\rasl2tp.sys\4A5BC93918000\rasl2tp.sys
    Image path: rasl2tp.sys
    Image name: rasl2tp.sys
    Timestamp:        Tue Jul 14 02:54:33 2009 (4A5BC939)
    CheckSum:         00021F6B
    ImageSize:        00018000
    InternalName:     rasl2tp.sys
    OriginalFilename: rasl2tp.sys
    FileDescription:  RAS L2TP mini-port/call-manager driver
934f9000 93504000   ndistapi   (deferred)
    Mapped memory image file: c:\websymbols\ndistapi.sys\4A5BC930b000\ndistapi.sys
    Image path: ndistapi.sys
    Image name: ndistapi.sys
    Timestamp:        Tue Jul 14 02:54:24 2009 (4A5BC930)
    CheckSum:         0001309D
    ImageSize:        0000B000
    InternalName:     NDISTAPI.SYS
    OriginalFilename: NDISTAPI.SYS
    FileDescription:  NDIS 3.0 connection wrapper driver
93504000 93526000   ndiswan    (deferred)
    Mapped memory image file: c:\websymbols\ndiswan.sys\4A5BC93A22000\ndiswan.sys
    Image path: ndiswan.sys
    Image name: ndiswan.sys
    Timestamp:        Tue Jul 14 02:54:34 2009 (4A5BC93A)
    CheckSum:         0001D342
    ImageSize:        00022000
    InternalName:     NDISWAN.SYS
    OriginalFilename: NDISWAN.SYS
    FileDescription:  MS PPP Framing Driver (Strong Encryption)
93526000 9353e000   raspppoe   (deferred)
    Mapped memory image file: c:\websymbols\raspppoe.sys\4A5BC94D18000\raspppoe.sys
    Image path: raspppoe.sys
    Image name: raspppoe.sys
    Timestamp:        Tue Jul 14 02:54:53 2009 (4A5BC94D)
    CheckSum:         00020761
    ImageSize:        00018000
    InternalName:     raspppoe.sys
    OriginalFilename: raspppoe.sys
    FileDescription:  RAS PPPoE mini-port/call-manager driver
9353e000 93555000   raspptp    (deferred)
    Mapped memory image file: c:\websymbols\raspptp.sys\4A5BC94717000\raspptp.sys
    Image path: raspptp.sys
    Image name: raspptp.sys
    Timestamp:        Tue Jul 14 02:54:47 2009 (4A5BC947)
    CheckSum:         00016CEC
    ImageSize:        00017000
    InternalName:     RASPPTP.SYS
    OriginalFilename: RASPPTP.SYS
    FileDescription:  Peer-to-Peer Tunneling Protocol
93555000 9356c000   rassstp    (deferred)
    Mapped memory image file: c:\websymbols\rassstp.sys\4A5BC95117000\rassstp.sys
    Image path: rassstp.sys
    Image name: rassstp.sys
    Timestamp:        Tue Jul 14 02:54:57 2009 (4A5BC951)
    CheckSum:         0001BBF6
    ImageSize:        00017000
    InternalName:     rassstp.sys
    OriginalFilename: rassstp.sys
    FileDescription:  RAS SSTP Miniport Call Manager
9356c000 93576000   rdpbus     (deferred)
    Mapped memory image file: c:\websymbols\rdpbus.sys\4A5BCB20a000\rdpbus.sys
    Image path: rdpbus.sys
    Image name: rdpbus.sys
    Timestamp:        Tue Jul 14 03:02:40 2009 (4A5BCB20)
    CheckSum:         000052DD
    ImageSize:        0000A000
    File type:        3.0 Driver
    InternalName:     RDPBUS.SYS
    OriginalFilename: RDPBUS.SYS
    FileDescription:  Microsoft RDP Bus Device driver
93576000 93583000   mouclass   (deferred)
    Mapped memory image file: c:\websymbols\mouclass.sys\4A5BBF13d000\mouclass.sys
    Image path: mouclass.sys
    Image name: mouclass.sys
    CheckSum:         00017B8D
    ImageSize:        0000D000
    InternalName:     mouclass.sys
    OriginalFilename: mouclass.sys
    FileDescription:  Mouse Class Driver
93583000 93584380   swenum     (deferred)
    Mapped memory image file: c:\websymbols\swenum.sys\4A5BC7041380\swenum.sys
    Image path: swenum.sys
    Image name: swenum.sys
    Timestamp:        Tue Jul 14 02:45:08 2009 (4A5BC704)
    CheckSum:         000042B5
    ImageSize:        00001380
    InternalName:     swenum.sys
    OriginalFilename: swenum.sys
    FileDescription:  Plug and Play Software Device Enumerator
93585000 935b9000   ks         (deferred)
    Mapped memory image file: c:\websymbols\ks.sys\4A5BC70934000\ks.sys
    Image path: ks.sys
    Image name: ks.sys
