Destination/Source path too long- try by shortening
Status
Not open for further replies.
openmind
Dear Geeks,
We are facing the "Destination/ Source path too long - try by shortening the name ".
Some times users are unable to access the files on file server because of path too long.
So what is solution for this without shortening the names ?
Thanks in Advance.
strollin
Honorable Member
Do you have a share setup to access the folder where the docs are stored on the file server? Have you mapped a drive to point to that share?
openmind
Dear ,
Yes in the file server we have shared the folders and users have access to those ,but not mapped any drive for any folder.
raymono
I am using a software called Long Path Tool and it is working like charm, i have no problems in copying,deleting or extracting anything anywhere.
Long path error!
"Long path tool" is very helpful for this problem. You can solve this
problem like copy, delete, long path files by using this tool. I used to have similar problems too, but after using "long path tool" everything was solved.
Status
