Windows 10 BSOD Unexpected_Store_Exception need help to fix
Vodalyn1984
I keep getting the same crash report, an Unexpected_Store_Exception, on boot up. Any help would be greatly appreciated!
BugCheck 154, {ffffe000bf4cb000, ffffd0002528eae0, 0, 0}
Probably caused by : ntkrnlmp.exe ( nt!SMKM_STORE<SM_TRAITS>::SmStUnhandledExceptionFilter+22 )
Followup: MachineOwner
all dump files were the same as the above and mean that the Store caught an unexpected exception...
all dump files were the same as the above and mean that the Store caught an unexpected exception which looking at the call stack could down to a Hard drive/NTFS issue.
I checked your support page for drivers and have to admit this is a first for me:
I'm pretty sure the above is your machine but please correct me if I'm wrong.
May I ask when you upgraded to windows 10 did you check on compatibility first?
In any case please run these scans:
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
Please run a chkdsk:
Post any new dump files.
I have followed all the instructions above, to answer your questions Yes that is my computer and I upgraded to Windows 10 about a year ago, I don't remember the exact date. Here is the updated report.
BugCheck 154, {ffffe00016b3c000, ffffd001b3e76d80, 0, 0}
Please create a Recovery disk/USB:
The reason for this is because I want you to run the driver verifier. This can sometimes lead to a bsod boot loop. If this happens you can boot from the recovery disk/USB and enter safe mode to turn the verifier off.:
How do I fix a Blue Screen in Windows using Driver Verifier?
