CVE-2023-52624: AMD GPINT Wake and Execute Fix Prevents Kernel Hang
Neon circuit diagram showing a DMC cube, Linux kernel chip, and wake/execute/sleep flow.
The Linux kernel vulnerability tracked as CVE‑2023‑52624 corrects a fragile interaction between the AMD display driver and a small display microcontroller (DMCUB): when the driver attempted to send GPINT mailbox commands while DMCUB was idle the hardware could hang the system, and the upstream fix wraps GPINT calls with a wake‑execute‑sleep helper so the microcontroller is reliably awakened before use and returned to sleep after the call completes.
Background​
The AMD display stack uses tiny on‑chip microcontrollers (DMCUs) to handle low‑level display control tasks. Those microcontrollers conserve power by entering idle/sleep states when not in use, and host driver code interacts with them through mailbox interfaces such as the GPINT (general purpose interrupt) mailbox. If driver code assumes the microcontroller is awake when it is not, attempts to execute mailbox commands can stall waiting for a response that never arrives — creating a dependable kernel hang or driver deadlock. CVE‑2023‑52624 documents exactly this class of failure for the driver code in the drm/amd/display tree. This is not a speculative theory: the publicly posted upstream commit and multiple vendor advisories describe the same corrective action — add a small helper (named dc_wake_and_execute_gpint in upstream wording) that wakes DMCUB, executes the GPINT command, and then optionally puts the microcontroller back to sleep after processing an optional response. The maneuver is functionally similar to the driver’s established inbox command interface and is intentionally minimal: it preserves normal behavior while closing a deterministic hang window that occurs when DMCUB is idle.
What the bug is, in plain terms​
  • Component affected: Linux kernel, AMD display driver (drm/amd/display).
  • Root cause: GPINT mailbox commands were issued without ensuring the DMCUB microcontroller was awake; if DMCUB was idle the mailbox interaction could block indefinitely and hang the driver or whole system.
  • Primary impact: Availability — deterministic system hang / driver deadlock / kernel stall.
  • Attack vector: Local — a user or process that can exercise display driver paths (for example, a compositor, a GPU‑using process, or a container that has access to /dev/dri) can trigger the problematic flow.
The technical fix is conservative and surgical: rather than rearchitecting the mailbox protocol, maintainers added a thin wrapper that explicitly wakes the microcontroller and only executes the GPINT command once wake has been confirmed. That eliminates the race between the microcontroller’s sleep state and the driver’s attempt to use the mailbox. The patch was merged into the upstream stable/kernel trees and subsequently propagated to vendor and distribution packages.
Who should worry — exposure model​
This vulnerability’s practical risk hinges on device exposure and configuration:
  • Desktop and workstation machines with AMD GPUs where unprivileged user processes (compositors, browser GPU code, test harnesses) can interact with DRM device nodes (/dev/dri/*) are primary candidates for exploitation of the hang.
  • Multi‑tenant hosts, CI/CD runners, or cloud/virtual environments that deliberately expose GPU devices to untrusted containers or guests (via device passthrough or --device=/dev/dri) are high‑risk — an untrusted actor in a container can often trigger the relevant ioctl paths.
  • Embedded devices, OEM kernels, Android forks, and appliances represent the long tail of exposure: vendor trees often lag upstream and may not backport the tiny fix promptly, leaving devices vulnerable for months or years.
Practical exploitability is straightforward in exposed contexts: the sequence to hang the system is deterministic once the driver path is reached. That makes the issue an attractive Denial‑of‑Service primitive in adversarial operational models, even though it does not, on its own, provide code execution or privilege escalation. Multiple vendor trackers and vulnerability mirrors classify the flaw as availability‑centric and recommend patching.
Technical anatomy — how the failure manifests​
The failure mode is a classic sleep‑state / mailbox contract mismatch:
  • The driver sends a GPINT mailbox command to DMCUB expecting an immediate or timely response.
  • DMCUB, however, may be in a low‑power idle state (sleeping microcontroller).
  • Because the driver code did not guarantee DMCUB was awake, the mailbox command stalls waiting for an event the hardware won’t deliver until it is woken.
