JeronStevens
Member
For a while now my computer has been freezing up, quite odd freezes as well. I can move my mouse, and interact with some objects, but i cant do things such as open folders/files/start menu. If i have a browser open, i can still scroll on the page, but if i click on anything it wont load. its like whatever is currently loaded is ok, but whatever my computer needs to load wont open. Sometimes there are two mouse pointers on my screen as well, but i can only control one. There are no logs in the task manager either. this usually happens 1-2 times a day for 30-60 seconds, nothing causes it.
I also noticed the fans on my GPU are almost never on, idk why that is.
I was thinking it was my SSD that was going bad, but i did the tests on it and it says there are no problems with it, so that wont explain why it cant load.
Im not too aware of how power supply's act when they are dying, could it be that?
I dont think its my GPU, but some of the more recent wackiness is happening is making me doubt that.
Occasionally my desktop background just turns white. also today both my displays just turned off, no warning, and i had to restart my PC, and all is working good.
Yesterday i shut down my PC, but a few minutes later it wasn't shut down, the main monitor was off, and stuff, but my side monitor was black except for the task manager window?!
Samsung 860 EVO 500GB
GTX 1050 ti
AMD 8300 8core
8gb ddr3 ram
400W powwer supply
I can also upload some videos of it being weird, its mostly me just clicking icons/minimizing windows and nothing happens.
Please help me, I am really at a loss here...
Can you open a adim command prompt and run sfc /scannow and on completing that run dism /online /cleanup-image /restorehealth hopefully you just have corrupted system files and they should sort that out. If not we'll look at other remedies we can try.
nmsuk
JeronStevens
Member
Thanks for the reply, I am running that now.
I was going to make a new thread about this next issue, but it may pertain to your "corrupted system files" thought. I was trying to test individual components of my computer, and I tried to run the Windows Memory Diagnostics. Upon restarting i get an Error message:
An image from 'Computer freezes, hardware issue?'. Windows Boot Manager error showing missing or corrupted file memtest.efi preventing startup.
If this couldn't be relevant, let me know and ill make a new thread about this. Until then, ill let you know the results of my scan.
JeronStevens
Member
sfc /scannow : Did not find any integrity violations
Deployment image servicing and management tool:
version: 10.0.17134.1
image version 10.0.17134.345
The restore operation completed successfully.
JeronStevens
Member
So what else do you think?
Ive been having issues with my computer for 3-4 months now with this. and it seems every few weeks it freezes up differently.
A few months ago the display would just turn black.
A few weeks ago it would have beeping sounds when it froze, and nothing could move.
Now it freezes and i can move the mouse, the keyboard scroll lock/num lights can be toggled on the keyboard, but i cant interact with anything.
So its like every time it freezes its slightly different.
Im at a complete loss for explanation here.
nmsuk
Can you grab hwinfo64 and monitor temps, lets see if this is as simple as a heat issue.
JeronStevens
Member
I installed hwinfo64 if that's what you needed. Here's the summary
HWiNFO64 Version 5.70-3300
DESKTOP-9GESDGI -----------------------------------------------------------
[Current Computer]
Computer Name: DESKTOP-9GESDGI
Computer Brand Name: MSI MS-7693
[Operating System]
Operating System: Microsoft Windows 10 Home (x64) Build 17134.345
UEFI Boot: Present
Central Processor(s) ------------------------------------------------------
[CPU Unit Count]
Number Of Processor Packages (Physical): 1
Number Of Processor Cores: 8
Number Of Logical Processors: 8
AMD FX-8300 ---------------------------------------------------------------
[General Information]
Processor Name: AMD FX-8300
Original Processor Frequency: 3300.0 MHz
Original Processor Frequency [MHz]: 3300
CPU ID: 00600F20
Extended CPU ID: 00600F20
CPU Brand Name: AMD FX(tm)-8300 Eight-Core Processor
CPU Vendor: AuthenticAMD
CPU Stepping: OR-C0 (Orochi)
CPU Code Name: Piledriver/Vishera
CPU Technology: 32 nm
CPU OPN: FD8300WMW8KHK
CPU Thermal Design Power (TDP): 94.9 W
CPU Platform: Socket AM3r2
Microcode Update Revision: 6000822
Number of CPU Cores: 8
Number of Logical CPUs: 8
[Operating Points]
CPU HFM (Base): 3300.0 MHz = 16.50 x 200.0 MHz [Unlimited]
CPU Boost Max: 4200.0 MHz = 21.00 x 200.0 MHz [Unlimited]
CPU Current: 3600.2 MHz = 18.00 x 200.0 MHz @ 1.3375 V
Northbridge Maximum: [Unlimited]
Northbridge Current: 2200.1 MHz = 11.00 x 200.0 MHz @ 1.2000 V
CPU Bus Type: Hyper-Transport v3.00
Maximum Supported Hyper-Transport Link Clock: 3200 MHz
Current Hyper-Transport Link Clock: 2400 MHz
[Cache and TLB]
L1 Cache: Instruction: 4 x 64 KBytes, Data: 8 x 16 KBytes
L2 Cache: Integrated: 4 x 2 MBytes
L3 Cache: 8 MBytes
Instruction TLB: Fully associative, 48 entries
Data TLB: Fully associative, 64 entries
[Standard Feature Flags]
FPU on Chip Present
Enhanced Virtual-86 Mode Present
I/O Breakpoints Present
Page Size Extensions Present
Time Stamp Counter Present
Pentium-style Model Specific Registers Present
Physical Address Extension Present
Machine Check Exception Present
CMPXCHG8B Instruction Present
APIC On Chip / PGE (AMD) Present
Fast System Call Present
Memory Type Range Registers Present
Page Global Feature Present
Machine Check Architecture Present
CMOV Instruction Present
Page Attribute Table Present
36-bit Page Size Extensions Present
Processor Number Not Present
CLFLUSH Instruction Present
Debug Trace and EMON Store Not Present
Internal ACPI Support Not Present
MMX Technology Present
Fast FP Save/Restore (IA MMX-2) Present
Streaming SIMD Extensions Present
Streaming SIMD Extensions 2 Present
Self-Snoop Not Present
Multi-Threading Capable Present
Automatic Clock Control Not Present
IA-64 Processor Not Present
Signal Break on FERR Not Present
Streaming SIMD Extensions 3 Present
PCLMULQDQ Instruction Support Present
MONITOR/MWAIT Support Present
Supplemental Streaming SIMD Extensions 3 Present
FMA Extension Present
CMPXCHG16B Support Present
Streaming SIMD Extensions 4.1 Present
Streaming SIMD Extensions 4.2 Present
x2APIC Not Present
POPCNT Instruction Present
AES Cryptography Support Present
XSAVE/XRSTOR/XSETBV/XGETBV Instructions Present
XGETBV/XSETBV OS Enabled Present
AVX Support Present
Half-Precision Convert (CVT16) Present
[Extended Feature Flags]
FPU on Chip Present
AMD-style Model Specific Registers Present
APIC On Chip Present
SYSCALL and SYSRET Instructions Present
Multi-Processing / Brand feature Not Present
No Execute Present
MMX+ Extensions Present
Fast FP Save/Restore Present
Fast FP Save/Restore Optimizations Present
1 GB large page support Present
RDTSCP Instruction Present
x86-64 Long Mode Present
3DNow! Technology Extensions Not Present
3DNow! Technology Not Present
Bit Manipulation Instructions Set 1 Present
Bit Manipulation Instructions Set 2 Not Present
Advanced Vector Extensions 2 (AVX2) Not Present
Advanced Vector Extensions 512 (AVX-512) Not Present
AVX-512 Prefetch Instructions Not Present
AVX-512 Exponential and Reciprocal Instructions Not Present
AVX-512 Conflict Detection Instructions Not Present
AVX-512 Doubleword and Quadword Instructions Not Present
AVX-512 Byte and Word Instructions Not Present
AVX-512 Vector Length Extensions Not Present
AVX-512 52-bit Integer FMA Instructions Not Present
