bochane
- Joined
- Oct 18, 2012
- Messages
- 1,404
- Thread Author
- #1
Have you ever seen this?
I do a clean install of 10162 from USB flash, on a Acer Aspire One (yes, a minimal system), remove all partitions and create a new one. Everything seems to go as expected, devices are installed, I select use Express settings, see the message “Even geduld” (One moment please) and than a threatening message pops up:
“Kritieke fout
Startmenu en Cortane werken niet. De volgende keer dat u zich aanmeldt zal worden geprobeerd dit te het te herstellen - Afmelden”
(Critical Failure
Startmenu and Cortana don’t work. Next time you login, we will try to fix it – Log off)
After logging off this repeats.
I force a reboot, again I select Express settings and the installation continues……
“Kritieke fout
(Critical Failure
