Ragnar Egeland
Hi
I am new on the forum.
I'm working with Side Effects Houdini and it crashes all the time due to "command exit code: -1073741819".
I thought it was a Houdini issue, but I tink now it is a Window issue.
Please advice.
Ragnar Egeland
Hi
Please advice.
Ragnar Egeland
never used it myself so took a look through the various sites related to this app. One post I found was down to overclocking:
Command Exit Code -1073741819
Try turning off the XMP?
Hi
Please advice.
Ragnar Egeland
Ragnar Egeland
Thank you for the fastest answer ever on a forum.
I have google the Exit code, but was not able to find any solution.
It is a Dell Precision workstation with two Xeon processors. I have not overclocked the ram, so it must have been done by the factory.
I will take a look at the XMP.
Thank you again.