Secure Hash Algorithm (SHA) Extensions Not Present
Software Guard Extensions (SGX) Support Not Present
Supervisor Mode Execution Protection (SMEP) Not Present
Supervisor Mode Access Prevention (SMAP) Not Present
Hardware Lock Elision (HLE) Not Present
Restricted Transactional Memory (RTM) Not Present
Memory Protection Extensions (MPX) Not Present
Read/Write FS/GS Base Instructions Not Present
Enhanced Performance String Instruction Not Present
INVPCID Instruction Not Present
RDSEED Instruction Not Present
Multi-precision Add Carry Instructions (ADX) Not Present
PCOMMIT Instructions Not Present
CLFLUSHOPT Instructions Not Present
CLWB Instructions Not Present
TSC_THREAD_OFFSET Not Present
Platform Quality of Service Monitoring (PQM) Not Present
Platform Quality of Service Enforcement (PQE) Not Present
FPU Data Pointer updated only on x87 Exceptions Not Present
Deprecated FPU CS and FPU DS Not Present
Intel Processor Trace Not Present
PREFETCHWT1 Instruction Not Present
AVX-512 Vector Bit Manipulation Instructions Not Present
AVX-512 Vector Bit Manipulation Instructions 2 Not Present
AVX-512 Galois Fields New Instructions Not Present
AVX-512 Vector AES Not Present
AVX-512 Vector Neural Network Instructions Word Not Present
AVX-512 Bit Algorithms Not Present
AVX-512 Carry-Less Multiplication Quadword (VPCLMULQDQ) Not Present
AVX-512 Vector POPCNT (VPOPCNTD/VPOPCNTQ) Not Present
User-Mode Instruction Prevention Not Present
Protection Keys for User-mode Pages Not Present
OS Enabled Protection Keys Not Present
Total Memory Encryption Not Present
Read Processor ID Not Present
SGX Launch Configuration Not Present
AVX-512 4 x Vector Neural Network Instructions Word Variable Precision Not Present
AVX-512 4 x Fused Multiply Accumulation Packed Single Precision Not Present
LAHF/SAHF Long Mode Support Present
Core Multi-Processing Legacy Mode Present
Secure Virtual Machine Present
Extended APIC Register Space Present
LOCK MOV CR0 Support Present
Advanced Bit Manipulation Present
SSE4A Support Present
Misaligned SSE Mode Present
PREFETCH(W) Support Present
OS Visible Work-around Support Present
Instruction Based Sampling Present
XOP Instruction Support Present
SKINIT, STGI, and DEV Support Present
Watchdog Timer Support Present
TBM0 Instruction Support Not Present
Lightweight Profiling Support Present
FMA4 Instruction Support Present
Translation Cache Extension Present
NodeId Support Present
Trailing Bit Manipulation Present
Topology Extensions Present
Core Performance Counter Extensions Present
NB Performance Counter Extensions Present
Streaming Performance Monitor Architecture Not Present
Data Breakpoint Extension Not Present
Performance Time-Stamp Counter Not Present
L2I Performance Counter Extensions Not Present
MWAITX/MONITORX Support Not Present
Secure Memory Encryption Not Present
Secure Encrypted Virtualization Not Present
[Enhanced Features]
Core Performance Boost Supported, Enabled
[Memory Ranges]
Maximum Physical Address Size: 48-bit (256 TBytes)
Maximum Virtual Address Size: 48-bit (256 TBytes)
[MTRRs]
Range 0-80000000 (0MB-2048MB) Type: Write Back (WB)
Range 80000000-C0000000 (2048MB-3072MB) Type: Write Back (WB)
Range BF800000-C0000000 (3064MB-3072MB) Type: Uncacheable (UC)
Motherboard ---------------------------------------------------------------
[Computer]
[Motherboard]
Motherboard Model: MSI 970A-G43 (MS-7693)
Motherboard Chipset: AMD 970 (RX980) + SB920/SB950
Motherboard Slots: 3xPCI Express x1, 2xPCI Express x2, 1xPCI Express x4, 1xPCI Express x16
PCI Express Version Supported: v2.0
USB Version Supported: v3.0
[BIOS]
BIOS Manufacturer: American Megatrends
BIOS Date: 01/08/2016
BIOS Version: V10.6
AMD AGESA Version: OrochiPIV1.5.0.4
UEFI BIOS: Capable
Super-IO/LPC Chip: Unknown
ACPI Devices --------------------------------------------------------------
Programmable interrupt controller -----------------------------------------
Device Name: Programmable interrupt controller
[Assigned Resources]
I/O Port: 0020 - 0021
IRQ: 65792
[Alternative 1]
I/O Port: 00A0 - 00A1
System timer --------------------------------------------------------------
Device Name: System timer
I/O Port: 0040 - 0043
[Alternative 1]
IRQ: 0
High precision event timer ------------------------------------------------
Device Name: High precision event timer
Memory Location: FED00000 - FED003FF
[Alternative 1]
Direct memory access controller -------------------------------------------
Device Name: Direct memory access controller
I/O Port: 0089 - 008B
DMA: 4
[Alternative 1]
I/O Port: 0000 - 000F
I/O Port: 0081 - 0083
I/O Port: 0087
I/O Port: 008F
I/O Port: 00C0 - 00DF
DMA: 4
Communications Port -------------------------------------------------------
Device Name: Communications Port
I/O Port: 03F8 - 03FF
[Alternative 1]
IRQ: 4
[Alternative 2]
IRQ: 3
IRQ: 4
IRQ: 5
IRQ: 6
IRQ: 7
IRQ: 10
IRQ: 11
IRQ: 12
[Alternative 3]
I/O Port: 02F8 - 02FF
IRQ: 3
IRQ: 4
IRQ: 5
IRQ: 6
IRQ: 7
IRQ: 10
IRQ: 11
IRQ: 12
[Alternative 4]
I/O Port: 03E8 - 03EF
IRQ: 3
IRQ: 4
IRQ: 5
IRQ: 6
IRQ: 7
IRQ: 10
IRQ: 11
IRQ: 12
[Alternative 5]
I/O Port: 02E8 - 02EF
IRQ: 3
IRQ: 4
IRQ: 5
IRQ: 6
IRQ: 7
IRQ: 10
IRQ: 11
IRQ: 12
System speaker ------------------------------------------------------------
Device Name: System speaker
I/O Port: 0061
[Alternative 1]
I/O Port: 0061
Pci Bus -------------------------------------------------------------------
Device Name: Pci Bus
I/O Port: 0000 - FFFFFFFF
I/O Port: 03B0 - 03DF
Memory Location: 000A0000 - 0009FFFF
[Alternative 1]
I/O Port: 0000 - 03AF
I/O Port: 03E0 - 0CF7
I/O Port: 0D00 - FFFF
Memory Location: 000A0000 - 000BFFFF
Memory Location: 000C0000 - 000DFFFF
Memory Location: C0000000 - FFFFFFFF
System CMOS/real time clock -----------------------------------------------
Device Name: System CMOS/real time clock
I/O Port: 0070 - 0071
[Alternative 1]
IRQ: 8
System board --------------------------------------------------------------
Device Name: System board
Memory Location: E0000000 - EFFFFFFF
[Alternative 1]
Motherboard resources -----------------------------------------------------
Device Name: Motherboard resources
I/O Port: 0010 - 001F
I/O Port: 0065 - 006F
I/O Port: 0088
Memory Location: 00000000 - 0000008F
[Alternative 1]
I/O Port: 0022 - 003F
I/O Port: 0044 - 005F
I/O Port: 0062 - 0063
I/O Port: 0072 - 007F
I/O Port: 0080
I/O Port: 0084 - 0086
I/O Port: 0088
I/O Port: 008C - 008E
I/O Port: 0090 - 009F
I/O Port: 00A2 - 00BF
I/O Port: 00E0 - 00EF
I/O Port: 04D0 - 04D1
Memory Location: FEC20000 - FEC200FF
[Alternative 1]
I/O Port: 0480 - 0481
[Alternative 1]
I/O Port: 040B
I/O Port: 0000 - 0BFF
I/O Port: 0C50 - 0C51
I/O Port: 0000 - 0C6B
I/O Port: 0CD0 - 0CD1
I/O Port: 0CD8 - 0CDF
I/O Port: 0900 - 090F
Memory Location: FEE00000 - FEE00FFF
IRQ: 1114369
[Alternative 1]
I/O Port: 040B
I/O Port: 04D6
I/O Port: 0C00 - 0C01
I/O Port: 0C14
I/O Port: 0C52
I/O Port: 0C6C
I/O Port: 0C6F
I/O Port: 0CD2 - 0CD3
I/O Port: 0CD4 - 0CD5
I/O Port: 0CD6 - 0CD7
I/O Port: 0800 - 089F
I/O Port: 0B20 - 0B3F
I/O Port: 0910 - 091F
I/O Port: FE00 - FEFE
Memory Location: FEC00000 - FEC00FFF
Memory Location: FED80000 - FED8FFFF
Memory Location: FED61000 - FED70FFF
Memory Location: FEC10000 - FEC10FFF
Memory Location: FED00000 - FED00FFF
Memory Location: FF800000 - FFFFFFFF
Numeric data processor ----------------------------------------------------
Device Name: Numeric data processor
I/O Port: 00F0 - 00FF
[Alternative 1]
IRQ: 13
SMBIOS DMI ----------------------------------------------------------------
BIOS ----------------------------------------------------------------------
BIOS Vendor: American Megatrends Inc.