  • The stalled mailbox call back‑pressures the driver path and can cause a hard hang or unresponsive display, necessitating a reboot to recover in some circumstances.
Upstream maintainers addressed the timing and power‑state assumption by adding dc_wake_and_execute_gpint (the precise helper name as shown in kernel commit messages). The helper performs a three‑step sequence:
  1. Wake the DMCUB microcontroller (clear idle/wake registers or issue a wake request).
  2. Execute the GPINT mailbox command and wait for the optional response.
  3. Sleep (optionally) — return DMCUB to its prior idle/sleep state if the hardware semantics require it.
Because the helper centralizes wake/sleep semantics, every GPINT invocation passes through the same guarded sequence, removing the previous race window. This change is intentionally small to ease backporting and minimize regression risk.
Verification and distribution status​
Multiple independent vulnerability trackers and distribution advisories record CVE‑2023‑52624 and link it to the upstream stable commits that implement the helper wrapper. The NVD entry summarizes the problem and the corrective change; Debian’s security tracker and OSV list specific package statuses and fixed versions for their trees. Major distro and vendor advisories (Ubuntu, Red Hat, Oracle Linux, Debian) have entries mapping packaged kernels to patched or unpatched states. Operators should consult their distribution’s security tracker or package changelog and confirm the presence of the upstream commit(s) in their installed kernel package. CVE analysis mirrors show that fix availability varies by kernel version and vendor packaging. Some distributions included the change in their 6.12–6.16 series and backported stable commits into older trees where maintainers judged the change low‑risk and high‑priority. If you run a custom or vendor‑supplied kernel, you must examine the kernel source tree for the helper function or verify package changelogs that explicitly list CVE‑2023‑52624 or the upstream commit ID. Treat the kernel as unpatched until you can confirm the exact commit is present.
Detection and incident response​
A hang in this driver path leaves practical, detectable artifacts:
  • Kernel logs (dmesg, journalctl -k) may show driver stalls, mailbox timeouts, or stack traces rooted in drm/amdgpu display functions.
  • Repeated compositor crashes (Wayland/Xwayland) or display freezes tied to GPU‑using workloads are symptomatic of an underlying driver hang.
  • In multi‑tenant hosts you may see repeatable crash patterns correlated to untrusted container jobs that have /dev/dri mounted.
Incident triage checklist (short):
  1. Immediately preserve kernel logs and serial console captures — they are critical to map the stack trace to upstream commits.
  2. Identify the process or container exercising the GPU driver at the time of the hang (call traces often include the userland process like Xwayland or a GPU runtime).
  3. Validate kernel package changelogs for CVE‑2023‑52624 and inspect the kernel source tree if you maintain custom builds.
  4. If you cannot patch immediately, isolate affected systems and remove GPU device access from untrusted workloads until a maintenance window is available.
Remediation and practical hardening (recommended priority actions)​
The only reliable fix is to run a kernel that contains the upstream stable commit implementing dc_wake_and_execute_gpint (or the vendor equivalent) and then reboot into that kernel.
  1. Inventory and exposure:
    1. Find hosts with AMD GPU driver modules loaded: lsmod | grep amdgpu.
    2. List DRM device nodes and permissions: ls -l /dev/dri/* and identify whether unprivileged users or containers can access them.
    3. Identify containers/VMs/CI runners that mount /dev/dri or use passthrough.
  2. Patch:
    1. Check your distribution’s security tracker or vendor advisory for packaged kernels that list CVE‑2023‑52624 or the upstream stable commit.
    2. Apply the vendor kernel update and reboot to the updated kernel.
    3. For custom kernels, cherry‑pick the upstream stable commit into your tree, rebuild, and validate on representative hardware.
  3. Compensating controls (if immediate patching is impossible):
    • Restrict access to DRM device nodes: apply udev rules to bind /dev/dri/* to a trusted group and remove world access.
    • Remove /dev/dri device nodes from untrusted containers and CI runners; avoid --device=/dev/dri unless necessary.
