VIDEO Computer Freezing for first time but fine after disk check (interpretation of disk chk results)...
Paolo78
Was having problems for the first time with my desktop over the weekend - Windows 7, Quad Core, 16GB memory, GTX 550Ti graphics card, enhanced power supply.
I think it may have been a result of some trouble I've been having with an external hard drive.
It completely froze up computer every few minutes --- went thru a million tests to attempt to solve problem - nothing was effective - came across this video and set disk check over night. Since then, computer is working well but want to make sure it's going to stay that way and anticipate any problems.
If anyone would be kind enough to take a minute to take a look at my Winit log file and shoot some quick feedback on status/what you recommend from here on out, I would be very grateful.
Let me know if you need any or log files..etc...
Thanks - let me know soon as you can - log file attached
I would be concerned with the large number of read errors. Corruption is generally not caused by a bad hard disk. Read errors are disk-related.
As an absolute minimum, I would rerun chkdsk each day for the next week or so and then maybe once a week until you are convinced that there are no further problems. If the problem was some kind of one-time corruption, it may be cleaned up. However, if you see any new read errors, I would replace the drive. Backup the drive now, while you still can, in case it is in the process of failing.
Paolo78
I know it's a bit of a pain to check a log and provide feedback - if anyone could do it, I'd immensely appreciate it. Here's the log below (tried to space to make easier to read) =
+ System
- Provider
[ Name] Microsoft-Windows-Wininit
[ Guid] {206f6dea-d3c5-4d10-bc72-989f03c8b84b}
[ EventSourceName] Wininit
- EventID 1001
[ Qualifiers] 16384
Version 0
Level 4
Task 0
Opcode 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2014-07-21T10:57:36.000000000Z
EventRecordID 45049
Correlation
- Execution
[ ProcessID] 0
[ ThreadID] 0
Channel Application
Computer PC-PC
Security
- EventData
Checking file system on C: The type of the file system is NTFS. A disk check has been scheduled. Windows will now check the disk. CHKDSK is verifying files (stage 1 of 5)... Read failure with status 0xc0000185 at offset 0x8153568000 for 0x1000 bytes. File record segment 103212 is unreadable. Read failure with status 0xc0000185 at offset 0x8153568000 for 0x1000 bytes. File record segment 103213 is unreadable.
Read failure with status 0xc0000185 at offset 0x8153568000 for 0x1000 bytes. File record segment 103214 is unreadable. Read failure with status 0xc0000185 at offset 0x8153568000 for 0x1000 bytes. File record segment 103215 is unreadable.
Read failure with status 0xc0000185 at offset 0x8155828000 for 0x1000 bytes. File record segment 138796 is unreadable. Read failure with status 0xc0000185 at offset 0x8155828000 for 0x1000 bytes. File record segment 138797 is unreadable. Read failure with status 0xc0000185 at offset 0x8155828000 for 0x1000 bytes. File record segment 138798 is unreadable.
Read failure with status 0xc0000185 at offset 0x8155828000 for 0x1000 bytes. File record segment 138799 is unreadable. Read failure with status 0xc0000185 at offset 0x8155829000 for 0x1000 bytes. File record segment 138800 is unreadable. Read failure with status 0xc0000185 at offset 0x8155829000 for 0x1000 bytes. File record segment 138801 is unreadable.
Read failure with status 0xc0000185 at offset 0x8155829000 for 0x1000 bytes. File record segment 138802 is unreadable. Read failure with status 0xc0000185 at offset 0x8155829000 for 0x1000 bytes. File record segment 138803 is unreadable.
Read failure with status 0xc0000185 at offset 0x815582a000 for 0x1000 bytes. File record segment 138804 is unreadable. Read failure with status 0xc0000185 at offset 0x815582a000 for 0x1000 bytes. File record segment 138805 is unreadable.
Read failure with status 0xc0000185 at offset 0x815582a000 for 0x1000 bytes. File record segment 138806 is unreadable. Read failure with status 0xc0000185 at offset 0x815582a000 for 0x1000 bytes. File record segment 138807 is unreadable.