BIOS Version: V10.6
BIOS Release Date: 01/08/2016
BIOS Start Segment: F000
BIOS Size: 8192 KBytes
System BIOS Version: 4.6
ISA Support: Not Present
MCA Support: Not Present
EISA Support: Not Present
PCI Support: Present
PC Card (PCMCIA) Support: Not Present
Plug-and-Play Support: Not Present
APM Support: Not Present
Flash BIOS: Present
BIOS Shadow: Present
VL-VESA Support: Not Present
ESCD Support: Not Present
Boot from CD: Present
Selectable Boot: Present
BIOS ROM Socketed: Present
Boot from PC Card: Not Present
EDD Support: Present
NEC PC-98 Support: Not Present
ACPI Support: Present
USB Legacy Support: Present
AGP Support: Not Present
I2O Boot Support: Not Present
LS-120 Boot Support: Not Present
ATAPI ZIP Drive Boot Support: Not Present
IEE1394 Boot Support: Not Present
Smart Battery Support: Not Present
BIOS Boot Specification Support: Present
Function key-initiated Network Service Boot Support: Not Present
Targeted Content Distribution Support: Present
UEFI Specification Support: Present
Virtual Machine: Not Present
System --------------------------------------------------------------------
System Manufacturer: MSI
Product Name: MS-7693
Product Version: 3.0
Product Serial Number: To be filled by O.E.M.
SKU Number: To be filled by O.E.M.
Family: To be filled by O.E.M.
Mainboard -----------------------------------------------------------------
Mainboard Manufacturer: MSI
Mainboard Name: 970A-G43 (MS-7693)
Mainboard Version: 3.0
Mainboard Serial Number: To be filled by O.E.M.
Asset Tag: To be filled by O.E.M.
Location in chassis: To be filled by O.E.M.
System Enclosure ----------------------------------------------------------
Manufacturer: MSI
Case Type: Desktop
Version: 3.0
Serial Number: To Be Filled By O.E.M.
Asset Tag Number: To Be Filled By O.E.M.
Processor -----------------------------------------------------------------
Processor Manufacturer: AMD
Processor Version: AMD FX(tm)-8300 Eight-Core Processor
External Clock: 200 MHz
Maximum Clock Supported: 3300 MHz
Current Clock: 3300 MHz
CPU Socket: Populated
CPU Status: Enabled
Processor Type: Central Processor
Processor Voltage: 1.2 V
Processor Upgrade: Socket AM3
Socket Designation: CPU 1
L1-Cache ------------------------------------------------------------------
Socket Designation: L1-Cache
Cache State: Enabled
Cache Type: Internal, Unified
Cache Scheme: Write-Back
Supported SRAM Type: Pipeline Burst
Current SRAM Type: Pipeline Burst
Cache Speed: 1 ns
Error Correction Type: Multi-bit ECC
Maximum Cache Size: 384 KBytes
Installed Cache Size: 384 KBytes
Cache Associativity: 2-way Set-Associative
L2-Cache ------------------------------------------------------------------
Socket Designation: L2-Cache
Cache Speed: 1 ns
Maximum Cache Size: 8192 KBytes
Installed Cache Size: 8192 KBytes
Cache Associativity: 16-way Set-Associative
L3-Cache ------------------------------------------------------------------
Socket Designation: L3-Cache
Cache Speed: 1 ns
Cache Associativity: 64-way Set-Associative
OEM Strings ---------------------------------------------------------------
System Configuration Options ----------------------------------------------
System Boot Information ---------------------------------------------------
Boot Status: No error occured
On Board Device -----------------------------------------------------------
Device Description: Onboard IGD
Device Type: Video Adapter
Device Status: Enabled
Device Description: Onboard LAN
Device Type: Ethernet Adapter
Device Description: Onboard 1394
Device Type: Unknown
BIOS Language -------------------------------------------------------------
Memory Devices ------------------------------------------------------------
Physical Memory Array -----------------------------------------------------
Array Location: System board
Array Use: System memory
Error Detecting Method: None
Memory Capacity: 32 GBytes
Memory Devices: 4
Memory Array Mapped Address -----------------------------------------------
Starting Address: 00000000
Ending Address: 007FFFFF
Partition Width: 255
Memory Device -------------------------------------------------------------
Total Width: 0 bits
Data Width: 64 bits
Device Size: 0 MBytes
Device Form Factor: DIMM
Device Locator: A1_DIMM0
Bank Locator: A1_BANK0
Device Type Detail: Synchronous
Manufacturer: A1_Manufacturer0
Serial Number: A1_SerNum0
Part Number: Array1_PartNumber0
Asset Tag: A1_AssetTagNum0
Total Width: 64 bits
Data Width: 64 bits
Device Size: 8192 MBytes
Device Locator: A1_DIMM1
Bank Locator: A1_BANK1
Device Type: DDR3 SDRAM
Memory Speed: 800 MHz
Manufacturer: Undefined
Serial Number: 00000000
Part Number: F641GU67G1600G
Asset Tag: A1_AssetTagNum1
Memory Device Mapped Address ----------------------------------------------
Ending Address: 0000003F
Partition Row Position: Unknown
Interleave Position: Unknown
Interleave Data Depth: Unknown
Total Width: 0 bits
Data Width: 64 bits
Device Locator: A1_DIMM2
Bank Locator: A1_BANK2
Manufacturer: A1_Manufacturer2
Serial Number: A1_SerNum2
Part Number: Array1_PartNumber2
Asset Tag: A1_AssetTagNum2
Total Width: 0 bits
Data Width: 64 bits
Device Locator: A1_DIMM3
Bank Locator: A1_BANK3
Manufacturer: A1_Manufacturer3
Serial Number: A1_SerNum3
Part Number: Array1_PartNumber3
Asset Tag: A1_AssetTagNum3
Port Connectors -----------------------------------------------------------
Mouse Port ----------------------------------------------------------------
Port Type: Mouse Port
Internal Reference: J1A1
Internal Connector Type: None
External Reference: PS2Mouse
External Connector Type: PS/2
Keyboard Port -------------------------------------------------------------
Port Type: Keyboard Port
External Reference: Keyboard
Port Connector ------------------------------------------------------------
Port Type: Unknown
Internal Reference: J2A1
External Reference: TV Out
External Connector Type: Mini-Centronics Type-14
Serial Port 16550A Compatible ---------------------------------------------
Port Type: Serial Port 16550A Compatible
Internal Reference: J2A2A
External Reference: COM A
External Connector Type: DB-9 pin male
Video Port ----------------------------------------------------------------
Port Type: Video Port
Internal Reference: J2A2B
External Reference: Video
External Connector Type: DB-15 pin female
USB -----------------------------------------------------------------------
Port Type: USB
Internal Reference: J3A1
External Reference: USB1
External Connector Type: Access Bus (USB)
Port Type: USB
External Reference: USB2
Port Type: USB
External Reference: USB3
Port Type: Unknown
Internal Reference: J9A1 - TPM HDR
Internal Connector Type: Unknown
External Reference: Unknown
External Connector Type: None
Port Type: Unknown
Internal Reference: J9C1 - PCIE DOCKING CONN
Port Type: Unknown
Internal Reference: J2B3 - CPU FAN
Port Type: Unknown
Internal Reference: J6C2 - EXT HDMI
Port Type: Unknown
Internal Reference: J3C1 - GMCH FAN
Port Type: Unknown
Internal Reference: J1D1 - ITP
Port Type: Unknown
Internal Reference: J9E2 - MDC INTPSR
Port Type: Unknown
Internal Reference: J9E4 - MDC INTPSR
Port Type: Unknown
Internal Reference: J9E3 - LPC HOT DOCKING
Port Type: Unknown
Internal Reference: J9E1 - SCAN MATRIX
Port Type: Unknown
Internal Reference: J9G1 - LPC SIDE BAND
Port Type: Unknown
Internal Reference: J8F1 - UNIFIED
Port Type: Unknown
Internal Reference: J6F1 - LVDS
Port Type: Unknown
Internal Reference: J2F1 - LAI FAN
Port Type: Unknown
Internal Reference: J2G1 - GFX VID
Port Type: Unknown
Internal Reference: J1G6 - AC JACK
System Slots --------------------------------------------------------------
J6B2 ----------------------------------------------------------------------
Slot Designation: J6B2
Slot Type: PCI Express
Slot Usage: In use
Slot Data Bus Width: 16x / x16
Slot Length: Long
J6B1 ----------------------------------------------------------------------
Slot Designation: J6B1
Slot Usage: In use
Slot Data Bus Width: 1x / x1
Slot Length: Short
J6D1 ----------------------------------------------------------------------
Slot Designation: J6D1
Slot Usage: In use
Slot Length: Short
J7B1 ----------------------------------------------------------------------
Slot Designation: J7B1
Slot Usage: In use
Slot Length: Short
Memory --------------------------------------------------------------------
[General information]
Total Memory Size: 8 GBytes
Total Memory Size [MB]: 8192
[Current Performance Settings]
Maximum Supported Memory Clock: 933.3 MHz
Row: 2 - 8 GB PC3-12800 DDR3 SDRAM Avant Technology F641GU67G1600G --------
[General Module Information]
Module Number: 2
Module Size: 8 GBytes
Memory Type: DDR3 SDRAM
Module Type: Unbuffered DIMM (UDIMM)
Memory Speed: 800.0 MHz (DDR3-1600 / PC3-12800)
Module Manufacturer: Avant Technology
Module Part Number: F641GU67G1600G
Module Revision: 0
Module Serial Number: 0
Module Manufacturing Date: Year: 2000, Week: 0
Module Manufacturing Location: 0
SDRAM Manufacturer: Micron Tech.