    Timestamp:        Tue Jul 14 02:45:13 2009 (4A5BC709)
    CheckSum:         0003931B
    ImageSize:        00034000
    InternalName:     ks.sys
    OriginalFilename: ks.sys
    FileDescription:  Kernel CSA Library
935b9000 935c7000   umbus      (deferred)
    Mapped memory image file: c:\websymbols\umbus.sys\4A5BC88Ae000\umbus.sys
    Image path: umbus.sys
    Image name: umbus.sys
    Timestamp:        Tue Jul 14 02:51:38 2009 (4A5BC88A)
    CheckSum:         00016EA1
    ImageSize:        0000E000
    File type:        2.0 Dll
    InternalName:     umbus.sys
    OriginalFilename: umbus.sys
    FileDescription:  User-Mode Bus Enumerator
95800000 9581b000   luafv      (deferred)
    Mapped memory image file: c:\websymbols\luafv.sys\4A5BC0201b000\luafv.sys
    Image path: luafv.sys
    Image name: luafv.sys
    Timestamp:        Tue Jul 14 02:15:44 2009 (4A5BC020)
    CheckSum:         00017576
    ImageSize:        0001B000
    InternalName:     luafv.sys
    OriginalFilename: luafv.sys
    FileDescription:  LUA File Virtualization Filter Driver
9581b000 95835000   WudfPf     (deferred)
    Mapped memory image file: c:\websymbols\WudfPf.sys\4A5BC8351a000\WudfPf.sys
    Image path: WudfPf.sys
    Image name: WudfPf.sys
    Timestamp:        Tue Jul 14 02:50:13 2009 (4A5BC835)
    CheckSum:         0002104B
    ImageSize:        0001A000
    InternalName:     WUDFPf.sys
    OriginalFilename: WUDFPf.sys
    FileDescription:  Windows Driver Foundation - User-mode Driver Framework Platform Driver
9583c000 95b3c980   RTKVHDA    (deferred)
    Image path: RTKVHDA.sys
    Image name: RTKVHDA.sys
    Timestamp:        Wed Jul 28 13:00:28 2010 (4C4FFFBC)
    CheckSum:         003058D6
    ImageSize:        00300980
95b3d000 95b6c000   portcls    (deferred)
    Mapped memory image file: c:\websymbols\portcls.sys\4A5BC8642f000\portcls.sys
    Image path: portcls.sys
    Image name: portcls.sys
    Timestamp:        Tue Jul 14 02:51:00 2009 (4A5BC864)
    CheckSum:         0003B28B
    ImageSize:        0002F000
    InternalName:     portcls.sys
    OriginalFilename: portcls.sys
    FileDescription:  Port Class (Class Driver for Port/Miniport Devices)
95b6c000 95b85000   drmk       (deferred)
    Image path: drmk.sys
    Image name: drmk.sys
    Timestamp:        Tue Jul 14 03:36:05 2009 (4A5BD2F5)
    CheckSum:         0001D8FD
    ImageSize:        00019000
95b85000 95b92000   crashdmp   (deferred)
    Mapped memory image file: c:\websymbols\crashdmp.sys\4A5BC72Ed000\crashdmp.sys
    Image path: crashdmp.sys
    Image name: crashdmp.sys
    CheckSum:         00010FCB
    ImageSize:        0000D000
    InternalName:     crashdmp.sys
    OriginalFilename: crashdmp.sys
    FileDescription:  Crash Dump Driver
95b92000 95b9c000   Dxapi      (deferred)
    Mapped memory image file: c:\websymbols\Dxapi.sys\4A5BC265a000\Dxapi.sys
    Image path: Dxapi.sys
    Image name: Dxapi.sys
    CheckSum:         0000CBB7
    ImageSize:        0000A000
    InternalName:     dxapi.sys
    OriginalFilename: dxapi.sys
    FileDescription:  DirectX API Driver
95b9c000 95bad000   dump_dumpfve   (deferred)
    Mapped memory image file: c:\websymbols\dumpfve.sys\4A5BBF6F11000\dumpfve.sys
    Image path: dump_dumpfve.sys
    Image name: dump_dumpfve.sys
    Timestamp:        Tue Jul 14 02:12:47 2009 (4A5BBF6F)
    CheckSum:         000106FF
    ImageSize:        00011000
    InternalName:     dumpfve.sys
    OriginalFilename: dumpfve.sys
    FileDescription:  Bitlocker Drive Encryption Crashdump Filter
95bad000 95bb8000   hidusb     (deferred)
    Mapped memory image file: c:\websymbols\hidusb.sys\4A5BC868b000\hidusb.sys
    Image path: hidusb.sys
    Image name: hidusb.sys
    Timestamp:        Tue Jul 14 02:51:04 2009 (4A5BC868)
    CheckSum:         0000DFCF
    ImageSize:        0000B000
    File type:        2.0 Dll
