Can Your PC Handle Rematch? System Requirements Explained for Gamers
Rematch, the latest title highlighted on Esports.gg, brings together high-octane gaming and cutting-edge graphical technology for Windows gamers. But before you fire up your rig, it’s crucial to know whether your PC has the muscle to handle the action. Let’s break down the minimum and recommended system requirements for Rematch, and discuss what these specs mean for your gaming experience.
A young man intensely focused on a computer screen in a dimly lit room.
Understanding Minimum vs. Recommended Requirements​
When browsing game specs, you often see two sets of numbers: minimum and recommended.
• The minimum requirements are the bare bones specs needed for the game to run. With these settings, the game will launch and you’ll be able to play, but you might need to sacrifice visual fidelity and smooth performance.
• The recommended requirements are what the developers suggest if you want to enjoy the game at its best, with smoother gameplay and enhanced graphics. Essentially, it’s the “sweet spot” for a great experience.
For gamers who want blazing performance without having to tweak every setting, understanding this pair of benchmarks is essential. Let’s dive into the actual numbers.
Minimum System Requirements for Rematch​
For Rematch to run even on the lowest settings, the minimum specifications are as follows:
  • Operating System: Windows 10 (64-bit) or Windows 11 (64-bit)
  • Processor: Intel Core i5-10400, Intel Core i3-12100, or AMD Ryzen 5 3600
  • Memory: 16 GB RAM
  • Graphics: NVIDIA GeForce GTX 1660 (6GB VRAM) or AMD Radeon RX 5500 XT (8GB VRAM)
  • DirectX: Version 12
  • Network: Broadband Internet connection
  • Storage: 75 GB available space (SSD required)
  • Performance Expectation: The game is expected to run at 1080p (upscaled from a native 720p) at 30 FPS on the lowest settings, with DirectStorage support to help reduce load times
Even at these specs, you’ll likely encounter performance limitations. The visuals might not be as crisp, and the frame rate could dip noticeably in more demanding scenes. However, knowing that your system meets these minimum thresholds means that you can get into the action if you’re willing to adjust your expectations.
Recommended System Requirements for the Best Experience​
For gamers seeking a seamlessly smoother experience with higher visual settings, the recommended requirements are tuned for 1080p/60 FPS gameplay:
  • Processor: Same as the minimum requirements (Intel Core i5-10400, Intel Core i3-12100, or AMD Ryzen 5 3600)
  • Memory: 16 GB RAM
  • Graphics: NVIDIA GeForce RTX 2060 Super (8GB VRAM) or AMD Radeon RX 6600 (8GB VRAM)
  • Performance Expectation: With these specs, the game should run at 1080p/60 FPS (with frame generation on medium settings), delivering a noticeably smoother and more immersive experience.
The jump from a GTX 1660 to an RTX 2060 Super or the AMD RX 6600 essentially introduces the benefits of more advanced graphics processing—crisper visuals, improved lighting, and an overall more fluid gaming session. It’s this sweet spot that the developers endorse, targeting gamers who want both quality and performance without excessive tweaking.
What Do These Specifications Mean for Windows Gamers?​
For Windows gamers, especially those with systems that were built to handle modern titles, these requirements serve as a benchmark. Let’s explore why each component matters:
Operating System​
Both minimum and recommended setups run on Windows 10 or 11 (64-bit). Modern Windows versions bring robust driver support, DirectX 12 enhancements, and cutting-edge performance features like DirectStorage. The support for Windows 11, in particular, means that the game can take advantage of improvements in resource handling and system optimizations specific to Microsoft’s latest OS.
Processor (CPU)​
The use of Intel Core i5/i3 and AMD Ryzen 5 series processors as listed in the requirements signals that Rematch does rely on reasonably powerful multi-core performance. While the CPU may not be a glaring challenge given that many modern systems meet or exceed these specs, it is still fundamental in ensuring that background tasks and game logic run without hiccups.
Memory (RAM)​
At 16 GB, the system memory requirement ensures smooth multitasking. In today’s gaming landscape, 16 GB is almost the standard—enough to handle both the game and other system processes without causing bottlenecks.
Graphics Card (GPU)​
Your graphics card is the heart of the gaming experience. On the minimum side, the NVIDIA GTX 1660 or AMD RX 5500 XT ensures basic 1080p gameplay at a decent frame rate. However, stepping up to the RTX 2060 Super or its AMD equivalent significantly improves visual details, lighting effects, and the overall smoothness of gameplay. With support for DirectStorage, these GPUs can handle rapid texture streaming, which is especially important when playing on an SSD.
Storage​
A 75 GB SSD isn’t just a random number—it’s tuned to ensure the game’s assets load quickly, reducing long wait times. Using an SSD instead of an HDD is practically a requirement for modern gaming as data transfer speeds have become paramount for stable and responsive gameplay.
DirectX and Networking​
DirectX 12 is the baseline for many advanced graphical features, such as better shading and multi-threaded processing support. Additionally, a broadband Internet connection is highlighted to ensure that online functionalities and multiplayer features (if applicable) run smoothly.
