Create and Mount VHDX Virtual Drives to Archive Projects in Windows 10/11
Create and Mount VHDX Virtual Drives to Archive Projects in Windows 10/11​
Difficulty: Intermediate | Time Required: 20 minutes
If you regularly archive old projects, client folders, photos, code repositories, design files, or research material, a VHDX virtual hard drive can be a very tidy storage option. Instead of leaving thousands of files scattered across folders, you can store an entire project inside a single .vhdx file. When you need it, you mount the VHDX and Windows treats it like a real drive with its own drive letter.
This is useful for long-term project storage, backups, moving archives between PCs, or keeping inactive work separate from your daily files. VHDX files are supported in modern Windows versions, including Windows 10 and Windows 11, and can be created using the built-in Disk Management tool.
What is a VHDX?
A VHDX is a virtual hard disk file. When mounted, it appears in File Explorer like a normal disk drive. When detached, it becomes a single portable archive file.
Prerequisites​
Before you begin, make sure you have:
Quick walkthrough
  • A PC running Windows 10 or Windows 11.
  • An account with administrator permissions.
  • Enough free disk space for your archive.
  • A destination folder where the VHDX file will be stored, such as:
  • D:\Archives
  • E:\Project_Archives
  • An external USB drive
  • A network storage location
Note:
VHDX is generally preferred over the older VHD format because it is newer, more resilient, and supports larger virtual disk sizes.
Step 1: Decide How Large the Archive Drive Should Be​
Before creating the virtual drive, estimate how much space your archived project needs.
For example:
  • Small documentation archive: 5–10 GB
  • Web/design project archive: 20–50 GB
  • Video, CAD, or media project archive: 100 GB or more
You will also need to choose between two disk types:
  • Dynamically expanding
  • Starts small and grows as files are added.
  • Best for most project archives.
  • Saves physical disk space initially.
  • Fixed size
  • Immediately uses the full size you assign.
  • May offer more predictable performance.
  • Takes longer to create if the size is large.
For archiving projects, dynamically expanding is usually the better choice.
Warning:
A dynamically expanding VHDX can grow up to the maximum size you set. Make sure the physical drive storing the VHDX has enough free space over time.
Step 2: Open Disk Management​
Disk Management console with the disk and volume list visible.
  • Right-click the Start button.
  • Select Disk Management.
    Alternatively, press Windows + R, type:
    diskmgmt.msc
    Then press Enter.
  • If prompted by User Account Control, click Yes.
Disk Management is included with Windows 10 and Windows 11 and allows you to manage physical disks, partitions, and virtual hard disks.
Step 3: Create the VHDX File​
Create and Attach Virtual Hard Disk dialog for choosing the VHDX file name, size, and type.
  • In Disk Management, click Action in the menu bar.
  • Select Create VHD.
  • In the Create and Attach Virtual Hard Disk window, click Browse.
  • Choose where you want to save the VHDX file.
    Example:
    D:\Archives\Client_Project_2024.vhdx
  • Enter a clear file name, such as:
    Website_Redesign_Archive.vhdx
  • Under Virtual hard disk size, enter the maximum size for the archive.
    Example:
    50 GB
  • Under Virtual hard disk format, choose:
    VHDX
  • Under Virtual hard disk type, choose:
  • Click OK.
Windows will create the VHDX file and attach it automatically. You should now see a new disk appear in Disk Management, usually listed as Unknown and Not Initialized.
Step 4: Initialize the New Virtual Disk​
Before you can store files on the new VHDX, it needs to be initialized.
  • In Disk Management, locate the new virtual disk.
  • It may appear as Disk 1, Disk 2, or another number depending on your system.
  • Right-click the area that says Unknown or Not Initialized.
  • Select Initialize Disk.
  • Choose a partition style:
  • GPT: Recommended for modern Windows 10/11 systems.
  • MBR: Older option, mainly for compatibility with legacy systems.
  • Select GPT unless you have a specific reason to use MBR.
  • Click OK.
Tip:
GPT is the better default choice for most Windows 10 and Windows 11 users.
Step 5: Create a New Simple Volume​
Disk Management with the new virtual disk and unallocated space ready to create a simple volume.
Now you need to create a usable partition inside the VHDX.
  • Right-click the Unallocated space on the new virtual disk.
  • Select New Simple Volume.
  • Click Next.
  • Leave the volume size at the default if you want to use the full VHDX.