    InternalName:     HIDUSB.SYS
    OriginalFilename: HIDUSB.SYS
    FileDescription:  USB Miniport Driver for Input Devices
95bb8000 95bcb000   HIDCLASS   (deferred)
    Mapped memory image file: c:\websymbols\HIDCLASS.SYS\4A5BC86513000\HIDCLASS.SYS
    Image path: HIDCLASS.SYS
    Image name: HIDCLASS.SYS
    Timestamp:        Tue Jul 14 02:51:01 2009 (4A5BC865)
    CheckSum:         000128CB
    ImageSize:        00013000
    File type:        2.0 Dll
    InternalName:     hidclass.sys
    OriginalFilename: hidclass.sys
    FileDescription:  Hid Class Library
95bcb000 95bd1480   HIDPARSE   (deferred)
    Mapped memory image file: c:\websymbols\HIDPARSE.SYS\4A5BC8636480\HIDPARSE.SYS
    Image path: HIDPARSE.SYS
    Image name: HIDPARSE.SYS
    Timestamp:        Tue Jul 14 02:50:59 2009 (4A5BC863)
    CheckSum:         00007748
    ImageSize:        00006480
    File type:        2.0 Dll
    InternalName:     hidparse.sys
    OriginalFilename: hidparse.sys
    FileDescription:  Hid Parsing Library
95bd2000 95bd3700   USBD       (deferred)
    Mapped memory image file: c:\websymbols\USBD.SYS\4A5BC8691700\USBD.SYS
    Image path: USBD.SYS
    Image name: USBD.SYS
    Timestamp:        Tue Jul 14 02:51:05 2009 (4A5BC869)
    CheckSum:         0000E24C
    ImageSize:        00001700
    File type:        2.0 Dll
    InternalName:     usbd.sys
    OriginalFilename: usbd.sys
    FileDescription:  Universal Serial Bus Driver
95bd4000 95bdf000   mouhid     (deferred)
    Mapped memory image file: c:\websymbols\mouhid.sys\4A5BC704b000\mouhid.sys
    Image path: mouhid.sys
    Image name: mouhid.sys
    CheckSum:         0000BAF0
    ImageSize:        0000B000
    File type:        2.0 Dll
    InternalName:     mouhid.sys
    OriginalFilename: mouhid.sys
    FileDescription:  HID Mouse Filter Driver
95bdf000 95bea000   monitor    (deferred)
    Mapped memory image file: c:\websymbols\monitor.sys\4A5BC286b000\monitor.sys
    Image path: monitor.sys
    Image name: monitor.sys
    Timestamp:        Tue Jul 14 02:25:58 2009 (4A5BC286)
    CheckSum:         000112CF
    ImageSize:        0000B000
    InternalName:     monitor.sys
    OriginalFilename: monitor.sys
    FileDescription:  Monitor Driver
95bea000 95bfa000   lltdio     (deferred)
    Mapped memory image file: c:\websymbols\lltdio.sys\4A5BC8EE10000\lltdio.sys
    Image path: lltdio.sys
    Image name: lltdio.sys
    Timestamp:        Tue Jul 14 02:53:18 2009 (4A5BC8EE)
    CheckSum:         000134EE
    ImageSize:        00010000
    InternalName:     LLTDIO.SYS
    OriginalFilename: LLTDIO.SYS
    FileDescription:  Link-Layer Topology Mapper I/O Driver
95bfa000 95bfd580   cpuz134_x32   (deferred)
    Image path: cpuz134_x32.sys
    Image name: cpuz134_x32.sys
    Timestamp:        Fri Jul 09 14:18:04 2010 (4C37056C)
    CheckSum:         0000B396
    ImageSize:        00003580
96220000 9646a000   win32k     (deferred)
    Mapped memory image file: c:\websymbols\win32k.sys\4C1C425A24a000\win32k.sys
    Image path: win32k.sys
    Image name: win32k.sys
    Timestamp:        Sat Jun 19 07:06:50 2010 (4C1C425A)
    CheckSum:         00238145
    ImageSize:        0024A000
    InternalName:     win32k.sys
    OriginalFilename: win32k.sys
    FileDescription:  Multi-User Win32 Driver
96480000 96489000   TSDDD      (deferred)
    Mapped memory image file: c:\websymbols\TSDDD.dll\4A5BCAE49000\TSDDD.dll
    Image path: TSDDD.dll
    Image name: TSDDD.dll
    CheckSum:         00012D61
    ImageSize:        00009000
    InternalName:     framebuf.dll
    OriginalFilename: framebuf.dll
    FileDescription:  Framebuffer Display Driver
964b0000 964ce000   cdd        (deferred)
    Mapped memory image file: c:\websymbols\cdd.dll\4A5BD9921e000\cdd.dll
    Image path: cdd.dll
    Image name: cdd.dll
    Timestamp:        Tue Jul 14 04:04:18 2009 (4A5BD992)
    CheckSum:         0001F9C9
