Pcgamer27
Member
i am looking for a script that copy certain folder to other location
Sources folder Sounds
destination folder
C:\Windows\Media folder
Certainly! Here is a PowerShell script you can run as Administrator to copy a folder named Sounds from your Sources directory (assuming it's next to the script or at a known path) into C:\Windows\Media:
PowerShell Script: Copy Sounds Folder to Windows Media
# Define source and destination paths (edit as needed)
$sourceFolder = "C:\Path\To\Sources\Sounds" # <-- Change to your actual path
$destinationFolder = "C:\Windows\Media\Sounds" # Create destination folder if it doesn't exist
if (!(Test-Path -Path $destinationFolder) { New-Item -Path $destinationFolder -ItemType Directory -Force
} # Copy all content, recursive, overwrite existing files
Copy-Item -Path "$sourceFolder\*" -Destination...
Copy-Item -Path "$sourceFolder\*" -Destination $destinationFolder -Recurse -Force Write-Host "Sounds copied from $sourceFolder to $destinationFolder"
How to Use
  • Edit $sourceFolder so it points to the folder containing your sounds (e.g., D:\Sources\Sounds or C:\Users\Tim\Desktop\Sources\Sounds).
  • Run PowerShell as Administrator! (You need admin rights to write to C:\Windows\Media)
  • Execute the script.
To call from Command Prompt (using a batch file):
powershell.exe -ExecutionPolicy Bypass -File "C:\Path\To\Script\CopySounds.ps1"
Copy Everything Into C:\Windows\Media
  • If you want just the contents (not the "Sounds" folder) inside C:\Windows\Media, change destination to "C:\Windows\Media".
Example for SetupComplete.cmd or Unattended:
powershell.exe -ExecutionPolicy Bypass -Command "Copy-Item -Path 'C:\Sources\Sounds\*' -Destination 'C:\Windows\Media' -Recurse -Force"
This assumes during deployment your Sources\Sounds folder is at C:\Sources\Sounds.
If you tell me the exact full path to your Sources\Sounds folder (for example, D:\Install\Sources\Sounds), I can paste the one-line command for you!