Error Check/Correction: None
[Module characteristics]
Row Address Bits: 16
Column Address Bits: 10
Number Of Banks: 8
Module Density: 4096 Mb
Number Of Ranks: 2
Device Width: 8 bits
Bus Width: 64 bits
Module Nominal Voltage (VDD): 1.5 V, 1.35 V
[Module timing]
Minimum SDRAM Cycle Time (tCKmin): 1.250 ns
CAS# Latencies Supported: 6, 7, 8, 9, 10, 11
Minimum CAS# Latency Time (tAAmin): 13.125 ns
Minimum RAS# to CAS# Delay (tRCDmin): 13.125 ns
Minimum Row Precharge Time (tRPmin): 13.125 ns
Minimum Active to Precharge Time (tRASmin): 35.000 ns
Supported Module Timing at 800.0 MHz: 11-11-11-28
Supported Module Timing at 733.3 MHz: 10-10-10-26
Supported Module Timing at 666.7 MHz: 9-9-9-24
Supported Module Timing at 600.0 MHz: 8-8-8-21
Supported Module Timing at 533.3 MHz: 7-7-7-19
Supported Module Timing at 466.7 MHz: 7-7-7-17
Supported Module Timing at 400.0 MHz: 6-6-6-14
Minimum Write Recovery Time (tWRmin): 15.000 ns
Minimum Row Active to Row Active Delay (tRRDmin): 6.000 ns
Minimum Active to Active/Refresh Time (tRCmin): 48.125 ns
Minimum Refresh Recovery Time Delay (tRFCmin): 260.000 ns
Minimum Internal Write to Read Command Delay (tWTRmin): 7.500 ns
Minimum Internal Read to Precharge Command Delay (tRTPmin): 7.500 ns
Minimum Four Activate Window Delay Time (tFAWmin): 30.000 ns
[Features]
Partial Array Self Refresh (PASR): Not Supported
On-die Thermal Sensor (ODTS) Readout: Not Supported
Auto Self Refresh (ASR): Supported
Extended Temperature 1X Refresh Rate: Not Supported
Extended Temperature Range: Supported
Module Temperature Sensor: Not Supported
Pseudo Target Row Refresh (pTRR): Not Supported
Module Nominal Height: 29 - 30 mm
Module Maximum Thickness (Front): 1 - 2 mm
Module Maximum Thickness (Back): 1 - 2 mm
Bus -----------------------------------------------------------------------
PCI Bus #0 ----------------------------------------------------------------
ATI/AMD RD9x0 - Host Bridge -----------------------------------------------
Device Name: ATI/AMD RD9x0 - Host Bridge
Original Device Name: ATI/AMD RD9x0 - Host Bridge
Device Class: Host-to-PCI Bridge
Revision ID: 2
PCI Address (Bus:Device:Function) Number: 0:0:0
PCI Latency Timer: 0
Hardware ID: PCI\VEN_1002&DEV_5A14&SUBSYS_76931462&REV_02
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
Bus Mastering: Disabled
Running At 66 MHz: Not Capable
Fast Back-to-Back Transactions: Not Capable
[Driver Information]
Driver Manufacturer: (Standard system devices)
Driver Description: PCI standard host CPU bridge
Driver Provider: Microsoft
Driver Version: 10.0.17134.1
Driver Date: 20-Jun-2006
DeviceInstanceId PCI\VEN_1002&DEV_5A14&SUBSYS_76931462&REV_02\3&11583659&1&00
Location Paths PCIROOT(0)#PCI(0000)
ATI/AMD RD890/RD9x0 - IOMMU -----------------------------------------------
Device Name: ATI/AMD RD890/RD9x0 - IOMMU
Original Device Name: ATI/AMD RD890/RD9x0 - IOMMU
Device Class: IOMMU
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:0:2
Hardware ID: PCI\VEN_1002&DEV_5A23&SUBSYS_76931462&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: INTA#
[Features]
Driver Manufacturer: AMD
Driver Description: AMD IOMMU Device
Driver Provider: AMD
Driver Version: 1.2.0.32
Driver Date: 16-Apr-2018
DeviceInstanceId PCI\VEN_1002&DEV_5A23&SUBSYS_76931462&REV_00\3&11583659&1&02
Location Paths PCIROOT(0)#PCI(0002)
ATI/AMD RD890/RD9x0 - PCI Express Port (GPP3a port 0) ---------------------
Device Name: ATI/AMD RD890/RD9x0 - PCI Express Port (GPP3a port 0)
Original Device Name: ATI/AMD RD890/RD9x0 - PCI Express Port (GPP3a port 0)
Device Class: PCI-to-PCI Bridge
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:4:0
Hardware ID: PCI\VEN_1002&DEV_5A18&SUBSYS_00000000&REV_00
[PCI Express]
Version: 2.0
Maximum Link Width: 4x
Current Link Width: 4x
Maximum Link Speed: 5.0 GT/s
Current Link Speed: 5.0 GT/s
Device/Port Type: Root Port of PCI Express Root Complex
Slot Implemented: Yes
Hot-Plug: Not Capable
Hot-Plug Surprise: Not Capable
Slot Power Limit: 75.000 W
Emergency Power Reduction: Not Supported
Active State Power Management (ASPM) Support: L0s and L1
Active State Power Management (ASPM) Status: Disabled
L0s Exit Latency: 512 ns - 1 us
L1 Exit Latency: 4 - 8 us
Maximum Payload Size Supported: 128 bytes
Maximum Payload Size: 128 bytes
[System Resources]
Interrupt Line: IRQ11
[Features]
Bus Mastering: Enabled
Driver Description: PCI-to-PCI Bridge
Driver Version: 10.0.17134.254
DeviceInstanceId PCI\VEN_1002&DEV_5A18&SUBSYS_76931462&REV_00\3&11583659&1&20
Location Paths PCIROOT(0)#PCI(0400)
PCI Express x4 Bus #1 -----------------------------------------------------
GIGABYTE GTX 1050 Ti OC (GV-N105TOC-4GD) ----------------------------------
Device Name: GIGABYTE GTX 1050 Ti OC (GV-N105TOC-4GD)
Original Device Name: NVIDIA GeForce GTX 1050 Ti (GP107-400)
Device Class: VGA Compatible Adapter
Revision ID: A1
PCI Address (Bus:Device:Function) Number: 1:0:0
Hardware ID: PCI\VEN_10DE&DEV_1C82&SUBSYS_37321458&REV_A1
[PCI Express]
Version: 2.0
Maximum Link Width: 16x
Device/Port Type: Legacy PCI Express Endpoint
Slot Implemented: No
L1 Exit Latency: 2 - 4 us
Maximum Payload Size Supported: 256 bytes
[System Resources]
Interrupt Line: IRQ44
Memory Base Address 0 FD000000
Memory Base Address 1 C0000000
Memory Base Address 3 D0000000
I/O Base Address 5 E000
[Features]
Driver Manufacturer: NVIDIA
Driver Description: NVIDIA GeForce GTX 1050 Ti
Driver Provider: NVIDIA
Driver Version: 24.21.13.9882 (GeForce 398.82)
Driver Date: 29-Jul-2018
DeviceInstanceId PCI\VEN_10DE&DEV_1C82&SUBSYS_37321458&REV_A1\4&11574C93&0&0020
Location Paths PCIROOT(0)#PCI(0400)#PCI(0000)
NVIDIA GP107 - High Definition Audio Controller ---------------------------
Device Name: NVIDIA GP107 - High Definition Audio Controller
Original Device Name: NVIDIA GP107 - High Definition Audio Controller
Device Class: Mixed mode device
Revision ID: A1
PCI Address (Bus:Device:Function) Number: 1:0:1
Hardware ID: PCI\VEN_10DE&DEV_0FB9&SUBSYS_37321458&REV_A1
[PCI Express]
Version: 2.0
Device/Port Type: PCI Express Endpoint
Active State Power Management (ASPM) Status: L0s and L1 Entry
[System Resources]
Interrupt Line: IRQ45
Interrupt Pin: INTB#
Memory Base Address 0 FE080000
[Features]
Driver Manufacturer: Microsoft
Driver Description: High Definition Audio Controller
Driver Date: 10-Apr-2018
DeviceInstanceId PCI\VEN_10DE&DEV_0FB9&SUBSYS_37321458&REV_A1\4&11574C93&0&0120
Location Paths PCIROOT(0)#PCI(0400)#PCI(0001)
ATI/AMD RD890/RD9x0 - PCI Express Port (GPP3a port 4) ---------------------
Device Name: ATI/AMD RD890/RD9x0 - PCI Express Port (GPP3a port 4)
Original Device Name: ATI/AMD RD890/RD9x0 - PCI Express Port (GPP3a port 4)
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:9:0
Hardware ID: PCI\VEN_1002&DEV_5A1C&SUBSYS_00000000&REV_00
[PCI Express]
Version: 2.0
Maximum Link Width: 2x
Current Link Width: 1x
