That was a post for me!Well it looks like 10061 has backtracked on most of the video improvements gained over the last months. The Nvidia system is having some of the same problems it did with the original 3 builds. I am glad they centered the links on the Spartan favorites bar, but doesn't mean much if I can't play my games.
10056 was better and I may go back to it if I decide to try to stay with the Preview... I will try a clean install, and if it does the same thing, I am done.
I am still trying to see what is happening. The video is normal if I use just one monitor on both systems. If I try to go to surround on the three monitors, strange things happen.I am on the slow ring, but, when I read that 061 was available, i was tempted to change (again). Now I am staying with the slow ring.
Then I would try to change it back to the non-leaked configuration. It may not hold if you open and close the Registry or reboot, but it may straighten yours out. There is a note on the settings page which mentions changes to the build preferences may take up to 24 hours and it may depend on if you are logged into a Microsoft account.Saltgrass, Here is what mine looks like.
