Windows 10 BSOD problem HELP
JjinN69
I am frequently experiencing BSODs and NVIDIA Kernel Mode driver crashes when playing Dota 2 since October 2015. I have no idea why this happens and I have done factory settings restore but the problem still persists. I have tried keeping my drivers up-to-date but it still crashes when I am playing the game. I also did a roll-back on the drivers and it doesn't help too. Downloaded the recommended drivers for my Lenovo PC model and still it doesn't fix anything. I am suspecting that it may due to a hardware problem, maybe a damaged Graphics Card or RAM problem. Can anyone please help ?
Following are the specs for my PC :
Lenovo Thinkpad Model W541
Windows 10 Pro
Processor : Intel(R) Core(TM) i7-4710MQ CPU @ 2.50 GHz
System type : 64-bit Operating System, x64 based processor
Display :
-Intel(R) HD Graphics 4600
Render :
-NVIDIA Quadro K1100M
Please tell me if there's more information you needed to help.
Please refer attached DxDiag analysis and .dmp files included in the .zip file.
Thank You.
BugCheck 152, {ac1288b8, fffff961ac1288b8, 0, 0}
Probably caused by : win32kfull.sys ( win32kfull!CAutoPushLockEx::CAutoPushLockEx+22 )
Followup: MachineOwner
of the two bugchecks sent one was the driver verifier which blamed the system kernel and the above means that for...
of the two bugchecks sent one was the driver verifier which blamed the system kernel and the above means that for whatever reason internal data or 'Flags' were invalid (Typically, a program uses a flag to remember something or to leave a sign for another program.).
If you haven't already please turn off the verifier.
This could be down to corruption within the system itself or a driver.
Try uninstalling your current gpu driver using this application:
Display Driver Uninstaller (DDU) V15.7.4.1 Released. - Wagnardmobile Forum
You will need to boot into safe mode in order to utilise it best but this will clear out any old bits of driver left behind by previous installs.
Re-install the driver from your systems support page:
Driver wise you don't look in too bad a shape although I notice there is a bios update available. If you don't feel up to installing the bios update i understand but if the bsod continues you may want to reconsider and perhaps get a local computer shop to update the bios for you.
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
Does the crash only happen with Dota 2 or any other game?
Try running the furmark test to check for stability:
FurMark: VGA Stress Test, Graphics Card and GPU Stability Test, Burn-in Test, OpenGL Benchmark and GPU Temperature | oZone3D.Net
As your testing please monitor system temperatures:
HWiNFO, HWiNFO32/64 - Download
Please post any new dump files.
JjinN69
Thanks for your help ! Really appreciated it. The crash happens most frequently, and very frequently in Dota2, but other games such as Fallout4 will sometimes have the same crashes too. I will do the steps and update you my progress ASAP :)
JjinN69
@kemical I was unable to complete the second scan through the command :
Below is a PNG of the scan results. Any idea?
