Windows 8 Can I connect Laptop to Monitor PC?
MichaelWinchester
Hi, all
I just want to ask
I have a laptop Compaq CQ40, using windows 8
My laptop have a problem with the monitor, i guess the flexible cable of my laptop is broken
Now I wanna use my Monitor PC to work (like we use projector)
The question is, Can I use the monitor PC as the monitor Laptop?
What item must i prepare? What must i do?
Thanks a lot for your response
If I understand your question correctly, you want to know if you can use your PC's monitor with your laptop because the laptop's display is not working. Providing the problem is the laptop's display and not its video circuitry then yes. Your laptop has a VGA connector that will allow you to attach an external monitor. Once you attach the VGA cable to the connector, then one of the F keys should allow you to cycle thru laptop display, external or both. I can't say which F key provides that function on your laptop.
strollin
Honorable Member