Why Do Game Developers Publish These Specs?​
It might seem like a mere checklist, but game developers use these requirements to help players assess:
  • If their system will merely run the game or deliver a full-featured experience.
  • Where tweaking settings might be necessary if your system aligns more with the minimum specs.
  • When it might be time for an upgrade, especially if you’re eyeing those higher frame rates and immersive visuals.
Understanding these nuances helps you, the consumer, make an informed decision. Do you want to stick with basic settings, or is it time to consider hardware upgrades for a truly phenomenal gaming experience?
Making Sense of "Minimum" and "Recommended" in Your Own PC Configuration​
If your system’s hardware falls at the minimum level, you might face occasional frame drops in graphically heavy moments or need to reduce some visual settings. Here’s how you can evaluate where you stand:
  • Check Your OS: Ensure you’re running a 64-bit version of Windows 10 or Windows 11. Upgrading your OS may be one of the simplest ways to get better performance if you’re currently on an older version of Windows.
  • CPU and RAM: Open your Task Manager (Ctrl + Shift + Esc) to check your processor model and confirm that you have 16 GB of RAM. If your CPU is several generations old, even meeting the minimum might cause bottlenecks in CPU-intensive scenes.
  • GPU: Use tools like GPU-Z or check your system properties to see which graphics card you’re running. Compare your GPU’s performance with the minimum requirements. If it’s close to the GTX 1660 or RX 5500 XT thresholds, you might be able to run the game, but expect a performance hit in complex scenes.
  • Storage Space: Make sure you have a solid state drive (SSD)—preferably one with fast read/write speeds—to install the game. Running a game from an HDD can lead to longer load times and may negatively affect gameplay smoothness.
Using these checkpoints, you can quickly judge whether an upgrade is necessary or whether your current setup is sufficient for playing Rematch.
Upgrading Your PC for an Optimal Experience​
Not every PC is a gaming powerhouse straight off the bat. If your system lags behind the recommended specifications, here are a few tips:
  • Invest in a Better GPU: If graphics are your bottleneck, upgrading to a GPU like the NVIDIA RTX 2060 Super or an equivalent AMD card can dramatically improve visual performance.
  • Boost Your Storage: Transitioning from HDD to SSD can reduce load times and improve overall game responsiveness, thanks to faster data retrieval.
  • Consider a CPU Upgrade: While the minimum requirements might suffice, a more modern processor often comes with improvements in speed and efficiency. On platforms like Windows 11, newer CPUs can further reduce processing delays.
  • Upgrade Your Memory: Although 16 GB is sufficient, if you multitask heavily or run multiple background applications, additional RAM can help. However, for Rematch, the standard remains at 16 GB.
  • Keep Your Drivers Updated: Regularly updating your graphics and chipset drivers can eke out better performance and ensure compatibility with the latest game updates and DirectX improvements.
These upgrades don’t just apply to Rematch—they’re common considerations for any modern Windows gaming setup. Windows gamers can often find it worthwhile to periodically inspect their hardware setup and upgrade as necessary.
Broader Implications for Gaming on Windows​
The focus on detailed performance requirements underscores a broader trend in the gaming world: the increasing importance of optimized power delivery in PCs, especially on Windows. With the introduction of features like DirectStorage and enhanced DirectX 12 support in Windows 11, modern games are designed to maximize the interplay between hardware and software. This convergence can shift gameplay from being “just functional” to truly immersive.
For instance, DirectStorage is not just about faster load times—it's about enabling a battle-ready environment where texture streaming and rapid asset loading help maintain an uninterrupted gaming narrative. Gamers on Windows 11, in particular, are positioned to enjoy this new level of performance, as the OS is built with these innovations in mind.
Final Thoughts​
Rematch’s published system requirements provide clear guidance for gamers at all levels. Whether your rig is at the minimum spec or closer to the recommended setup, knowing precisely what hardware is needed allows you to tailor your settings, expectations, and potential upgrades accordingly. Here’s a quick recap:
  • The minimum requirements aim to let you play Rematch with basic settings at 1080p and 30 FPS, provided your PC meets the Windows 10/11 baseline, has a mid-range CPU paired with 16 GB RAM, and a GPU equivalent to the NVIDIA GTX 1660 or AMD RX 5500 XT—all on an SSD.
  • The recommended requirements target a smoother, more immersive experience at 1080p/60 FPS. A bit more punch in the GPU department (NVIDIA RTX 2060 Super or AMD Radeon RX 6600), along with the same CPU and memory specifications, ensures that gameplay remains fluid even during more demanding moments.
Taking a few minutes to assess your current hardware against these benchmarks could mean the difference between a laborious gaming session and a smooth, exciting adventure in Rematch. Armed with these insights and some handy tips for tuning your system, you’re now better prepared to decide: can your PC run Rematch? If not, consider the practical upgrade paths available for keeping your rig competitive in today’s fast-paced gaming world.
Source: Esports.gg Can your PC run Rematch? Minimum and recommended system requirements