  • Click Next.
  • Assign a drive letter.
    For example:
    P:
    You might use P: for Projects or A: for Archives if available.
  • Click Next.
  • Choose the file system:
    NTFS
  • Set the allocation unit size to:
    Default
  • Enter a volume label, such as:
    Project Archive
  • Check Perform a quick format.
  • Click Next.
  • Click Finish.
After a few moments, the new virtual drive should appear in File Explorer with the drive letter you selected.
Step 6: Copy Your Project Files into the VHDX​
Now use the mounted virtual drive like any other disk.
  • Open File Explorer.
  • Open the new VHDX drive, such as:
    P:\
  • Create folders if needed, for example:
    P:\Source Files
    P:\Documentation
    P:\Exports
    P:\Screenshots
    P:\Invoices
  • Copy your project files into the VHDX.
  • Once the copy is complete, open a few files from the VHDX to verify they copied correctly.
Tip:
Consider adding a README.txt file inside the archive explaining what the project is, when it was archived, software versions used, and any restore instructions.
Step 7: Detach the VHDX When Finished​
When you are done archiving files, detach the VHDX. This safely removes the virtual drive from Windows while keeping the .vhdx file intact.
  • Close any open files or folders from the VHDX.
  • Open Disk Management again.
  • Locate the mounted VHDX disk.
  • Right-click the disk label area on the left side, such as Disk 2.
  • Select Detach VHD.
  • Make sure Delete the virtual hard disk file after removing the disk is not checked.
  • Click OK.
Important:
Do not check the delete option unless you intentionally want to remove the VHDX file permanently.
Your archive is now stored as a single .vhdx file in the location you selected.
Step 8: Mount the VHDX Later​
File Explorer showing a VHDX file with the context menu open and Mount available.
When you need to access the archive again, you can mount it quickly.
Option 1: Mount from File Explorer​
  • Browse to the folder containing your .vhdx file.
  • Right-click the VHDX file.
  • Select Mount.
Windows will attach the virtual disk and assign it a drive letter.
Option 2: Mount from Disk Management​
  • Open Disk Management.
  • Click Action.
  • Select Attach VHD.
  • Click Browse.
  • Select your .vhdx file.
  • Click OK.
The archive will appear as a drive again.
Tips and Troubleshooting​
The VHDX does not appear in File Explorer​
Open Disk Management and check whether the disk is online and has a drive letter. If no drive letter is assigned:
  • Right-click the volume.
  • Select Change Drive Letter and Paths.
  • Click Add.
  • Choose a drive letter.
  • Click OK.
The VHDX file is getting very large​
If you used a dynamically expanding VHDX, it grows as data is added. However, deleting files inside the mounted VHDX may not automatically shrink the .vhdx file on your physical disk.
For long-term archives, this is usually acceptable. If space is critical, consider creating a new smaller VHDX and copying only the final archive files into it.
I want the archive to be read-only​
If you want to prevent accidental changes, you can right-click the .vhdx file, choose Properties, and enable Read-only. You can also store the VHDX on read-only media or in a protected backup location.
Is a VHDX the same as a backup?​
Not exactly. A VHDX is a convenient archive container, but it is still just a file. If that file is deleted or the physical disk fails, the archive can be lost.
For important projects, keep at least one additional backup on another drive, NAS, cloud storage provider, or offline storage device.
Can I use BitLocker with a VHDX?​
Yes, on Windows editions that support BitLocker, you can encrypt the mounted virtual drive. This is useful if your archived projects contain sensitive client files, financial records, or personal information.
Using VHDX virtual drives is a clean and practical way to archive completed projects in Windows 10 and Windows 11. Instead of managing thousands of loose files, you can package an entire project into one mountable virtual disk. When needed, simply mount the VHDX, access the files, and detach it again when finished.
This approach is especially useful for project archives, client work, development snapshots, research collections, and long-term file organization.
Key Takeaways:
  • VHDX files let you store an entire project archive inside one portable virtual disk file.
  • Windows 10 and Windows 11 can create, mount, and detach VHDX files using Disk Management.
  • Dynamically expanding VHDX files are usually best for archives because they grow as needed.
  • Always detach the VHDX safely when finished and keep backups of important archive files.
  • For sensitive archives, consider using BitLocker or another encryption method.
This tutorial was generated to help WindowsForum.com users get the most out of their Windows experience.
