Charles Linquist
I have a home network with 7 or 8 XP machines. All are on the same workgroup. All share EVERYTHING. All have passwords. All are logged in with an ADMINISTRATOR account. All can see each other on the network. They all talk to each other just fine. All the GUEST accounts are turned ON.
I loaded Windows 7 on a machine, and turned on sharing for drive C: I gave everyone ALL permissions. I also went into the Network and Sharing Center. I had no idea what a "HomeGroup" was, so I went a few more menus deep and found the Workgroup setting. I set that up with the name of my workgroup.
From the Windows 7 machine, I can see all the XP machines on the network, and they can see the Windows 7 machine. But when I try to view anything (drive C:\ , for example), I get the "you might not have permission to view this network resource....". I get the same thing when I try to log on to the Windows 7 machine from the XP machines.
Since I can't log on to my XP machines, I also can't connect to, and use the printers attached to them.
I basically want a big, open, flat network. No security at all between machines. What do I need to do?
OK unlike some problems all the machines can see each other.
This looks like Firewall / AV settings might be inhibiting access.
For testing disable AV software and switch off firewalls. If you are paranoia disconnect from Internet as well.
Now see if you can connect.
Another solution is to re-set all the share options on ALL the machines and then permit share on a USER basis (select the disk / folder you want to share, right mouse click, properties, sharing, advanced permissions, add -- then add your user id and the privileges you want).
On the Windows XP machines as well as the above re-run the Network setup wizard from the control panel. re-boot.
You should be able to access all the folders you want.
Now re-enable firewalls and...
Still not working
I seem to be having pretty much the same problem. I cannot connect to my file server, which requires a user name and password.
I have 3 XP machines that connect to the same drive, with the same user name and password so I know its right. From my W7 machine, I cannot get to it. I can get to all the admin shares on all other machines, but the file server.
I've tried everything you suggested, and it still comes up asking for a user name and password and wont take the one I give it. Anything else you can think of?
*** Update ***
Some times I just need to search a little bit more. I found the answer on a different thread. (Link Removed)
- Click Start
- Click Control Panel
- Click System and Maintenance
- Click Administrative Tools
- Double-Click Local Security Policy
- In the left pane, click the triangle next to Local Policy
- In the left pane, click Security Options
- In the right pane near the bottom, double-click "Network security: LAN
manager authentication level"
- Click the drop-down box, and click "Send LM & NTLM responses"
- Click OK
Win 7 to Vista/XP Networking
OK, so the first thing I did was NOT use homegroup. I made sure the workgroup name was the same as the rest of my systems, then turned off password protect in networking, and finally, made sure I shared the appropriate folder and had guest permissions set to full.
Homegroup is ONLY used when connecting two or more systems that are running Win 7, it cannot be used for connecting dissimilar OS's (at least not so far as I can tell)
i was able to fix this problem by changing the permissions and ownership of the share to "Everyone" and i can now access all my shares from xp
Can't connect to My Windows XP
I am new to this forum. I need some help with networking my two computers. I have a wired Windows XP Pro and Windows 7 Home Premuim. I have them both in the same workgroup. Now I can access the printer that is attached to the Windows XP Pro. But I do not see my Windows XP Pro in the Network on Windows 7. On the Windows XP Pro, I can see my Windows 7 laptop but cannot access it. I am not sure what I am doing wrong. One minute I am able to access the Window XP from the Windows 7. I really just want to access the Windows XP from Windows 7. I really do not need Windows XP to access Windows 7. Can anyone help me figure this out?
I was finally able to do this after I tried EVERYTHING. I was able to connect when I uninstalled the McAfee virus protection on the XP computer. And I mean I had disabled homegroups on Win-7, done all windows updates, changed all the computer names and workgroups (don't use HOME as a computer name).
Finally - I believe there was ANOTHER firewall in McAfee, or else a hang in the program, that was blocking me. I am not sure, but I do know uninstalling McAfee was the answer.
I am posting this because few people ever post solutions when they find them.
PLEASE POST YOUR SOLUTIONS TO THIS SO COMMON PROBLEM!!!!
Furthermore, after I did this I was able to restore the Windows firewall and still connect to this XP computer.
On my machine it was not a firewall issue. On the Windows 7 computer I had to go to the Networking Properties of the connection from Control Panel\All Control Panel Items\Network and Sharing Center and turn off AGN Filter Interface (64-bit).
Hey Gang,
For those of you using a workgroup .... on the Windows 7 machine, in the System Properties --> Computer Name, make sure to Click on Network ID and when prompted for option "How do you use this computer", you should select "The computer is part of a business network...." and click next. On the next screen, for "what kind of network do you use?", select "My company uses a network without a domain". Then on the last screen, is should ask you to enter your workgroup name. Enter the name and continue to end. You'll need to reboot in order for the changes to take affect.
After many hours of searching a bunch of forums to no avail, I found it to be something this simple!
Hope this helps someone.
John
