Display Driver Uninstaller (DDU)
The Display-drivers uninstaller is exactly what it say's it is. Using this handy app you can remove all previous versions of your display driver whether it be AMD or Nvidia:
What it does is removing the Display driver from device manager and removing the current and all precedent driver from the Windows Driver store along with removing services from NVIDIA/AMD.
The current effect after you use this tool will be similar as if Windows was in a "Fresh Install" state.
This tool act similar to what Driver sweeper do + the extra mentioned above.
If you have problem installing older driver or newer one, give it a try as there are some reports that it fix those problems.
RECOMMENDED USAGE :
-The tool can be used in Normal mode but for abolute stability when using DDU, Safemode is always the best.
Windows XP up to 8.1 is supported X86/X64 (not sure for WinXP x64)
Reference:
Download latest Version 9.4
Changelog:
Added extra potection to DDU to prevent the removal of the "programfiles ..." folders (could happen on very rare)
Added a warning message if the user is not in safemode
Added Russian language + updated some languages.
Download:
Display Driver Uninstaller Download version 9.7.1
Changelog:
  • Now supporting .NET 2.0 (Fixed crash for user who do not have .NET 3.5)
  • Fixed a possible infinite loop with the driver store Cleanup
  • Updated Portuguese language.
  • updated the NVIDIA clsidleftover and driverfiles .cfgs
  • clean the firewall entrys and power settings (nvidia)
  • fixed the win32 error message for ddudr on winxp32
Download:
Link Removed[/URL]
Download latest version 9.8.1 (11-29-2013) V2 (re-released)
Changelog:
-Fixed crashes encountered by some users who are not using a base Windows localized in English when cleaning some registry keys that required special permissions.
-Cleaning of the LEGACY_AMDKMDAG registry key leftovers for win 7 and -
-Remove the AMD service AODservice
-French language Update
-Updated nvidia driverfiles.cfg
-DDU is now safe to use even with the "Real" Administrator account.
-Fixed a possible DDU crash for AMD users.
Download:
Download latest version 10.1(01-07-2014)
Changelog:
-Changed the way GPU and driver version are detected and shown in the log to avoid some bug reported by users.
-Fixed a possible DDU crash when doing the Driver store cleanUP.
-Cleanup of display cpl from the pnpressource section. win8+
-Added cleanup of the HKLM\SYSTEM\CurrentControlSet\Control\Video section for NVIDIA.
-Quick workaround to correctly clean the driver entry of program and features of Dutch systems.
-Updated ddudr
-Russian Translation updated (Thanks to homocomputeris)
-Fixed aboutbox autoresize
Download:
Download latest version 10.2(01-15-2014)
Changelog:
-Changed how stuff get deleted on disk and some region of the registry.(Nvidia only)
-Fixed an issue that prevented cleaning various stuff in the registry.(AMD and NVIDIA)
Download latest version 11.2(01-29-2014)
Changelog:
-DDU now have a new installer and icon. (the installer also have offers, nothing is installed without users approval.)
-Party rewrite of the Installer/Product, updagradecodes, features, components on the different registry regions. (Nvidia / AMD)
-Now when DDU restart into safemode, it is now using Safemode with Networking
-CleanUP of Some shellEx extension leftovers.
Display Driver Uninstaller 12.2 (beta) (02-09-2014)
Changelog:
-Do not remove the amdkmpfd (amd PCI bus lower filter) it can cause trouble...
-Amd cleanup order reorganisation (Nvidia will follow later.)
-Some amd cleanup addition to remove some leftover for some users.
Display Driver Uninstaller 12.4 (03-01-2014)
DDU should be considered as beta software.
Changelog:
-Fixed a bug introduced recently that could have prevented the cleanUP of the pnplockdownfiles section. (Nvidia only)
-made a packages.cfg file to give further DDU CleanUp power to the users.
-Spanish language update from Jackalito ! Thanks.
Display Driver Uninstaller 12.6.0 (03-17-2014)
DDU should be considered a beta.
Changelog:
-Fixed a possible registry clean-up problem that could happen on some circumstances (I highly recommend users to update DDU to this version)
-Updated Interface reg clean-up.
-Add Korean language . Contributor: 4Li
Download page:
