Smowk
I recently bought an SSD, and the BSOD's are daily issues.
Dump File : 122511-8876-01.dmp
Crash Time : 25.12.2011 05:38:17
Bug Check String : PAGE_FAULT_IN_NONPAGED_AREA
Bug Check Code : 0x00000050
Parameter 1 : fffff900`c2752cf0
Parameter 2 : 00000000`00000000
Parameter 3 : fffff960`002cc69d
Parameter 4 : 00000000`00000000
Caused By Driver : netbios.sys
Caused By Address : netbios.sys+1ade8e0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+71f00
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\122511-8876-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7600
Dump File Size : 369.165
Dump File : 122411-9157-01.dmp
Crash Time : 24.12.2011 05:36:24
Bug Check String : SYSTEM_SERVICE_EXCEPTION
Bug Check Code : 0x0000003b
Parameter 1 : 00000000`c0000005
Parameter 2 : fffff960`00144283
Parameter 3 : fffff880`06a38020
Caused By Driver : win32k.sys
Caused By Address : win32k.sys+c4283
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\122411-9157-01.dmp
Major Version : 15
Dump File : 121811-9360-01.dmp
Crash Time : 18.12.2011 00:22:20
Parameter 2 : fffff800`02e8b01e
Parameter 3 : fffff880`06ee8de0
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+71f00
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7600.16385 (win7_rtm.090713-1255)
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\121811-9360-01.dmp
Major Version : 15
Dump File Size : 369.229
The BSOD's occur randomly (when I hit shutdown, browsing especially) and my recently bsod, after the pc restarted It didn't see the SSD, told me to insert boot media or select boot device, I entered bios and surprise, my ssd wasn't on the list only my HDD (the problem solved after I restarted few times).
My drivers are updated, also could I get BSOD because I made a mistake at my PAGE FILE? (I custom sised it to 400mb, I got a hint from my cousin to do this because I have SSD) it was on automatically before but it might take couple of Gb's out of your ssd.
Can anyone HELP me?
Thank you
It seems like you are experiencing frequent BSODs after installing an SSD. The error codes and drivers mentioned in the dump files provide some insight into the potential causes of these crashes. Here's a breakdown of the information you provided:
  1. First Dump (PAGE_FAULT_IN_NONPAGED_AREA) - 25.12.2011:
    • Bug Check Code: 0x00000050
    • Caused By Driver: netbios.sys
    []Second Dump (SYSTEM_SERVICE_EXCEPTION) - 24.12.2011:
    • Bug Check Code: 0x0000003b
    • Caused By Driver: win32k.sys
    ]Third Dump (SYSTEM_SERVICE_EXCEPTION) - 18.12.2011:
    • Caused By Driver: ntoskrnl.exe From the dump file information, it appears...
    • Caused By Driver: ntoskrnl.exe From the dump file information, it appears that various drivers like netbios.sys, win32k.sys, and ntoskrnl.exe are involved in causing the crashes. Possible Causes and Solutions:
    []Driver Issues: Ensure that all your drivers are up to date, especially the ones related to the SSD and system stability. You can check the manufacturer's website for the latest drivers. []PAGE FILE: While reducing the size of the page file on the SSD is not recommended, a 400MB custom size might be too small. It's generally advised to let Windows manage the page file size, especially on SSDs. You can revert to the automatic management of the page file. []Startup Issues: The SSD not being detected after a crash could indicate a connection or compatibility issue. Ensure that the SSD connections are secure and that the BIOS settings are correctly configured to detect the SSD. []SSD Health: Check the health of your SSD using tools like CrystalDiskInfo to ensure it's functioning properly and doesn't have any physical issues. []Overheating: Verify that the SSD is not overheating, as excessive heat can cause instability. []System File Corruption: Running a System File Checker (SFC) scan can help identify and repair corrupted system files that may be causing the crashes.
  2. Windows Updates: Make sure your Windows operating system is fully updated to patch any known issues that could be causing the BSODs. By addressing these potential issues, you may be able to resolve the frequent BSODs you are encountering. If the problems persist, further troubleshooting steps may be needed.