    • Harden container capabilities (drop CAP_SYS_ADMIN and related elevated capabilities) to reduce the chance a container can call driver ioctls.
    • Increase monitoring and SIEM rules for kernel oops/hang traces referencing amdgpu/drm.
  4. Vendor engagement:
    • For embedded appliances and vendor kernels where you cannot rebuild the kernel, open a support ticket and request an update or backport that includes the upstream stable commit. Vendor lag is the dominant long‑tail risk for device fleets.
Critical analysis — strengths of the fix and residual risks​
Strengths
  • Surgical, low‑risk change: The upstream patch is small and defensive: a wrapper that enforces the wake‑execute‑sleep protocol. Small fixes are easier to backport and less likely to introduce regressions than large refactors. That fact increases the chance distributions and vendors will ship fixes quickly.
  • Preserves performance and semantics: The helper mirrors existing inbox command semantics and only changes behavior around the corner case of sleeping microcontrollers; normal fast paths and performance characteristics remain unchanged.
  • Clear detection artifacts: Kernel oopses and timeout stack traces provide actionable forensics that map directly to the offending code paths and the upstream commit, assisting incident response.
Residual and systemic risks
  • Vendor/embedded lag: OEM kernels, Android forks, and appliances remain the largest practical exposure because vendors may not backport fixes promptly. These devices can remain vulnerable long after desktop distributions are fixed. Operators should identify such fleets and escalate with vendors.
  • Misconfiguration exposure: Hosts that intentionally expose /dev/dri to untrusted workloads (CI runners, multi‑tenant GPU hosts) remain high‑risk until they are patched or reconfigured. Access control is the most effective short‑term mitigation.
  • Availability as an amplifier: Even though this is an availability bug rather than an RCE, DoS primitives are operationally valuable to attackers — they can disrupt monitoring, trigger failovers, or be used to mask other malicious activity. Treat DoS vulnerabilities with urgency in critical environments.
Cross‑checks and verification guidance for operators​
  • Confirm the kernel package changelog mentions CVE‑2023‑52624, the upstream commit ID, or an advisory mapping from your distribution vendor. Do not assume a kernel is patched solely because it is a newer minor version; verify the commit presence in the package metadata.
  • If you build your own kernels, search the source tree for the helper function name (dc_wake_and_execute_gpint), or inspect kernel git history for the merge that referenced the CVE. If you cannot find the helper in your tree, treat the host as unpatched.
  • For embedded or vendor kernels, retain captured kernel logs and serial console output and submit them to vendor support when requesting a backport; the oops traces directly map to upstream fixes and reduce vendor triage time.
Quick checklist for incident managers (one page)​
  1. Inventory affected assets: lsmod | grep amdgpu and ls -l /dev/dri/*.
  2. Confirm patch availability in distro vendor tracker; apply kernel update and reboot.
  3. If patching is delayed:
    • Restrict /dev/dri permissions via udev.
    • Remove /dev/dri from containers and passthrough configurations.
    • Harden container capabilities (drop unnecessary capabilities).
  4. Collect and preserve kernel logs and serial console output where hang occurred.
  5. Engage vendors for embedded devices, request a firmware/kernel image with the backport.
  6. Validate after patch: reproduce previously problematic GPU workloads in a staging ring and monitor for oopses for 48–72 hours.
CVE‑2023‑52624 is a textbook example of how small assumptions about microcontroller power state can lead to high‑impact availability failures in kernel drivers. The fix is intentionally small and conservative — wake the DMCUB before using the GPINT mailbox and put it back to sleep afterward — which makes the remediation low risk and straightforward to backport. For administrators and platform teams the priority is simple and practical: inventory exposure, apply vendor or distribution kernel updates that include the upstream commit, and restrict untrusted access to display devices until systems are patched. Because long‑tail devices and vendor kernels represent the greatest remaining exposure, those fleets deserve special focus and vendor escalation until the backport is confirmed. For operational guidance and concrete remediation steps, follow your distribution’s security advisories and verify the upstream commit or CVE mention in package changelogs before declaring systems remediated. If you cannot confirm the commit presence, treat the host as unpatched and apply the compensations above immediately.
