Windows 7 DRIVER_IRQL_NOT_LESS_OR_EQUAL - ntoskrnl.exe
Leespiker
I have received this BSOD in the past. This time it was randomly triggered. In the past, it has been triggered from high intensity gaming. That was another issue though. All the necessary information is attached.
Link Removed due to 404 Error
Thanks in advance,
Lee
EDIT: It seems to happen I have extreme stress on my graphics card. For example, it just crashed when running three Diablo III clients and DayZ.
Re: KMODE_EXCEPTION_NOT_HANDLED - wanarp.sys ---&--- DRIVER_IRQL_NOT_LESS_OR_EQUAL - ndis.sys
Sorry for the delay, but I needed to compare the older analysis with the latest memory dumps.
Make sure that you've updated the Lachesis drivers AND the firmware.
Un-install LogMeIn.
Update the Asus Xonar DG drivers - the latest date from 2011
Update the keyboard drivers
lmimirr.sys Tue Apr 10 18:32:45 2007 (461C108D)...
Only 97 updates - most Win7 SP1 systems have 130 or more. Please visit Windows Update and get all available updates.
E: drive only has about 11% free space. 15% is recommended - please free up (approximately) an additional 24 gB for optimum performance.
3 hard drives installed - what is the make, model, and wattage of your Power Supply?
This is most likely (IMO) caused by a Razer Lachesis driver that's not Win7 compatible. Please visit the Razer website to download and install the latest, Win7 compatible Razer drivers.
Also, Please update these older drivers. Links are included to assist in looking up the source of the drivers. If unable to find an update, please remove (un-install) the program responsible for that driver. DO NOT manually delete/rename the driver as it may make the system unbootable! :
RemotelyAnywhere Mirror Miniport Driver or LogMeIn Mirror Miniport Driver
Lachesis.sys Fri Aug 17 03:48:44 2007 (46C552DC)
Razer Lachesis Mouse driver
RaInfo.sys Fri Jan 4 13:57:14 2008 (477E818A)
LogMeIn/RemotelyAnywhere Kernel Information Provider
LMIRfsDriver.sys Mon Jul 14 12:26:56 2008 (487B7E50)
cmudaxp.sys Tue Jun 9 07:32:36 2009 (4A2E4854)
ASUS Xonar DG Audio Interface driver
TuneUpUtilitiesDriver64.sys Thu Sep 17 07:54:52 2009 (4AB2238C)
TuneUpUtilitiesDrv
VX3000.sys Tue Oct 6 21:49:00 2009 (4ACBF38C)
Microsoft LifeCam
ScreamingBAudio64.sys Thu Jul 1 14:54:32 2010 (4C2CE468)
Screaming Bee Audio Driver
Although this driver isn't all that old, we have seen problems with it in the past - so I suggest updating it "just-in-case".
In the event that all of the above doesn't stop the BSOD's - please run Driver Verifier according to these instructions: Link Removed
Analysis:
[FONT=lucida console]**************************Tue Sep 18 19:51:53.985 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091812-33509-01.dmp]
Windows 7 Kernel Version [B]7601 [/B](Service Pack 1) MP (8 procs) Free x64
Built by: [B]7601[/B].17835.amd64fre.win7sp1_gdr.120503-2030
System Uptime:[B]0 days 21:07:55.000[/B]
BugCheck Code: [B]BugCheck D1, {fffff88044f973a4, 2, 8, fffff88044f973a4}[/B]
Probably caused by :[B]usbhub.sys ( usbhub!UsbhDmTimer+16f )[/B]
BugCheck Info: [B]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/B]
BUGCHECK_STR:  0xD1
PROCESS_NAME: [B]chrome.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xD1_CODE_AV_BAD_IP_usbhub!UsbhDmTimer+16f[/B]
CPUID:        "Intel(R) Core(TM) i7 CPU         940  @ 2.93GHz"
MaxSpeed:     2930
CurrentSpeed: [B]2937[/B]
  BIOS Version                  1802
  BIOS Release Date             01/28/2010
**************************Sat Sep 15 17:42:25.007 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091512-29889-01.dmp]
System Uptime:[B]0 days 4:23:46.037[/B]
BugCheck Code: [B]BugCheck D1, {fffff8004369107a, 2, 8, fffff8004369107a}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiPageFault+260 )[/B]
BUGCHECK_STR:  0xD1
PROCESS_NAME: [B]MOM.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xD1_CODE_AV_BAD_IP_nt!KiPageFault+260[/B]
MaxSpeed:     2930
  BIOS Version                  1802
[/FONT]
3rd Party Drivers:
[B]lmimirr.sys                   Tue Apr 10 18:32:45 2007 (461C108D)[/B]
[B]Lachesis.sys                  Fri Aug 17 03:48:44 2007 (46C552DC)[/B]
[B]RaInfo.sys                    Fri Jan  4 13:57:14 2008 (477E818A)[/B]