    ImageSize:        0001E000
    InternalName:     cdd.dll
    OriginalFilename: cdd.dll
    FileDescription:  Canonical Display Driver
9b60a000 9b6a1000   peauth     (deferred)
    Image path: peauth.sys
    Image name: peauth.sys
    Timestamp:        Tue Jul 14 03:35:44 2009 (4A5BD2E0)
    CheckSum:         00097D35
    ImageSize:        00097000
9b6a1000 9b6ab000   secdrv     (deferred)
    Image path: secdrv.SYS
    Image name: secdrv.SYS
    Timestamp:        Wed Sep 13 16:18:32 2006 (45080528)
    CheckSum:         0000F9E8
    ImageSize:        0000A000
9b6ab000 9b6cc000   srvnet     (deferred)
    Mapped memory image file: c:\websymbols\srvnet.sys\4C20242D21000\srvnet.sys
    Image path: srvnet.sys
    Image name: srvnet.sys
    Timestamp:        Tue Jun 22 05:47:09 2010 (4C20242D)
    CheckSum:         000218E4
    ImageSize:        00021000
    File version:     6.1.7600.16619
    Product version:  6.1.7600.16619
    InternalName:     SRVNET.SYS
    OriginalFilename: SRVNET.SYS
    ProductVersion:   6.1.7600.16619
    FileVersion:      6.1.7600.16619 (win7_gdr.100621-1505)
    FileDescription:  Server Network driver
9b6cc000 9b6d9000   tcpipreg   (deferred)
    Mapped memory image file: c:\websymbols\tcpipreg.sys\4A5BC926d000\tcpipreg.sys
    Image path: tcpipreg.sys
    Image name: tcpipreg.sys
    Timestamp:        Tue Jul 14 02:54:14 2009 (4A5BC926)
    CheckSum:         00012637
    ImageSize:        0000D000
    File type:        1.0 App
    InternalName:     tcpipreg.sys
    OriginalFilename: tcpipreg.sys
    FileDescription:  TCP/IP Registry Compatibility Driver
9b6d9000 9b728000   srv2       (deferred)
    Mapped memory image file: c:\websymbols\srv2.sys\4C2024374f000\srv2.sys
    Image path: srv2.sys
    Image name: srv2.sys
    Timestamp:        Tue Jun 22 05:47:19 2010 (4C202437)
    CheckSum:         0004DEF7
    ImageSize:        0004F000
    InternalName:     SRV2.SYS
    OriginalFilename: SRV2.SYS
    FileDescription:  Smb 2.0 Server driver
9b728000 9b779000   srv        (deferred)
    Mapped memory image file: c:\websymbols\srv.sys\4C20244451000\srv.sys
    Image path: srv.sys
    Image name: srv.sys
    Timestamp:        Tue Jun 22 05:47:32 2010 (4C202444)
    CheckSum:         0005993A
    ImageSize:        00051000
    InternalName:     SRV.SYS
    OriginalFilename: SRV.SYS
    FileDescription:  Server driver
Unloaded modules:
8efbd000 8efd5000   parport.sys
    Checksum:  00000000
88ff2000 88fff000   crashdmp.sys
    Checksum:  00000000
8d628000 8d7dd000   dump_iaStor.
    Checksum:  00000000
8d7dd000 8d7ee000   dump_dumpfve
    Checksum:  00000000
#54
So how has it been since updating the J-Micron driver? Good?
#55
it was good.. until..
dammit, was really thinking it was working...
#56
Open an elevated command prompt. Type the following then press enter:
chkdsk /r
If that doesn't fix it, then test the memory overnight with Memtest86+.
If any errors shown, replace the RAM.
If no errors shown, then the hard drive is likely faulty. <<< (This is probably the reason.)
You could try updating the bios to newest, from Gigabyte's site but that is only for good measure. Very unlikely to help at all.
yeah i typed tht in, it will do it next time i restart comp....
HDD faulty? could it not be a bad install of windows or anything?
#58
Well, restart the pc and let it get on it. It will be a long while until it completes.
No, not bad install. All of your drivers are now in perfect condition which leaves only 2 possibilities.
Faulty/corrupt hdd or bad ram.
#59
*2 hours after last post* DONE!!!! ok, so, am i waiting for a BSOD?
#60
ok, so now Memtest... if no errors, then i shall need a new harddrive. Tis a shame, its my newest piece...
btw, so no matter what results i get... i will need to replace a piece of hardware?
Lucky i have a years warranty of everything i got.....
