CVE-2024-39475: Linux Savage framebuffer bug fix and patch guidance
The Linux kernel’s legacy framebuffer driver for S3 Savage hardware contains a simple-but-serious error‑handling bug that can be triggered locally to crash a host kernel: a missing check in the savagefb probe path fails to handle an error return from savagefb_check_var, allowing a zero-valued pixclock to produce a divide‑by‑zero and a kernel oops. Distributors and the kernel stable trees have already landed corrective commits; operators should treat this as an availability risk and apply vendor kernel updates or mitigations as soon as possible. (ubuntu.com)
A circuit board shows a red 'DIVIDE-BY-ZERO KERNEL OOPS' error with a 'Patch applied' CVE-2024-39475 banner.Background​
The S3 Savage framebuffer driver (commonly referenced as fbdev:savage) is a legacy graphics driver in the Linux kernel’s fbdev subsystem. It implements basic framebuffer operations for older S3 Savage GPUs and continues to be present in many kernel trees for compatibility on legacy hardware. Historically, fbdev drivers have been a source of a variety of divide‑by‑zero and bounds‑checking fixes because userspace can pass values (via ioctls or mode setting) that end up as divisors in timing calculations. (ubuntu.com)
In this instance, a defensive commit added a check for a zero pixclock (the pixel clock value used during mode timing calculations) in one function, but the probe path—where that function’s return value must be handled—did not properly respond to the error. The result: if userspace (or a crafted input) results in a zero pixclock, the code path can reach a divide‑by‑zero at probe time and trigger a kernel failure. The Common Vulnerabilities and Exposures entry records the fix as “Handle err return when savagefb_check_var failed.” (nvd.nist.gov)
What exactly is wrong in the code?​
The technical root cause, in plain language​
At the heart of the bug is a missing error‑check. One helper routine was changed to return an error when it encounters a zero pixclock—as it should, to avoid division by zero—yet the higher‑level probe routine (savagefb_probe) calls this helper and continues as though the helper had succeeded. When the helper returns an error, the probe logic doesn’t avoid using the pixclock as a divisor, so a divide‑by‑zero can occur. This triggers a kernel oops or panic and makes the machine unavailable until reboot or kernel recovery. (ubuntu.com)
Why pixclock matters​
pixclock is used in framebuffer drivers to calculate timing parameters for displays: horizontal/vertical sync and refresh rates depend on accurately computed pixel clocks. Because those calculations often perform divisions by pixclock, a value of zero is an obvious footgun—so the right fix is to validate and error out when pixclock is zero and then ensure callers check that error. The upstream patching strategy for similar fbdev defects has followed this pattern repeatedly across different drivers. (ubuntu.com)
Scope and affected systems​
This is an Local attack vector vulnerability that requires the attacker to be able to interact with the affected driver (for example, by calling ioctl or triggering a mode change via userspace). The vulnerability does not permit privilege escalation, arbitrary code execution, or direct data exposure; instead, its primary impact is availability: a machine can crash, hang, or otherwise become unusable until the kernel recovers. The established CVSS v3.1 base score commonly reported for this issue is 5.5 (Medium) with the confidentiality and integrity impact rated as None and availability as High. (nvd.nist.gov)
Multiple distribution advisories and vulnerability databases list the kernel versions and stable trees that contained the vulnerable code and where fixes were applied. Distributors have mapped the fix into their kernel branches and published patched kernel packages; canonical tracking pages show the specific stable kernel commits that introduced or fixed the problem. Affected kernel series range across multiple Long Term Support versions where the legacy driver is present; vendors have published fixed kernel package versions in their advisories. (ubuntu.com)
Key points about exposure and reachability:
  • Attack vector: Local (the attacker needs to run code on the host or otherwise control a user context that can interact with the framebuffer driver). (nvd.nist.gov)
  • Attack complexity: Low (the issue is a straightforward division by zero once the driver receives or is given a zero pixclock).
  • Privileges required: Low (a non‑privileged user that can access /dev/fb* or invoke relevant ioctls can potentially trigger the condition, depending on the system’s access controls).