[B]LMIRfsDriver.sys              Mon Jul 14 12:26:56 2008 (487B7E50)[/B]
GEARAspiWDM.sys               Mon May 18 08:17:04 2009 (4A1151C0)
[B]cmudaxp.sys                   Tue Jun  9 07:32:36 2009 (4A2E4854)[/B]
intelppm.sys                  Mon Jul 13 19:19:25 2009 (4A5BC0FD)
ASACPI.sys                    Wed Jul 15 23:31:29 2009 (4A5E9F11)
amdxata.sys                   Fri Mar 19 12:18:18 2010 (4BA3A3CA)
jraid.sys                     Thu May 19 03:55:18 2011 (4DD4CCE6)
SCDEmu.SYS                    Wed Jun 15 04:29:27 2011 (4DF86D67)
VMNET.SYS                     Fri Jul  8 03:43:55 2011 (4E16B53B)
vmnetadapter.sys              Fri Jul  8 03:43:56 2011 (4E16B53C)
vmnetbridge.sys               Fri Jul  8 03:44:44 2011 (4E16B56C)
vmci.sys                      Tue Jul 26 22:42:09 2011 (4E2F7B01)
hcmon.sys                     Tue Aug 30 02:05:35 2011 (4E5C7DAF)
yk62x64.sys                   Thu Sep  8 03:34:54 2011 (4E68701E)
RtHDMIVX.sys                  Fri Dec  2 05:32:46 2011 (4ED8A94E)
vmnetuserif.sys               Wed Jan 18 16:36:25 2012 (4F173B59)
vmx86.sys                     Wed Jan 18 18:33:10 2012 (4F1756B6)
MpFilter.sys                  Fri Mar  9 06:05:26 2012 (4F59E3F6)
mbam.sys                      Tue Mar 20 12:04:48 2012 (4F68AAA0)
atikmpag.sys                  Thu Apr  5 21:10:44 2012 (4F7E4294)
atikmdag.sys                  Thu Apr  5 21:48:25 2012 (4F7E4B69)
[/FONT]
Link Removed - Invalid URL
I updated all my drivers and my windows updates seem to be up to date.
I have around 20% free space on my E: drive now.
Power Supply - Make: Coolmax Model: RM-1000B Wattage: 1000W
Thank you for all your help. I will let you know if I blue screen again.
Thanks again,
Lee
I seem to blue screen when I run a game I play, DayZ and Diablo III at the same time. Although, it has happened with just multiple Diablo III clients running. I have also had blue screens caused by the ntoskrnl.exe driver as well. All my info is attached below:
Thanks in advance,
Lee
P.S. Thank you usasma for helping me previously.
EDIT: I just got another BSOD - PAGE_FAULT_IN_NONPAGED_AREA - atikmdag.sys - Here is the new minidump file: Link Removed due to 404 Error
PSU is probably OK (I'm not familiar with the brand - but 1000watts is probably well above what you need.
Good luck!
I'm going to ask the moderators to merge this topic with your old one - so we can keep all the info in the same place.
Sounds good, thank you.
EDIT: As far as the problem(s), any suggestions? :)
Un-install LogMeIn.
ramirr.sys Tue Apr 10 18:32:50 2007 (461C1092)
ramirr.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. LogMeIn RemotelyAnywhere Mirror Miniport Driver
UsbFltr.sys Wed Apr 11 04:23:46 2007 (461C9B12)
Ortek USB Keypad Driver by Waytech Development (may be a part of Razer Tarantula drivers also)
RARfsDriver.sys Mon Jul 14 12:26:51 2008 (487B7E4B)
RemotelyAnywhere Rfs Drivemap Driver
RARfsDriver.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed. LogMeIn RemotelyAnywhere Rfs Drivemap Driver
Analysis:
[FONT=lucida console]**************************Fri Sep 21 11:20:48.130 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092112-32058-01.dmp]
System Uptime:[B]0 days 10:56:26.145[/B]
BugCheck Code: [B]BugCheck 50, {fffff8a04d7a67b0, 1, fffff88005601ebd, 5}[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1+1ebd )[/B]
BugCheck Info: [B]PAGE_FAULT_IN_NONPAGED_AREA (50)[/B]
BUGCHECK_STR:  0x50
PROCESS_NAME: [B]Diablo III.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0x50_dxgmms1+1ebd[/B]
MaxSpeed:     2930
  BIOS Version                  1802
**************************Fri Sep 21 00:22:31.243 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092012-37674-01.dmp]
System Uptime:[B]1 days 1:42:30.147[/B]
BugCheck Code: [B]BugCheck D1, {fffffa80d3ca9d30, 2, 1, fffff880014bc042}[/B]
*** WARNING: Unable to verify timestamp for ndis.sys
*** ERROR: Module load completed but symbols could not be loaded for ndis.sys
Probably caused by :[B]ndis.sys ( ndis+33042 )[/B]
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_ndis+33042[/B]
MaxSpeed:     2930
  BIOS Version                  1802
**************************Wed Sep 19 09:48:52.031 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\091912-33977-01.dmp]
System Uptime:[B]0 days 8:29:18.046[/B]