Read failure with status 0xc0000185 at offset 0x8155be8000 for 0x1000 bytes. Deleted corrupt attribute list entry with type code 128 in file 139524. Unable to find child frs 0x22d2f with sequence number 0x23. The attributes with same type code 0x80 but different instance tags 0x0 and 0x0 have non-contiguous VCN numbers 0x55e00 and 0x578c0 respectively in file 0x22104. The attribute of type 0x80 and instance tag 0x0 in file 0x22104 has allocated length of 0xd4d7e000 instead of 0x578f0000. Deleted corrupt attribute list entry with type code 128 in file 139524. Unable to locate attribute with instance tag 0x0 and segment reference 0x7b000000010dc1.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 69057. Unable to locate attribute with instance tag 0x0 and segment reference 0xc6000000017088. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 94344. Unable to locate attribute with instance tag 0x0 and segment reference 0x2e800000001717b.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 94587. Unable to locate attribute with instance tag 0x0 and segment reference 0x8e000000017209. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 94729. Unable to locate attribute with instance tag 0x0 and segment reference 0xb820000000172ce.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 94926. Unable to locate attribute with instance tag 0x0 and segment reference 0x1c500000001795b. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 96603. Unable to locate attribute with instance tag 0x0 and segment reference 0x9a000000021ccf.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 138447. Unable to locate attribute with instance tag 0x0 and segment reference 0x550000000222ad. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 139949. Unable to locate attribute with instance tag 0x0 and segment reference 0x1440000000227e3.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 141283. Unable to locate attribute with instance tag 0x0 and segment reference 0x8b0000000228ac. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 141484. Unable to locate attribute with instance tag 0x0 and segment reference 0xad000000022d92.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 142738. Unable to locate attribute with instance tag 0x0 and segment reference 0x1e000000022dfe. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 142846. Unable to locate attribute with instance tag 0x0 and segment reference 0x32000000022e4a.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 142922. Unable to locate attribute with instance tag 0x0 and segment reference 0x30000000022e4d. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 142925. Unable to locate attribute with instance tag 0x0 and segment reference 0x4c000000022e76.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 142966. Unable to locate attribute with instance tag 0x0 and segment reference 0x58000000022f9f. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143263. Unable to locate attribute with instance tag 0x0 and segment reference 0x53000000022fa8.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143272. Unable to locate attribute with instance tag 0x0 and segment reference 0x6a000000022fb5. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143285. Unable to locate attribute with instance tag 0x0 and segment reference 0x235000000022fd0.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143312. Unable to locate attribute with instance tag 0x0 and segment reference 0x46000000022feb. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143339. Unable to locate attribute with instance tag 0x0 and segment reference 0x4e000000023001.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143361. Unable to locate attribute with instance tag 0x0 and segment reference 0x5f000000023027. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143399. Unable to locate attribute with instance tag 0x0 and segment reference 0x430000000230a1.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143521. Unable to locate attribute with instance tag 0x0 and segment reference 0x2400000002311b. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143643. Unable to locate attribute with instance tag 0x0 and segment reference 0x21000000023156.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143702. Unable to locate attribute with instance tag 0x0 and segment reference 0x42000000023274. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143988. Unable to locate attribute with instance tag 0x0 and segment reference 0xd2000000023275.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 143989. Unable to locate attribute with instance tag 0x0 and segment reference 0x3e0000000232f3. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 144115. Unable to locate attribute with instance tag 0x0 and segment reference 0xff00000002347f. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 144511.
Unable to locate attribute with instance tag 0x0 and segment reference 0x380000000234ed. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 144621. Unable to locate attribute with instance tag 0x0 and segment reference 0x420000000235f1. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 144881.
Unable to locate attribute with instance tag 0x0 and segment reference 0x28a000000023614. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 144916. Unable to locate attribute with instance tag 0x0 and segment reference 0x3e000000025e9f. The expected attribute type is 0x80.
Deleting corrupt attribute record (128, "") from file record segment 155295. Unable to locate attribute with instance tag 0x0 and segment reference 0x1a7000000025ed0. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 155344. Unable to locate attribute with instance tag 0x0 and segment reference 0xa9000000025ee2. The expected attribute type is 0x80.
