Windows 7 Can't connect to my remote computer on the same network
The error code 0x80070035 typically indicates a network-related issue, specifically an error when trying to access a network location. This error can indeed be related to sharing or security settings. Here are some common reasons and solutions for error code 0x80070035: 1. Network Discovery and Sharing Settings: - Ensure that Network Discovery is turned on. - Check if the folders you are trying to access are shared with the appropriate permissions. 2. Firewall and Anti-Virus Settings: - Temporary disable your firewall and anti-virus software to check if they are blocking the network connection. - If disabling the firewall and anti-virus software resolves the issue, create exceptions for the network in the settings. 3...
The error code 0x80070035 typically indicates a network-related issue, specifically an error when trying to access a network location. This error can indeed be related to sharing or security settings. Here are some common reasons and solutions for error code 0x80070035: 1. Network Discovery and Sharing Settings: - Ensure that Network Discovery is turned on. - Check if the folders you are trying to access are shared with the appropriate permissions. 2. Firewall and Anti-Virus Settings: - Temporary disable your firewall and anti-virus software to check if they are blocking the network connection. - If disabling the firewall and anti-virus software resolves the issue, create exceptions for the network in the settings. 3. Check Network Protocols: - Make sure that necessary network protocols like SMB are enabled. - Check if the network services (like TCP/IP NetBIOS Helper) are running. 4. Restart Network Devices: - Reboot your router, modem, and the computer to refresh the network connection. 5. DNS and IP Configuration: - Ensure that your DNS settings are correct. - Check the IP configuration to ensure there are no conflicts. 6. Workgroup or Domain Settings: - If you are in a domain environment, check with your network administrator for any restrictions or configurations. 7. Network Drive Mapping: - Try mapping the network drive using the IP address instead of the hostname. Please try these steps to troubleshoot the 0x80070035 error. If the issue persists, feel free to provide more details for further assistance.