BugCheck Code: [B]BugCheck A, {fffff80043a57430, 2, 1, fffff800038e5933}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiDeferredReadyThread+433 )[/B]
BugCheck Info: [B]IRQL_NOT_LESS_OR_EQUAL (a)[/B]
BUGCHECK_STR:  0xA
PROCESS_NAME: [B]sidebar.exe[/B]
FAILURE_BUCKET_ID: [B]X64_0xA_nt!KiDeferredReadyThread+433[/B]
MaxSpeed:     2930
  BIOS Version                  1802
[/FONT]
3rd Party Drivers:
[B]ramirr.sys                    Tue Apr 10 18:32:50 2007 (461C1092) - [/B][/FONT]LogMeIn RemotelyAnywhere Mirror Miniport Driver[FONT=lucida console]
[B]UsbFltr.sys                   Wed Apr 11 04:23:46 2007 (461C9B12)[/B]
[B]RARfsDriver.sys               Mon Jul 14 12:26:51 2008 (487B7E4B) - [/B][/FONT]LogMeIn RemotelyAnywhere Rfs Drivemap Driver[FONT=lucida console]
Lachesis.sys                  Fri Oct 16 09:09:12 2009 (4AD87078)
MxEFUF64.sys                  Thu Oct 20 12:24:05 2011 (4EA04B25)
jraid.sys                     Fri Mar 30 07:22:43 2012 (4F759783)
RtHDMIVX.sys                  Tue Jun  5 01:45:14 2012 (4FCD9CEA)
atikmpag.sys                  Tue Sep  4 21:07:18 2012 (5046A5C6)
atikmdag.sys                  Tue Sep  4 22:10:27 2012 (5046B493)
[/FONT]
Should I be uninstalling just LogMeIn or both LogMeIn and LogMeIn Ignition?
EDIT: Also, I'm not using the Asus Xonar DG drivers anymore I don't think. I have another audio card that I use. Should I just uninstall them?
Un-install all LogMeIn stuff
Un-install all Asus Xonar DG stuff
Okay I have uninstalled/updated the drivers. However, I am a little confused here. It says cmudaxp.sys is the HTO CLARO Audio Interf, which is my new audio card (not the one provided with my motherboard(which is an asus rampage II extreme)). However, you're saying that cmudaxp.sys is for the Asus Xonar DG stuff? I guess I just need some clarification on what exactly I need to keep/get rid of pertaining to my audio card drivers.
Thanks again,
Lee
EDIT: Got another bsod - here is the dump file: Link Removed due to 404 Error
The descriptions of the driver that I use are based on the reports at Link Removed (my website).
We get them from submissions by different members - and either myself or jcgriff2 approve them before they're posted to the site.
In this case, a search for your video card reveals that your card (and presumably the Asus Xonar DG card) both use C-Media audio drivers - so I've updated the link to reflect all 3 driver sources. Link Removed
I suggest using the most current drivers from the place that made the chipset for the card - but this depends on the functionality that the drivers offer to you. If the C-Media drivers don't have enough functions, then use the most updated Claro drivers. I prefer the C-Media drivers simply because they come from the people who designed the chipset for the card - and have no clue about the finer points of audio performance.
Finally, regardless of which card it came from - it dates from before SP1 came out. As such, it's suspect merely because of it's age.
I would suggest:
- download a fresh set of the C-Media drivers
- un-install all sound card software and drivers
- reboot
- verify that cmudaxp.sys is not present in C:\Windows\system32\drivers\ (DO NOT delete it - post back if it is and we'll describe a method to safely remove it)
- if it's not present, then install the freshly downloadedC-Media drivers and test for further BSOD's
Now on to the memory dump analysis....
Updated the link for Ortek keyboard drivers (UsbFltr.sys): Link Removed - Invalid URL
Have you updated the Razer Lachesis drivers to the latest available Win7 version (the dating scheme in their drivers isn't easily deciphered). Have you also updated the firmware for this device? If you've done both, please un-install the software for the device and remove the device from your system (temporarily). Use another mouse temporarily to see if that doesn't stop the BSOD's. If it doesn't, then feel free to reinstall the latest drivers for the device after we've stopped the BSOD's.
Here's the list of the older drivers that I'm concerned about. Also, the BSOD errors that you've reported are generally associated with a driver problem.