Deleting corrupt attribute record (128, "") from file record segment 155362. Unable to locate attribute with instance tag 0x0 and segment reference 0xc6000000025eeb. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 155371. Unable to locate attribute with instance tag 0x0 and segment reference 0x70000000025efb. The expected attribute type is 0x80.
Deleting corrupt attribute record (128, "") from file record segment 155387. Unable to locate attribute with instance tag 0x0 and segment reference 0x2c000000025f46. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 155462. Unable to locate attribute with instance tag 0x0 and segment reference 0x5a000000025fc4. The expected attribute type is 0x80.
Deleting corrupt attribute record (128, "") from file record segment 155588. Unable to locate attribute with instance tag 0x0 and segment reference 0x1c000000026022. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 155682. Unable to locate attribute with instance tag 0x0 and segment reference 0x6d000000026030. The expected attribute type is 0x80.
Deleting corrupt attribute record (128, "") from file record segment 155696. Unable to locate attribute with instance tag 0x0 and segment reference 0x3a000000026060. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 155744. Unable to locate attribute with instance tag 0x0 and segment reference 0x9a000000026346. The expected attribute type is 0x80.
Deleting corrupt attribute record (128, "") from file record segment 156486. Unable to locate attribute with instance tag 0x0 and segment reference 0x3c000000026371. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 156529. Unable to locate attribute with instance tag 0x0 and segment reference 0x880000000263b5. The expected attribute type is 0x80.
Deleting corrupt attribute record (128, "") from file record segment 156597. Unable to locate attribute with instance tag 0x0 and segment reference 0xac00000002eeae. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 192174. Unable to locate attribute with instance tag 0x0 and segment reference 0x3600000002f275. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193141. Unable to locate attribute with instance tag 0x0 and segment reference 0x3c00000002f2fd.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193277. Unable to locate attribute with instance tag 0x0 and segment reference 0x1fc00000002f302. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193282. Unable to locate attribute with instance tag 0x0 and segment reference 0x8500000002f312. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193298. Unable to locate attribute with instance tag 0x0 and segment reference 0x8600000002f32b. The expected attribute type is 0x80.
Deleting corrupt attribute record (128, "") from file record segment 193323. Unable to locate attribute with instance tag 0x0 and segment reference 0xb900000002f363. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193379. Unable to locate attribute with instance tag 0x0 and segment reference 0x6200000002f396. The expected attribute type is 0x80.
Deleting corrupt attribute record (128, "") from file record segment 193430. Unable to locate attribute with instance tag 0x0 and segment reference 0x1f00000002f3d9. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193497. Unable to locate attribute with instance tag 0x0 and segment reference 0x2700000002f421.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193569. Unable to locate attribute with instance tag 0x0 and segment reference 0x1a00000002f42d. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193581. Unable to locate attribute with instance tag 0x0 and segment reference 0x5600000002f43a.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193594. Unable to locate attribute with instance tag 0x0 and segment reference 0x6600000002f43f. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193599. Unable to locate attribute with instance tag 0x0 and segment reference 0x5700000002f441.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193601. Unable to locate attribute with instance tag 0x0 and segment reference 0x8400000002f447. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193607. Unable to locate attribute with instance tag 0x0 and segment reference 0x5a00000002f465.
The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193637. Unable to locate attribute with instance tag 0x0 and segment reference 0x3600000002f486. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193670. Unable to locate attribute with instance tag 0x0 and segment reference 0x2600000002f48f. The expected attribute type is 0x80.
Deleting corrupt attribute record (128, "") from file record segment 193679. Unable to locate attribute with instance tag 0x0 and segment reference 0x3f00000002f4b0. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193712.
Unable to locate attribute with instance tag 0x0 and segment reference 0x6d00000002f4b8. The expected attribute type is 0x80. Deleting corrupt attribute record (128, "") from file record segment 193720. Unable to locate attribute with instance tag 0x0 and segment reference 0x2300000002f4d2. The expected attribute type is 0x80. Deleting
Fixer1234