[System Resources]
Interrupt Line: IRQ10
[Features]
DeviceInstanceId PCI\VEN_1002&DEV_5A1C&SUBSYS_76931462&REV_00\3&11583659&1&48
Location Paths PCIROOT(0)#PCI(0900)
PCI Express x2 Bus #2 -----------------------------------------------------
Renesas Electronics uPD720202 USB 3.0 xHCI Host Controller ----------------
Device Name: Renesas Electronics uPD720202 USB 3.0 xHCI Host Controller
Original Device Name: Renesas Electronics uPD720202 USB 3.0 xHCI Host Controller
Device Class: USB xHCI Controller
Revision ID: 2
PCI Address (Bus:Device:Function) Number: 2:0:0
Hardware ID: PCI\VEN_1912&DEV_0015&SUBSYS_76931462&REV_02
[PCI Express]
Version: 2.0
Maximum Link Width: 1x
L0s Exit Latency: 2 - 4 us
L1 Exit Latency: >64 us
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 FE300000
[Features]
USB Version Supported: 3.0
Driver Manufacturer: Generic USB xHCI Host Controller
Driver Description: USB xHCI Compliant Host Controller
Driver Date: 09-Apr-2018
DeviceInstanceId PCI\VEN_1912&DEV_0015&SUBSYS_76931462&REV_02\4&2D8451E4&0&0048
Location Paths PCIROOT(0)#PCI(0900)#PCI(0000)
USB Root Hub --------------------------------------------------------------
[Port1] : No Device Connected ---------------------------------------------
[Port2] : No Device Connected ---------------------------------------------
[Port3] : No Device Connected ---------------------------------------------
[Port4] : No Device Connected ---------------------------------------------
ATI/AMD RD890/RD9x0 - PCI Express Port (GPP3a port 5) ---------------------
Device Name: ATI/AMD RD890/RD9x0 - PCI Express Port (GPP3a port 5)
Original Device Name: ATI/AMD RD890/RD9x0 - PCI Express Port (GPP3a port 5)
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:10:0
Hardware ID: PCI\VEN_1002&DEV_5A1D&SUBSYS_00000000&REV_00
[PCI Express]
Version: 2.0
[System Resources]
[Features]
DeviceInstanceId PCI\VEN_1002&DEV_5A1D&SUBSYS_76931462&REV_00\3&11583659&1&50
Location Paths PCIROOT(0)#PCI(0A00)
PCI Express x2 Bus #3 -----------------------------------------------------
Revision ID: 2
PCI Address (Bus:Device:Function) Number: 3:0:0
[PCI Express]
Version: 2.0
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 FE200000
[Features]
DeviceInstanceId PCI\VEN_1912&DEV_0015&SUBSYS_76931462&REV_02\4&24645B7D&0&0050
Location Paths PCIROOT(0)#PCI(0A00)#PCI(0000)
[Port3] : USB Composite Device --------------------------------------------
[Device Information]
Device Manufacturer: Logitech
Product Name: USB Receiver
Serial Number: N/A
USB Version Supported: 2.00
USB Device Speed: USB 1.1 Full-speed
Driver Description: USB Composite Device
Hardware ID: USB\VID_046D&PID_C537
Driver Manufacturer: (Standard USB Host Controller)
DeviceInstanceId USB\VID_046D&PID_C537\6&2AEFC9AD&0&3
Location Paths PCIROOT(0)#PCI(0A00)#PCI(0000)#USBROOT(0)#USB(3)
[Port4] : USB Composite Device --------------------------------------------
Product Name: Gaming Keyboard G105
Serial Number: N/A
USB Version Supported: 1.10
USB Device Speed: USB 1.1 Low-speed
Hardware ID: USB\VID_046D&PID_C248
DeviceInstanceId USB\VID_046D&PID_C248\6&2AEFC9AD&0&4
Location Paths PCIROOT(0)#PCI(0A00)#PCI(0000)#USBROOT(0)#USB(4)
ATI/AMD SB800/Hudson-1 - SATA (Native IDE) Controller ---------------------
Device Name: ATI/AMD SB800/Hudson-1 - SATA (Native IDE) Controller
Original Device Name: ATI/AMD SB800/Hudson-1 - SATA (Native IDE) Controller
Device Class: IDE Controller
Revision ID: 40
PCI Address (Bus:Device:Function) Number: 0:17:0
PCI Latency Timer: 32
Hardware ID: PCI\VEN_1002&DEV_4390&SUBSYS_76931462&REV_40
[System Resources]
Interrupt Line: IRQ19
I/O Base Address 0 F090
I/O Base Address 1 F080
I/O Base Address 2 F070
I/O Base Address 3 F060
I/O Base Address 4 F050
Memory Base Address 5 FE40B000
[Features]
Running At 66 MHz: Capable
Driver Manufacturer: Advanced Micro Devices
Driver Description: AMD SATA Controller (IDE Mode)
Driver Provider: Advanced Micro Devices
Driver Version: 5.2.2.179
Driver Date: 27-Jun-2013
DeviceInstanceId PCI\VEN_1002&DEV_4390&SUBSYS_76931462&REV_40\3&11583659&1&88
Location Paths PCIROOT(0)#PCI(1100)
ATI/AMD SP5100 (SB700/SB800) - USB OHCI Controller ------------------------
Device Name: ATI/AMD SP5100 (SB700/SB800) - USB OHCI Controller
Original Device Name: ATI/AMD SP5100 (SB700/SB800) - USB OHCI Controller
Device Class: USB OHCI Controller
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:18:0
Hardware ID: PCI\VEN_1002&DEV_4397&SUBSYS_76931462&REV_00
[System Resources]
Interrupt Line: IRQ18
Memory Base Address 0 FE40A000
[Features]
Fast Back-to-Back Transactions: Capable
USB Version Supported: 1.0
Driver Description: Standard OpenHCD USB Host Controller
DeviceInstanceId PCI\VEN_1002&DEV_4397&SUBSYS_76931462&REV_00\3&11583659&1&90
Location Paths PCIROOT(0)#PCI(1200)
[Port5] : No Device Connected ---------------------------------------------
ATI/AMD SP5100 (SB700/SB800) - USB 2.0 EHCI Controller --------------------
Device Name: ATI/AMD SP5100 (SB700/SB800) - USB 2.0 EHCI Controller
Original Device Name: ATI/AMD SP5100 (SB700/SB800) - USB 2.0 EHCI Controller
Device Class: USB EHCI Controller
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:18:2
Hardware ID: PCI\VEN_1002&DEV_4396&SUBSYS_76931462&REV_00
[System Resources]
Interrupt Line: IRQ17
Memory Base Address 0 FE409000
[Features]
Driver Description: Standard Enhanced PCI to USB Host Controller
DeviceInstanceId PCI\VEN_1002&DEV_4396&SUBSYS_76931462&REV_00\3&11583659&1&92
Location Paths PCIROOT(0)#PCI(1202)
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:19:0
[System Resources]
Memory Base Address 0 FE408000
[Features]
DeviceInstanceId PCI\VEN_1002&DEV_4397&SUBSYS_76931462&REV_00\3&11583659&1&98
Location Paths PCIROOT(0)#PCI(1300)
[Port2] : USB Composite Device --------------------------------------------
Product Name: Logitech G430 Gaming Headset
Serial Number: N/A
Hardware ID: USB\VID_046D&PID_0A4D
DeviceInstanceId USB\VID_046D&PID_0A4D\5&1700BC1B&0&2
Location Paths PCIROOT(0)#PCI(1300)#USBROOT(0)#USB(2)
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:19:2
[System Resources]
Memory Base Address 0 FE407000
[Features]
DeviceInstanceId PCI\VEN_1002&DEV_4396&SUBSYS_76931462&REV_00\3&11583659&1&9A
Location Paths PCIROOT(0)#PCI(1302)
ATI/AMD SB800/Hudson-1 - SMBus and ACPI Controller ------------------------
Device Name: ATI/AMD SB800/Hudson-1 - SMBus and ACPI Controller
Original Device Name: ATI/AMD SB800/Hudson-1 - SMBus and ACPI Controller
Device Class: SMBus (System Management Bus)
Revision ID: 42
PCI Address (Bus:Device:Function) Number: 0:20:0
Hardware ID: PCI\VEN_1002&DEV_4385&SUBSYS_76931462&REV_42
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
Driver Manufacturer: Advanced Micro Devices, Inc
Driver Description: AMD SMBus
Driver Provider: Advanced Micro Devices, Inc
Driver Version: 5.12.0.38