Why this matters to WindowsForum readers and system operators​
  • Many embedded systems, appliances, and older desktop setups still run kernels that include legacy fbdev drivers. A vulnerable savagefb will be present in kernels kept for stability or hardware compatibility. Even if the driver is rarely used, the presence of a device node or an exposed framebuffer interface may be sufficient for a local user or guest (in virtualized environments) to trigger the fault. (ubuntu.com)
  • In server or cloud contexts the risk is narrower but real: if an image or VM snapshot includes a kernel with the legacy driver enabled, an attacker with local access in a multi‑tenant environment or an untrusted guest could attempt to trigger a host‑side crash depending on the virtualization setup. The availability consequence is precisely the problem distributors flagged: a sustained or persistent denial of service that can render nodes unavailable. (nvd.nist.gov)
  • The bug is not a remote code execution or data‑exfiltration vector, but availability bugs are operationally significant: a kernel panic disrupts services, may corrupt running workloads, and imposes recovery work—particularly problematic for systems with tight uptime or for unmonitored devices in remote locations.
Evidence, tracking, and verification​
To understand whether your systems are affected and whether a vendor patch applies, operators should consult at least two independent trackers and their vendor advisories. The National Vulnerability Database (NVD) and major distributions (Ubuntu, SUSE, Debian, Oracle Linux) have published entries for this CVE and list either the fix or vendor package versions that include the fix. These authoritative sources confirm the problem description (error handling omitted in savagefb_probe leading to divide‑by‑zero) and provide the practical mitigations. (nvd.nist.gov)
Open source vulnerability databases (OSV, OpenCVE) and third‑party trackers add corroboration and variant metadata such as EPSS/SSVC estimates and which kernel stable commits carried the fix back to older branches. Use these cross‑references to map your running kernel to the correct patched kernel release or stable backport.
Practical mitigation and remediation guidance​
If you maintain Linux hosts (desktops, servers, appliances, or images), apply the following steps in order:
  • Inventory: Determine whether the savagefb (or overall fbdev) driver module is present and whether /dev/fb* devices exist on your systems. Use the commands your environment supports to list kernel modules and framebuffer devices. If you’re running a custom kernel, check your kernel config for fbdev drivers.
  • Patch: Install vendor or distribution kernel updates that include the upstream fixes. Most major distributions have already mapped the fix into their stable kernels; consult your distribution’s security notice for the exact package name and version and apply the update via your standard patch management process. Ubuntu and SUSE advisories list the fixed kernel package versions and backports. (ubuntu.com)
  • Workarounds (temporary): If you cannot immediately patch, consider blacklisting the driver or disabling fbdev support at runtime where possible. On systems that do not require legacy framebuffer drivers (modern X.Org/Wayland stacks on modern GPUs), remove or blacklist savagefb or restrict access to /dev/fb* (but be aware this may break some consoles or embedded UI). 1.) Add the module to a blacklist configuration or 2.) recompile the kernel without the legacy driver. These are stopgaps—not substitutes for applying vendor fixes.
  • Access control: Restrict /dev/fb* access to minimal, trusted users. Many deployments allow non‑root access to framebuffers; lock these down and elevate monitoring where users or processes need framebuffer access.
  • Monitor: Check your observability and kernel monitoring for recent oops/panic signatures and add detection rules for divide‑by‑zero kernel traces originating from video/fbdev subsystems. An uptick in such traces might indicate attempted exploitation.
  • Test and roll forward: After patching, verify the kernel boots cleanly, and run operational acceptance tests to ensure device behavior (console, display, and embedded UI) remains functional.
Because the vulnerability is local and affects availability, don’t assume absence of reported remote exploitation equates to little operational risk. In many environments a local DoS can translate into service outages or cascading failures—plan accordingly.
Who should prioritize this fix?​
  • Administrators of embedded devices, kiosk systems, and appliances that rely on older kernels and legacy framebuffer drivers. These systems are the most likely to load the savage driver and to be disrupted by a kernel oops. (ubuntu.com)
  • Operators of VMs and container hosts where untrusted workloads might have access to host device nodes (for example, passthrough /dev/fb* or insufficiently isolated device access). Even if hardware is not present, guest interactions with framebuffer interfaces can cause host-side kernels to hit vulnerable code in some misconfiguration scenarios. (nvd.nist.gov)
  • Security teams performing local privilege or service continuity audits—this CVE is a reminder that availability‑focused kernel bugs remain operational threats and must be included in patch plans and runbooks.
