Justin Mitchell
Dump File : 102412-20046-01.dmp
Crash Time : 10/24/2012 10:41:38 AM
Bug Check String : DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x000000d1
Parameter 1 : 00000000`00000030
Parameter 2 : 00000000`00000002
Parameter 3 : 00000000`00000000
Parameter 4 : fffff880`05a5e394
Caused By Driver : NETw5s64.sys
Caused By Address : NETw5s64.sys+1b4394
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+7efc0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\102412-20046-01.dmp
Processors Count : 2
Major Version : 15
Minor Version : 7601
Dump File Size : 292,096
Dump File : 102012-19453-01.dmp
Crash Time : 10/20/2012 1:19:48 AM
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : 00000000`00000000
Parameter 4 : fffff800`03401477
Caused By Driver : hal.dll
Caused By Address : hal.dll+2477
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\102012-19453-01.dmp
Major Version : 15
help me if you can
You posting seem to point to the Network Adapter Driver (NETw5s64.sys). Can you update it or uninstall the Network adapter, remove all drivers for it during the uninstall, and let Windows find it again, or load drivers from another source?
You might want to jump over to the BSOD forum and check the sticky on what might be needed to diagnose a Blue Screen.
