Windows 7 BSOD memory management
steffan
I have been receiving multiple stop errors (memory Management) lately and its getting really annoying now. If you guys would kindly help me out trying to solve my issue thanks.
Motherboard: ASUS p8h67-m2/tsp/si
Power Supply OCZ xstream-pro 700Watts
RAM: Corsair 8gb DDR3 1066MHZ(Lowered the speed to increase stability) XMS3 dual channel memory kit rating on the ram 9-9-9-24
Processor: i3-2120 lga 1155 3.30ghz
Graphic Card: ASUS GTX 650ti
I did memtest86+ overnight for 9 hours and 20 minutes no errors 7 passes did prime95 small failed after 7 hours in to the test did blend failed after 4 hours in and sometimes fails after clicking start torture test. CPU average temperature is around 50-65 on full load never goes over 70
  • 032813-18922-01.rar
usasma
Fantastic Member
If Prime95 failed, it's either your memory, CPU, or memory controller (which is on the CPU in an i-series processor).
Try the CPU stress tests at this link: Additional Hardware Diagnostics
If a couple of those tests pass, then run Prime95 Blend test on each stick of RAM individually. Then try one of the sticks that passed in each of the slots (in order to rule out the slots being bad).
Please provide this information so we can provide a complete analysis: http://windows7forums.com/blue-screen-death-bsod/38837-how-ask-help-bsod-problem.html
If that doesn't isolate the problem, they try these 2 things:
- run all the hardware diagnostics from here: http://www.carrona.org/hwdiag.html
- run Driver Verifier according to these directions: http://www.carrona.org/verifier.html
Analysis:
The following is for informational purposes only.
[font=lucida console]**************************Thu Mar 28 20:45:08.531 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032813-18922-01.dmp]
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Built by: [B]7601[/B].18044.amd64fre.win7sp1_gdr.130104-1431
System Uptime:[B]0 days 4:51:42.811[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!CmpDelayDerefKeyControlBlock+f )[/B]
BugCheck [B]50, {ffffb8a00013c820, 0, fffff80002dc4597, 7}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000050]PAGE_FAULT_IN_NONPAGED_AREA (50)[/url]
Arguments:
Arg1: ffffb8a00013c820, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff80002dc4597, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000007, (reserved)
BUGCHECK_STR:  0x50
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]X64_0x50_nt!CmpDelayDerefKeyControlBlock+f[/B]
CPUID:        "Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz"
MaxSpeed:     3300
CurrentSpeed: [B]3292[/B]
  BIOS Version                  1103
  BIOS Release Date             11/08/2012
[/font]
3rd Party Drivers:
intelppm.sys                Mon Jul 13 19:19:25 2009 (4A5BC0FD)
nx6000.sys                  Wed Jan 27 18:36:09 2010 (4B60CDE9)
amdxata.sys                 Fri Mar 19 12:18:18 2010 (4BA3A3CA)
AsUpIO.sys                  Mon Aug  2 22:47:59 2010 (4C57835F)
viahduaa.sys                Wed Aug  4 03:51:53 2010 (4C591C19)
AsIO.sys                    Mon Aug 23 21:53:02 2010 (4C7325FE)
HECIx64.sys                 Tue Oct 19 19:33:43 2010 (4CBE2AD7)
Rt64win7.sys                Fri Jun 10 02:33:15 2011 (4DF1BAAB)
nvhda64v.sys                Wed Dec 19 00:41:41 2012 (50D15395)
nvlddmkm.sys                Sat Feb  9 18:13:08 2013 (5116D804)
[/font]
http://www.carrona.org/drivers/driver.php?id=intelppm.sys
http://www.carrona.org/drivers/driver.php?id=nx6000.sys
http://www.carrona.org/drivers/driver.php?id=amdxata.sys
http://www.carrona.org/drivers/driver.php?id=AsUpIO.sys
http://www.carrona.org/drivers/driver.php?id=viahduaa.sys
http://www.carrona.org/drivers/driver.php?id=AsIO.sys
http://www.carrona.org/drivers/driver.php?id=HECIx64.sys
http://www.carrona.org/drivers/driver.php?id=Rt64win7.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=nvlddmkm.sys
steffan
I did the tests you told me to do and passed a couple of them and did blend test on prime 95 on all 4 ram slots on the ram stick that passed. All of them seems to be running fine with no errors im gonna try the other stick to see if its that ram stick that is defected.
i have been receiving another bsod these couple of days called page fault on non paged area does that mean my hard drive is faulty?
Also can it be the i3 Processor that cant support dual channel memory since on the box of the RAM it only showed I5 and i7 supported but on the site it said it also supports i3 processors as well (found the problem has nothing to do with dual channel i believe the memory management was due to a defected ram)
i am still receiving stop error page fault on non paged area here is the latest mini dump
  • 033013-18844-01.rar
usasma
Fantastic Member
This error is most often found to be associated with a driver problem - and not a piece of hardware (like your hard drive).
But, just in case, please run these free hard drive diagnostics on all hard drives: Hard Drive Diagnostic Procedure
Since there's no definite blame assigned in the memory dump, please try running Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
[font=lucida console]**************************Sat Mar 30 21:01:50.065 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\033013-18844-01.dmp]
System Uptime:[B]0 days 0:04:41.579[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+43781 )[/B]
BugCheck [B]50, {ffffda80037e9350, 1, fffff80002a910cc, 7}[/B]
Arguments:
Arg1: ffffda80037e9350, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff80002a910cc, If non-zero, the instruction address which referenced the bad memory
    address.
BUGCHECK_STR:  0x50
PROCESS_NAME:  chrome.exe
FAILURE_BUCKET_ID: [B]X64_0x50_nt!_??_::FNODOBFM::_string_+43781[/B]
MaxSpeed:     3300
  BIOS Version                  1103
[/font]
3rd Party Drivers:
[/font]
steffan
I left the driver verifier on for more than a day now and i didn't get any blue screens(strange)
Anyways if i receive another stop error i will be coming back here for help again
Thanks for helping me out on my issues
usasma
Fantastic Member
Don't forget to turn Driver Verifier off. To do this, open verifier.exe and select "Delete existing settings". Then click on "Finish" and reboot the system in order for the changes to take effect.
