Deleting an old opperating system
#21
Yah, I guess that makes sense. How much space should W7 take up? 28gigs?
reghakr
#22
right click rename on your C: drive, to call it something less confusing such as windows 7 instead of Vista64 ;)
very good idea.
What happened to your second hard drive?
You should have at least 60GB for Windows 7 installation, considering your going to install a number of 3rd party applications.
#23
very good idea.
Well, I have 38gb of taken up space on the ( C: ) and 10gb partition combined. I don't really get why that 10gb partition is there.
reghakr
#24
Would you consider a full "clean" install?
Be aware, you'll have to re-install all your 3rd party applications.
I use GParted for all my Windows installations. It look familiar to Linux if that helps at all.
Burn the ISO and boot your computer with it to get a feel as to it's capabilities
I'd be glad to help out with instructions..
#25
So Gparted is a program that organizes my "used disk space" during installation of the OS? or after?
#26
I think the operating system (W7) is only taking u 28gb on my C-drive. The 10gb partition I reformatted and turned into "z" drive. It's not a big deal to me that one of my hard drives has been split into 2. I think I'll just leave it the way it is.
Thanks a billion for yalls support,
James Keeton
#27
I think the operating system (W7) is only taking u 28gb on my C-drive. The 10gb partition I reformatted and turned into \\\"z\\\" drive. It's not a big deal to me that one of my hard drives has been split into 2. I think I'll just leave it the way it is.
James Keeton
if you right click computer\manage you can then open disk management and delete the Z drive then extend the C: drive to inocrporate it ?
If that grumbles about not on an active partition then use partition wizard :)
#28
Partition Wizard sais I can't re size the partition while it's in use?
#29
yes and if you click next step it will reeboot your system and perform the operation at dos level before you get into windows ;)
#30
Cool it worked!
Thanks to both of yall for the help!
James Keeton
