devices and printers problems
wt.pm
I was adding a new bluetooth device to my computer, when I restarted, now when I click on devices and printers, I get a blank page, the green progress bar slowly crosses the address bar all the way across then just sits there, and the page is blank. The network page is also blank. This has happened before but it did not take long to correct itself, if nothing else if I restarted again then that would fix it, but not this time. HELP, what is causing this, and how do I fix it? See attachment for screenshot
Sorry I don't have an answer here, but I hope somebody comes up with one since I have the same issue. Using the Trendnet TBW-105ub bluetooth adapter and the drivers appear to install properly, but when I select the BT devices icon it opens the window, but the green progress bar crawls along and stops right near the end. The same thing happens when trying to access the devices and printers directly from the control panel.
