Windows 7 details please of running xp on w7
bfedwards
hello,
Would some one please tell me if when running virtual Xp on W7 if:
XP is using its own drivers or W7 drivers
XP is limited to using 3 GB or less memory of the available memory
XP can run on a 64bit version of W7.
XP is partitioned separately from W7
XP has a speed loss running in virtual.
thanks
bfe
XP is using its own drivers or W7 drivers = No, Win 7, it is a VPC
XP is limited to using 3 GB or less memory of the available memory = It's a VPC, it uses whatever memory you allocate to it. But, yes, I think (not sure) it would still be limited to the 3G.
XP can run on a 64bit version of W7 = It should. But, if you are getting Win 7 Pro or Ultimate, then you can install Virtual XP Mode for free, which is a more powerful installation of a VPC XP than you might be concidering to install.
And that comes in 32bit and 64bit.
XP is partitioned separately from W7 = No, it's a VHD
XP has a speed loss running in virtual = Depends on the speed of your system, the ammount of RAM you allocate to it.
Also,,,,, The new Windows Virtual PC...
Tepid
Also,,,,, The new Windows Virtual PC requires hardware Virtualization (Intel - VT or AMD - V ) to run.
bfedwards
thanks,
I have pre ordered the W7 professional which contains virtual xp as I understand and will give it a whirl.
bfe
