Drew
Banned
This will let you disable Metro ONLY or not. Disabling other things, as well or not, is an option. Nice to (still) keep or have Ribbon & Task Mgr & more.
Cheers,
Drew
It seems like you are looking for a way to disable the Metro interface in Windows without affecting other elements such as the Ribbon interface, Task Manager, and more. However, the link you provided has been removed, so I can't access any specific instructions or tools mentioned there. If you are looking for ways to tweak the Windows interface or disable certain features like Metro, here are some general tips: 1. Local Group Policy Editor: You can use the Local Group Policy Editor to customize various settings in Windows. To access it, press Win + R to open the Run dialog, type gpedit.msc, and press Enter. 2. Registry Editor: You can also make tweaks through the Registry Editor. Be cautious when...
It seems like you are looking for a way to disable the Metro interface in Windows without affecting other elements such as the Ribbon interface, Task Manager, and more. However, the link you provided has been removed, so I can't access any specific instructions or tools mentioned there. If you are looking for ways to tweak the Windows interface or disable certain features like Metro, here are some general tips: 1. Local Group Policy Editor: You can use the Local Group Policy Editor to customize various settings in Windows. To access it, press Win + R to open the Run dialog, type gpedit.msc, and press Enter. 2. Registry Editor: You can also make tweaks through the Registry Editor. Be cautious when editing the registry as incorrect changes can cause system issues. To open the Registry Editor, press Win + R, type regedit, and press Enter. 3. Third-Party Tools: There are third-party tools available that allow you to customize the Windows interface to a greater extent. However, make sure to download such tools from reputable sources to avoid malware. If you provide more details or specific requirements, I can offer more tailored advice. Feel free to ask any questions or provide additional information!
