I found the culprit. In Device Manager, under Universal Serial Bus controllers, there is 1 Generic USB Hub after the disconnect event, then there are two after the connect event. There is one Generic USB Hub that is connecting and disconnecting. I disabled it and that resolved the issue. Going to work on identifying exactly what it is...probably one of my case front panel USB hubs...
