Windows 7 Desktop Backround not loading
chizwhiz2003
When i start up my windows 7 computer, the desktop backround is black. When i switch theme, the glass colour changes but not backround and i cannot get the backround back. It never used to happen. Plz help me, i have the right specs because it used to load it.
Windows 7 32 Bit RC downloaded on May 5th from Microsoft.com
Charlie :)
It seems like you are experiencing an issue with your Windows 7 desktop background displaying as black and not changing even when switching themes. This could be due to various reasons such as a corrupted system file, a background setting issue, or a problem with the theme. Here are some troubleshooting steps you can try to resolve this issue: 1. Check Wallpaper Settings: - Right-click on the desktop and select "Personalize." - Choose a different wallpaper from the provided options and see if it applies correctly. - If the wallpaper still appears black, proceed to the next steps. 2. System File Check: Run a system file check to scan and repair any corrupted system files that may be causing the issue. - Open Command Prompt as...
It seems like you are experiencing an issue with your Windows 7 desktop background displaying as black and not changing even when switching themes. This could be due to various reasons such as a corrupted system file, a background setting issue, or a problem with the theme. Here are some troubleshooting steps you can try to resolve this issue: 1. Check Wallpaper Settings: - Right-click on the desktop and select "Personalize." - Choose a different wallpaper from the provided options and see if it applies correctly. - If the wallpaper still appears black, proceed to the next steps. 2. System File Check: Run a system file check to scan and repair any corrupted system files that may be causing the issue. - Open Command Prompt as an administrator by typing "cmd" in the Start menu, right-clicking on "Command Prompt," and selecting "Run as administrator." - In the Command Prompt window, type the following command and press Enter: sfc /scannow - Wait for the scan to complete. If any issues are found, the tool will attempt to fix them automatically. 3. Check Themes: - Try switching to a different built-in theme to see if the issue persists. - If the problem is only with custom themes, try resetting the theme to default settings. 4. Check Background Settings: - Right-click on the desktop and select "Personalize." - Click on "Desktop Background" at the bottom of the window. - Ensure that the correct background image is selected and set to fill, fit, stretch, tile, or center as desired. 5. Update Graphics Drivers: Make sure your graphics drivers are up to date. Outdated or corrupt graphics drivers can sometimes cause display issues. 6. Run Windows Update: Check for any pending Windows updates and install them. Updates often contain bug fixes and improvements that could address the problem. 7. Advanced Troubleshooting: If the issue persists, consider performing a system restore to a point before the problem started or reinstalling Windows 7. Remember to backup your important data before making any significant changes to your system. These steps should help you troubleshoot and resolve the desktop background issue on your Windows 7 computer. Let me know if you need further assistance or if you have any other questions!