DeviceInstanceId PCI\VEN_1002&DEV_4385&SUBSYS_76931462&REV_42\3&11583659&1&A0
Location Paths PCIROOT(0)#PCI(1400)
ATI/AMD SB800 - IDE Controller --------------------------------------------
Device Name: ATI/AMD SB800 - IDE Controller
Original Device Name: ATI/AMD SB800 - IDE Controller
Revision ID: 40
PCI Address (Bus:Device:Function) Number: 0:20:1
Hardware ID: PCI\VEN_1002&DEV_439C&SUBSYS_76931462&REV_40
[System Resources]
I/O Base Address 0 0
I/O Base Address 1 0
I/O Base Address 2 0
I/O Base Address 3 0
I/O Base Address 4 F000
[Features]
Driver Description: AMD PCI IDE Controller
DeviceInstanceId PCI\VEN_1002&DEV_439C&SUBSYS_76931462&REV_40\3&11583659&1&A1
Location Paths PCIROOT(0)#PCI(1401)
ATI/AMD SB800/Hudson-1 - High Definition Audio Controller -----------------
Device Name: ATI/AMD SB800/Hudson-1 - High Definition Audio Controller
Original Device Name: ATI/AMD SB800/Hudson-1 - High Definition Audio Controller
Revision ID: 40
PCI Address (Bus:Device:Function) Number: 0:20:2
Hardware ID: PCI\VEN_1002&DEV_4383&SUBSYS_D6931462&REV_40
[System Resources]
Interrupt Line: IRQ16
Memory Base Address 0 FE400000
[Features]
Driver Description: High Definition Audio Bus
Driver Version: 15.20.0.1
Driver Date: 20-Jul-2015
DeviceInstanceId PCI\VEN_1002&DEV_4383&SUBSYS_D6931462&REV_40\3&11583659&1&A2
Location Paths PCIROOT(0)#PCI(1402)
ATI/AMD SB800/Hudson-1 - LPC Bridge ---------------------------------------
Device Name: ATI/AMD SB800/Hudson-1 - LPC Bridge
Original Device Name: ATI/AMD SB800/Hudson-1 - LPC Bridge
Device Class: PCI-to-ISA Bridge
Revision ID: 40
PCI Address (Bus:Device:Function) Number: 0:20:3
Hardware ID: PCI\VEN_1002&DEV_439D&SUBSYS_76931462&REV_40
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
Driver Description: PCI standard ISA bridge
DeviceInstanceId PCI\VEN_1002&DEV_439D&SUBSYS_76931462&REV_40\3&11583659&1&A3
Location Paths PCIROOT(0)#PCI(1403)
ATI/AMD SB800/Hudson-1 - PCI-to-PCI Host Bridge ---------------------------
Device Name: ATI/AMD SB800/Hudson-1 - PCI-to-PCI Host Bridge
Original Device Name: ATI/AMD SB800/Hudson-1 - PCI-to-PCI Host Bridge
Revision ID: 40
PCI Address (Bus:Device:Function) Number: 0:20:4
PCI Latency Timer: 64
Hardware ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_40
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_40\3&11583659&1&A4
Location Paths PCIROOT(0)#PCI(1404)
PCI Bus #4 ----------------------------------------------------------------
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:20:5
Hardware ID: PCI\VEN_1002&DEV_4399&SUBSYS_76931462&REV_00
[System Resources]
Interrupt Pin: INTC#
Memory Base Address 0 FE406000
[Features]
DeviceInstanceId PCI\VEN_1002&DEV_4399&SUBSYS_76931462&REV_00\3&11583659&1&A5
Location Paths PCIROOT(0)#PCI(1405)
ATI/AMD SB800/Hudson-1 - PCI Express Port 0 -------------------------------
Device Name: ATI/AMD SB800/Hudson-1 - PCI Express Port 0
Original Device Name: ATI/AMD SB800/Hudson-1 - PCI Express Port 0
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:21:0
Hardware ID: PCI\VEN_1002&DEV_43A0&SUBSYS_00000000&REV_00
[PCI Express]
Version: 2.0
Current Link Speed: 2.5 GT/s
L0s Exit Latency: < 64 ns
L1 Exit Latency: < 1 us
[System Resources]
Interrupt Line: N/A
[Features]
DeviceInstanceId PCI\VEN_1002&DEV_43A0&SUBSYS_00001002&REV_00\3&11583659&1&A8
Location Paths PCIROOT(0)#PCI(1500)
PCI Express x1 Bus #5 -----------------------------------------------------
RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC -------------
Device Name: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
Original Device Name: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
Device Class: Ethernet Adapter
Revision ID: 6
PCI Address (Bus:Device:Function) Number: 5:0:0
Hardware ID: PCI\VEN_10EC&DEV_8168&SUBSYS_76931462&REV_06
[PCI Express]
Version: 1.1
Maximum Link Speed: 2.5 GT/s
L0s Exit Latency: >4 us
L1 Exit Latency: 32 - 64 us
[System Resources]
Interrupt Line: N/A
I/O Base Address 0 D000
Memory Base Address 2 FE104000
Memory Base Address 4 FE100000
[Features]
Driver Manufacturer: Realtek
Driver Description: Realtek PCIe GbE Family Controller
Driver Provider: Realtek
Driver Version: 10.27.511.2018
Driver Date: 10-May-2018
DeviceInstanceId PCI\VEN_10EC&DEV_8168&SUBSYS_76931462&REV_06\4&17D6121&0&00A8
Location Paths PCIROOT(0)#PCI(1500)#PCI(0000)
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:22:0
[System Resources]
Memory Base Address 0 FE405000
[Features]
DeviceInstanceId PCI\VEN_1002&DEV_4397&SUBSYS_76931462&REV_00\3&11583659&1&B0
Location Paths PCIROOT(0)#PCI(1600)
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:22:2
[System Resources]
Memory Base Address 0 FE404000
[Features]
DeviceInstanceId PCI\VEN_1002&DEV_4396&SUBSYS_76931462&REV_00\3&11583659&1&B2
Location Paths PCIROOT(0)#PCI(1602)
AMD Family 15h Models 00h-0Fh CPU - HyperTransport Technology Configuration
Device Name: AMD Family 15h Models 00h-0Fh CPU - HyperTransport Technology Configuration
Original Device Name: AMD Family 15h Models 00h-0Fh CPU - HyperTransport Technology Configuration
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:24:0
Hardware ID: PCI\VEN_1022&DEV_1600&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1600&SUBSYS_00000000&REV_00\3&11583659&1&C0
Location Paths PCIROOT(0)#PCI(1800)
AMD Family 15h Models 00h-0Fh CPU - Address Map ---------------------------
Device Name: AMD Family 15h Models 00h-0Fh CPU - Address Map
Original Device Name: AMD Family 15h Models 00h-0Fh CPU - Address Map
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:24:1
Hardware ID: PCI\VEN_1022&DEV_1601&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1601&SUBSYS_00000000&REV_00\3&11583659&1&C1
Location Paths PCIROOT(0)#PCI(1801)
AMD Family 15h Models 00h-0Fh CPU - DRAM Controller -----------------------
Device Name: AMD Family 15h Models 00h-0Fh CPU - DRAM Controller
Original Device Name: AMD Family 15h Models 00h-0Fh CPU - DRAM Controller
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:24:2
Hardware ID: PCI\VEN_1022&DEV_1602&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1602&SUBSYS_00000000&REV_00\3&11583659&1&C2
Location Paths PCIROOT(0)#PCI(1802)
AMD Family 15h Models 00h-0Fh CPU - Miscellaneous Control -----------------
Device Name: AMD Family 15h Models 00h-0Fh CPU - Miscellaneous Control
Original Device Name: AMD Family 15h Models 00h-0Fh CPU - Miscellaneous Control
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:24:3
Hardware ID: PCI\VEN_1022&DEV_1603&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1603&SUBSYS_00000000&REV_00\3&11583659&1&C3
Location Paths PCIROOT(0)#PCI(1803)
AMD Family 15h Models 00h-0Fh CPU - Miscellaneous Control 2 ---------------
Device Name: AMD Family 15h Models 00h-0Fh CPU - Miscellaneous Control 2
Original Device Name: AMD Family 15h Models 00h-0Fh CPU - Miscellaneous Control 2
