JeronStevens
Member
For a while now my computer has been freezing up, quite odd freezes as well. I can move my mouse, and interact with some objects, but i cant do things such as open folders/files/start menu. If i have a browser open, i can still scroll on the page, but if i click on anything it wont load. its like whatever is currently loaded is ok, but whatever my computer needs to load wont open. Sometimes there are two mouse pointers on my screen as well, but i can only control one. There are no logs in the task manager either. this usually happens 1-2 times a day for 30-60 seconds, nothing causes it.
I also noticed the fans on my GPU are almost never on, idk why that is.
I was thinking it was my SSD that was going bad, but i did the tests on it and it says there are no problems with it, so that wont explain why it cant load.
Im not too aware of how power supply's act when they are dying, could it be that?
I dont think its my GPU, but some of the more recent wackiness is happening is making me doubt that.
Occasionally my desktop background just turns white. also today both my displays just turned off, no warning, and i had to restart my PC, and all is working good.
Yesterday i shut down my PC, but a few minutes later it wasn't shut down, the main monitor was off, and stuff, but my side monitor was black except for the task manager window?!
Samsung 860 EVO 500GB
GTX 1050 ti
AMD 8300 8core
8gb ddr3 ram
400W powwer supply
I can also upload some videos of it being weird, its mostly me just clicking icons/minimizing windows and nothing happens.
Please help me, I am really at a loss here...
Can you open a adim command prompt and run sfc /scannow and on completing that run dism /online /cleanup-image /restorehealth hopefully you just have corrupted system files and they should sort that out. If not we'll look at other remedies we can try.
My computer has been on for 10 minutes or so and this is the amount of errors i'm getting from 10016 Link Removed
I haven't had any freezes, so I'm starting to think this doesn't have anything to do with the weird freezes.[/QUOTE]
Just been checking my machine and have about the same amount of them and no freezes. Not sure why the fix though won't complete. I'm hoping @Neemobeer see's this as he may know how to solve that issue to see if it helps.
Thanks so much man. I cant stand these random freezes. If i can recall, it most commonly happens when im browsing online, but not always, maybe i can look into that.