Why the fix is straightforward—and why that matters​
The upstream change pattern is familiar: add a defensive check to reject zero pixclock, then ensure callers check and handle that error. Both parts are required; only the combination produces a correct fix. Kernel maintainers applied similar defensive changes to multiple fbdev drivers in the past (for other chipsets), and the correct pattern is now repeated in the savage driver. The simplicity is reassuring: it reduces the chance a fix introduces more complex regressions—but it also highlights why coding defensively across call chains matters. A single missing error check in a probe path is enough to transform a correctness fix into an availability hazard. (ubuntu.com)
Risk assessment and likelihood of exploitation​
  • Likelihood: Low-to-moderate. The vulnerability is local; it requires an attacker to be able to interact with framebuffer interfaces. That limits mass remote exploitation but leaves multi‑tenant and local user attack surfaces exposed. (nvd.nist.gov)
  • Impact: Availability-focused and tangible. Successful triggering causes kernel-level crashes or oopses. For critical infrastructure, that’s sufficient to justify high urgency for patching.
  • Active exploitation: At the time of writing there are no widely reported, reliable public exploit sightings for remote mass exploitation; vulnerability trackers show a low EPSS score, indicating low known exploit probability. That said, the attack is simple enough for an adversary with local code execution to weaponize, and availability exploits can be weaponized for sabotage even without privilege escalation. Treat "no public exploit" as not proof of safety.
Operational checklist (quick reference)​
  • Inventory: Identify systems with the savage driver loaded or /dev/fb* present.
  • Patch: Apply vendor kernel updates in test and then production windows; prioritize embedded and multi‑tenant hosts. (ubuntu.com)
  • Blocklist/Disable: Where patching is impossible in the short term, blacklist the module or rebuild kernel images without fbdev support. Verify console behavior afterwards.
  • Access controls: Restrict framebuffer device nodes to trusted accounts; tighten container and VM device isolation.
  • Monitoring: Add kernel oops/panic trace detection for fbdev/video subsystems.
  • Documentation: Update runbooks to include recovery steps for kernel oops related to the video/fbdev stack.
Broader lessons for maintainers and security teams​
  • Defensive programming must be applied end‑to‑end. A protective check inside a helper is only effective if call sites validate and respond to error returns. This bug is a textbook case where partial application of a defensive measure left a gap. (ubuntu.com)
  • Legacy subsystems matter. Even though fbdev is considered legacy by many users, drivers for older hardware remain in widespread kernel trees and can create real operational impact. Security programs should include legacy drivers in their scope. (nvd.nist.gov)
  • Availability is a security metric. Vulnerabilities that do not leak data or allow code execution can nonetheless be weaponized to cause outages. Track and remediate availability‑centric CVEs with the same discipline as confidentiality or integrity risks.
  • Vendor mapping and backports are essential. Kernel fixes land in upstream trees and are then backported to stable branches; follow your vendor’s mapping to identify the precise package that contains the fix for your platform. Distributors’ security advisories and OSV/NVD entries are the authoritative places to verify the correct patched package. (ubuntu.com)
Final takeaway​
CVE‑2024‑39475 is a straightforward but meaningful reminder that missing error handling at the kernel level converts innocuous inputs into system‑stopping faults. The vulnerability is local, low complexity to trigger, and produces a high availability impact if exploited or accidentally hit in production. The remedy is equally straightforward—apply the kernel updates your distribution provides or disable/load‑time block the legacy driver where it is not required. Treat this as an operational priority for affected platforms, validate fixes in test environments, and update monitoring and access controls to reduce the attack surface until all hosts are patched. (nvd.nist.gov)
Conclusion: patch promptly, restrict framebuffer device access where feasible, and use this incident as a prompt to expand inventory and monitoring for legacy kernel subsystems that remain operationally relevant.