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:24:4
Hardware ID: PCI\VEN_1022&DEV_1604&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1604&SUBSYS_00000000&REV_00\3&11583659&1&C4
Location Paths PCIROOT(0)#PCI(1804)
AMD Family 15h Models 00h-0Fh CPU - Miscellaneous Control 3 ---------------
Device Name: AMD Family 15h Models 00h-0Fh CPU - Miscellaneous Control 3
Original Device Name: AMD Family 15h Models 00h-0Fh CPU - Miscellaneous Control 3
Revision ID: 0
PCI Address (Bus:Device:Function) Number: 0:24:5
Hardware ID: PCI\VEN_1022&DEV_1605&SUBSYS_00000000&REV_00
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
DeviceInstanceId PCI\VEN_1022&DEV_1605&SUBSYS_00000000&REV_00\3&11583659&1&C5
Location Paths PCIROOT(0)#PCI(1805)
Video Adapter -------------------------------------------------------------
NVIDIA GeForce GTX 1050 Ti ------------------------------------------------
[Video chipset]
Video Chipset: NVIDIA GeForce GTX 1050 Ti
Video Chipset Codename: GP107-400
Video Memory: 4096 MBytes of GDDR5 SDRAM [Micron]
[Video Card]
Video Card: GIGABYTE GTX 1050 Ti OC (GV-N105TOC-4GD)
Video Bus: PCIe v2.0 x16 (5.0 GT/s) @ x4 (5.0 GT/s)
Video RAMDAC: Integrated RAMDAC
Video BIOS Version: 86.07.39.00.55
Video Chipset Revision: A1
[Performance]
Processor Clock: 1316.0 MHz
Video Unit Clock: 1177.0 MHz
Memory Clock: 1752.0 MHz (Effective 7008.0 MHz)
Memory Bus Width: 128-bit
Number Of ROPs: 32
Number Of Unified Shaders: 768
Number Of TMUs (Texture Mapping Units): 48
NVIDIA SLI Capability: Capable
NVIDIA SLI Status: Not Present
PCI Location (Bus:Dev:Fnc): 1:00:0
Monitor -------------------------------------------------------------------
Acer [Unknown Model: ACR02CA] ---------------------------------------------
Monitor Name: Acer [Unknown Model: ACR02CA]
Monitor Name (Manuf): S271HL
Serial Number: LUWAA0098524
Date Of Manufacture: Week: 38, Year: 2017
Monitor Hardware ID: Monitor\ACR02CA
Max. Vertical Size: 34 cm
Max. Horizontal Size: 60 cm
Horizontal Frequency: 31 - 83 kHz
Vertical Frequency: 56 - 76 Hz
Maximum Pixel Clock: 220 MHz
[Advanced parameters]
Input Signal: Digital
Display Type: RGB color
Gamma Factor: 2.20
[DPMS Modes]
Standby: Supported
Suspend: Supported
Active Off: Not Supported
Standard Colour Space: Not Supported
Preferred Timing Mode: Supported
Default GTF Supported: Not Supported
DFP 1.x Compatible: No
[Supported Video Modes]
1152 x 864 75 Hz
1280 x 960 60 Hz
1280 x 1024 60 Hz
1280 x 720 60 Hz
1280 x 800 60 Hz
1440 x 900 60 Hz
1680 x 1050 60 Hz
1920 x 1080 60 Hz
1920 x 1080 598 x 336 mm, Pixel Clock 148.50 MHz
Hewlett-Packard w1707 (Digital) -------------------------------------------
Monitor Name: Hewlett-Packard w1707 (Digital)
Monitor Name (Manuf): HP w1707
Serial Number: CNC8320MYD
Date Of Manufacture: Week: 32, Year: 2008
Monitor Hardware ID: Monitor\HWP2801
Max. Vertical Size: 23 cm
Max. Horizontal Size: 37 cm
Horizontal Frequency: 24 - 83 kHz
Vertical Frequency: 50 - 76 Hz
Maximum Pixel Clock: 140 MHz
Gamma Factor: 2.20
[DPMS Modes]
Standby: Not Supported
Suspend: Not Supported
Active Off: Supported
1280 x 960 60 Hz
1280 x 1024 60 Hz
1280 x 1024 75 Hz
1440 x 900 60 Hz
1440 x 900 370 x 230 mm, Pixel Clock 106.50 MHz
Drives --------------------------------------------------------------------
(S)ATA/ATAPI Drives -------------------------------------------------------
Samsung SSD 860 EVO 500GB -------------------------------------------------
Drive Controller: Serial ATA 6Gb/s @ 6Gb/s
Drive Model: Samsung SSD 860 EVO 500GB
Drive Revision: RVT01B6Q
Drive Serial Number: S3Z1NB0K827863L
World Wide Name: 5002538E40657D63
Drive Capacity: 476,940 MBytes (500 GB)
Drive Capacity [MB]: 476940
Media Rotation Rate: SSD Drive (Non-rotating)
Nominal Form Factor: 2.5"
ATA Major Version Supported: ATA/ATAPI-5, ATA/ATAPI-6, ATA/ATAPI-7, ATA8-ACS, ACS-4
ATA Minor Version Supported: ACS-4 Revision 5
ATA Transport Version Supported: SATA 3.1
[Drive Geometry]
Number of Cylinders: 16383
Number of Heads: 16
Sectors Per Track: 63
Number of Sectors: 16514064
Total 32-bit LBA Sectors: 268435455
Total 48-bit LBA Sectors: 976773168
Logical Sector Size: 512 Bytes
Cache Buffer Size: N/A
[Transfer Modes]
Sectors Per Interrupt: Total: 1, Active: 1
Max. PIO Transfer Mode: 4
Multiword DMA Mode: Total: 2, Active: -
Singleword DMA Mode: Total: -, Active: -
Ultra-DMA Mode: Total: 6 (ATA-133), Active: 6 (ATA-133)
Max. Multiword DMA Transfer Rate: 16.7 MBytes/s
Max. PIO with IORDY Transfer Rate: 16.7 MBytes/s
Max. PIO w/o IORDY Transfer Rate: 16.7 MBytes/s
Native Command Queuing: Supported, Max. Depth: 32
TRIM Command: Supported (Deterministic Read After TRIM, Words = 0)
[Device flags]
Fixed Drive: Present
Removable Drive: Not Present
Magnetic Storage: Present
LBA Mode: Supported
DMA Mode: Supported
IORDY: Supported
IORDY Disableable: Supported
[Features]
Write Cache: Present, Active
S.M.A.R.T. Feature: Present, Active
Security Feature: Present, Inactive
Removable Media Feature: Not Present, Disabled
Power Management: Present, Active
Advanced Power Management: Not Present, Inactive
Packet Interface: Not Present, Disabled
Look-Ahead Buffer: Present, Active
Host Protected Area: Present, Enabled
Power-Up In Standby: Not Suppported, Inactive
Automatic Acoustic Management: Not Suppported, Inactive
48-bit LBA: Supported, Active
Host-Initiated Link Power Management: Not Supported
Device-Initiated Link Power Management: Supported, Disabled
In-Order Data Delivery: Not Supported
Hardware Feature Control: Supported, Enabled
Software Settings Preservation: Supported, Enabled
NCQ Autosense: Not Supported
Link Power State Device Sleep: Supported, Disabled
Hybrid Information Feature: Not Supported
Rebuild Assist: Not Supported
Power Disable: Not Supported
All Write Cache Non-Volatile: Not Supported
Extended Number of User Addressable Sectors: Not Supported
CFast Specification: Not Supported
NCQ Priority Information: Not Supported
Host Automatic Partial to Slumber Transitions: Not Supported
Device Automatic Partial to Slumber Transitions: Not Supported
NCQ Streaming: Not Supported
NCQ Queue Management Command: Not Supported
DevSleep to Reduced Power State: Supported
Extended Power Conditions Feature: Not Supported
Sense Data Reporting Feature: Not Supported
Free-Fall Control Feature: Not Supported
Write-Read-Verify Feature: Supported, Disabled
[Security]
Security Feature: Supported
Security Status: Disabled
Security Locked: Disabled
Security Frozen: Enabled
Enhanced Security Erase: Supported
Sanitize Feature: Not Supported
Sanitize Device - Crypto Scramble: Not Supported
Sanitize Device - Overwrite: Not Supported
Sanitize Device - Block Erase: Not Supported
Sanitize Device - Antifreeze Lock: Not Supported
Device Encrypts All User Data: Supported
Trusted Computing: Supported
[Self-Monitoring, Analysis and Reporting Technology (S.M.A.R.T.)]
