whitelance
Hello, all I have an old machine i5 6th Generation, it has 8 GB ram with 256 GB SSD. I am using Windows 10 and want to upgrade to Windows 11. Does Upgrading will make my laptop slow or it will remain the same pace...
As Neemobeer mentioned it is not supported, still to satisfy you can download the Official tool released by Microsoft to see if your device will run Windows 11.
Below is the link for it
Go down to the bottom of the page & under check for compatibility click on download PC HEALTH CHECK APP
Once done, run it and see
Neemobeer
Windows Forum Team
6th gen Intel CPUs are not supported. You'd need to replace the CPU with a gen 7 or gen 8 I believe both use the same CPU socket
AsadAlam
Member