[05] Reallocated Sector Count: 100/10, Worst: 100
[09] Power-On Hours/Cycle Count: 99/Always OK, Worst: 99 (295 hours / 12.3 days)
[0C] Power Cycle Count: 99/Always OK, Worst: 99 (Data = 66,0)
[B1] Wear Leveling Count: 99/Always OK, Worst: 99 (Data = 1,0)
[B3] Used Reserved Block Count (Total): 100/10, Worst: 100
[B5] Program Fail Count (Total): 100/10, Worst: 100
[B6] Erase Fail Count (Total): 100/10, Worst: 100
[B7] Runtime Bad Block (Total): 100/10, Worst: 100
[BB] Uncorrectable Error Count: 100/Always OK, Worst: 100
[BE] Airflow Temperature: 64/Always OK, Worst: 56 (36.0 °C)
[C3] ECC Error Rate: 200/Always OK, Worst: 200
[C7] SATA CRC Error Count: 99/Always OK, Worst: 99 (Data = 1,0)
[EB] POR Recovery Count: 99/Always OK, Worst: 99 (Data = 4,0)
[F1] Total Host Writes: 99/Always OK, Worst: 99 (Data = 1878417778,0)
Drive Remaining Life 99%
[Device Statistics]
Lifetime Power-On Resets: 66
Power-on Hours: 295
Logical Sectors Written: 1878417778
Logical Sectors Read: 2819627882
Number of Write Commands: 24625177
Number of Read Commands: 55635850
Number of Reported Uncorrectable Errors: 0
Resets Between Command Acceptance and Completion: 0
Current Temperature: 36 °C
Maximum Operating Temperature: 70 °C
Lifetime Temperature: 21 - 44 °C
Number of Hardware Resets: 392
Number of ASR Events: 0
Number of Interface CRC Errors: 1
Used Endurance Indicator: 0%
ASUS DRW-24F1ST c -------------------------------------------------------
Drive Model: ASUS DRW-24F1ST c
Drive Revision: 1.01
Serial Number: G8D0CL042189
Device Type: DVD+R DL
[Device capabilities]
Drive can read: CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
Drive can write: CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
Audio ---------------------------------------------------------------------
Audio Adapter: ATI/AMD SB800/Hudson-1 - High Definition Audio Controller
Audio Controller Hardware ID: PCI\VEN_1002&DEV_4383&SUBSYS_D6931462&REV_40
High Definition Audio Codec: RealTek ALC887
Audio Codec Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_00000000
Driver Description: Realtek High Definition Audio
Driver Provider: Realtek Semiconductor Corp.
Driver Version: 6.0.1.8264
Driver Date: 02-Oct-2017
DeviceInstanceId HDAUDIO\FUNC_01&VEN_10EC&DEV_0887&SUBSYS_1462D693&REV_1003\4&16B1A570&0&0001
Audio Adapter: NVIDIA GP107 - High Definition Audio Controller
Audio Controller Hardware ID: PCI\VEN_10DE&DEV_0FB9&SUBSYS_37321458&REV_A1
High Definition Audio Codec: nVidia
Audio Codec Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0080&SUBSYS_00000000
Driver Description: NVIDIA High Definition Audio
Driver Provider: NVIDIA Corporation
Driver Version: 1.3.37.4
Driver Date: 02-Apr-2018
DeviceInstanceId HDAUDIO\FUNC_01&VEN_10DE&DEV_0080&SUBSYS_14583732&REV_1001\5&4DFF7F8&0&0001
Network -------------------------------------------------------------------
Network Card: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
Vendor Description: Realtek PCIe GbE Family Controller
MAC Address: 4C-CC-6A-2E-E9-7C
[Capabilities]
Maximum Link Speed: 1000 Mbps
Transmit Buffer Size: 193792 Bytes
Receive Buffer Size: 775168 Bytes
Ports ---------------------------------------------------------------------
Serial Ports --------------------------------------------------------------
Parallel Ports ------------------------------------------------------------
Standard OpenHCD USB Host Controller --------------------------------------
Root Hub ------------------------------------------------------------------
Serial Number: N/A
Standard Enhanced PCI to USB Host Controller ------------------------------
USB xHCI Compliant Host Controller ----------------------------------------
Serial Number: N/A
Serial Number: N/A
As for the monitor temps, I dont think it has anything to do with this. I have two different monitors, one newer one and one somewhat older one. They both freeze at the same time, not individually, so it leads me to believe it has nothing to do with it.
nmsuk
I didn't mean the monitor but to monitor the temps in hwinfo :)
nmsuk
In hwinfo click on sensors. It'll give you lots to look through. Check the temps it reports.
JeronStevens
Member
I hope thats the info you need.
More information, I ran stress tests with different programs in the past, and even with everything at 100% my temps were good and no freezes.
nmsuk
I've been thinking, we should check that ssd out. From an admin cmd prompt, can you do a chkdsk /F this will check the drive for errors and attempt to fix any it finds. It may take a while and it being your system drive will require a reboot.
JeronStevens
Member
I have already done that. I’ve tested my SSD and it says it’s fine, no bad blocks or anything... I had simmilar problems when I had a HDD, do you think maybe it’s the cables?
JeronStevens
Member
I have been looking around some more in the event viewer. Multiple times a day I am getting error: Event ID: 10016. This is happening a few minutes before my freezes sometimes, but its not logged at the same time as my freezes. there is a different forum here saying that this error is freezing his computer, could this possibly be some sort of issue? I have thousands of these 10016 errors in my logs, multiple multiple daily. Thanks for all your help so far nmsuk. This has been a major issue for me, and I just wish I had the answers.
nmsuk
Can I see the whole output from event viewer for those errors?
JeronStevens
Member
<Event xmlns="Link Removed"> - <System> <Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" /> <EventID Qualifiers="0">10016</EventID> <Version>0</Version> <Level>2</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x8080000000000000</Keywords> <TimeCreated SystemTime="2018-11-28T00:37:42.734890600Z" /> <EventRecordID>17182</EventRecordID> <Correlation /> <Execution ProcessID="516" ThreadID="7796" /> <Channel>System</Channel> <Computer>DESKTOP-9GESDGI</Computer> <Security UserID="S-1-5-21-4083421872-2189924615-2752685606-1001" /> </System> - <EventData> <Data Name="param1">application-specific</Data> <Data Name="param2">Local</Data> <Data Name="param3">Activation</Data> <Data Name="param4">{D63B10C5-BB46-4990-A94F-E40B9D520160}</Data> <Data Name="param5">{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}</Data> <Data Name="param6">DESKTOP-9GESDGI</Data> <Data Name="param7">Jeron</Data> <Data Name="param8">S-1-5-21-4083421872-2189924615-2752685606-1001</Data> <Data Name="param9">LocalHost (Using LRPC)</Data> <Data Name="param10">Unavailable</Data> <Data Name="param11">Unavailable</Data> </EventData> </Event>
I already tried to solve this issue, i used some online forums to help. Windows 10 Event 10016 Fix: The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID {D63B10C5-BB46-4990-A94F-E40B9D520160} and APPID {9CA88EE3-ACB7-47C8-AFC4-AB702511C276} to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.I a
But I get errors when I try to complete these steps.
nmsuk
after setting the reg entries reboot before doing the other steps.
JeronStevens
Member
Upon restarting the issue is still the same. I get an error : Link Removed and the add button is grayed out. I also have two runtime brokers located in my DCOM config, which investigating online is common for some reason. I could not find any remedy that worked online for the grayed button...
I'm worried that even if i fix this error, it may not even be the thing causing my freezes... I wish I knew more about the advanced side of computers...