So please update/remove the programs for these drivers from your system and see if you get further BSOD's:
C-Media Audio Interface Driver (WDM) by C-Media [br] ASUS Xonar DG Audio Interface driver [br] HTO CLARO Audio Interface Driver
TuneUpUtilitiesDrv
Microsoft LifeCam
You may also want to try running Driver Verifier to see if that will help in pointing out the offending driver. To do that, please follow the instructions here: Link Removed
Analysis:
[FONT=lucida console]**************************Sat Sep 22 01:05:45.708 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092212-34554-01.dmp]
System Uptime:[B]0 days 3:13:32.723[/B]
BugCheck Code: [B]BugCheck 50, {fffff8a04363a6d0, 0, fffff80003ba12b0, 5}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!ObDereferenceSecurityDescriptor+20 )[/B]
BUGCHECK_STR:  0x50
PROCESS_NAME: [B]SearchIndexer.[/B]
FAILURE_BUCKET_ID: [B]X64_0x50_nt!ObDereferenceSecurityDescriptor+20[/B]
MaxSpeed:     2930
  BIOS Version                  1802
[/FONT]
3rd Party Drivers:
[/FONT]
When trying to reinstall the c-media driver(s), at the end of the setup it says please insert hto claro audio device (as if it doesn't recognize that it's plugged in). Similar conflict with the UsbFltr.sys. When I try to update it, it says please plug in (some type of) controller. I don't remember exactly. If you could inform me on how to remove the UsbFltr driver, along with the audio card update, I think my computer is pretty close to being bsod-free. :)
Thanks again,
Lee
EDIT: I was also reading up somewhere that a BIOS update might fix the problem if none of these driver fixes fix it. Thoughts?
EDIT(2): I restarted my computer a second time, and it allowed me to install the c-media driver. I still cannot update or install the UsbFltr.sys driver, and I think I should uninstall, but I'm unsure how to.
EDIT(3): Another BSOD - Here is an update - Link Removed due to 404 Error
EDIT(4): New BSOD - caused by usbuhci.sys - dump file - Link Removed due to 404 Error
EDIT(5): I have updated my BIOS to the newest version. This could have been the problem. I have also removed one stick of RAM, putting me down at 20GB. Removing this stick in the past seemed to have fixed my problem. Therefore, if I don't blue screen for 48 hours, I will put the RAM stick back in and deduce my problems from there if I have any.
To safely remove UsbFltr.sys
1. Create a System Repair Disc. Go to Start...All Programs...Maintenance...Create a System Repair Disc
2. Create a System Restore Point
3. Download and install Autoruns (free from here: Autoruns for Windows ). Search within Autoruns for anything that uses UsbFltr.sys. Disable them by removing the checkmark from the far left column.
4. Check in services.msc for any UsbFltr.sys services. Disable any that you may find.
5. Check Device Manager (to include the View...Show hidden devices menu) and see if there are any UsbFltr.sys entries. If so, disable them (later on you can un-install them).
6. Rename UsbFltr.sys to UsbFltr.BAD (should be located in C:\Windows\System32\drivers folder)
7. Reboot
If the system won't boot, use the System Repair Disc (Command Prompt option) to re-rename UsbFltr.BAD to UsbFltr.sys
Then use the System Repair Disc (System Restore option) to restore the system to the state it was in prior to attempting to remove the driver.
Good luck!
Same advice as before - update or remove the programs associated with the older drivers.
Analysis:
[font=lucida console]**************************Sat Sep 22 15:25:59.067 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092212-31293-01.dmp]
System Uptime:[B]0 days 1:21:07.971[/B]
BugCheck Code: [B]BugCheck D1, {fffff8804355b000, 9, 0, fffff880053f25fb}[/B]
*** ERROR: Module load completed but symbols could not be loaded for usbuhci.sys
Probably caused by :[B]usbuhci.sys ( usbuhci+65fb )[/B]
BUGCHECK_STR:  0xD1
FAILURE_BUCKET_ID: [B]X64_0xD1_usbuhci+65fb[/B]
MaxSpeed:     2930
  BIOS Version                  1802
**************************Sat Sep 22 13:07:00.596 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092212-31933-01.dmp]
System Uptime:[B]0 days 0:48:30.611[/B]
BugCheck Code: [B]BugCheck 50, {fffff8a04cebad38, 1, fffff8800441b507, 5}[/B]
Probably caused by :[B]dxgmms1.sys ( dxgmms1!VidMmInterface+9c47 )[/B]
BUGCHECK_STR:  0x50
FAILURE_BUCKET_ID: [B]X64_0x50_dxgmms1!VidMmInterface+9c47[/B]
MaxSpeed:     2930
  BIOS Version                  1802
**************************Sat Sep 22 12:09:52.280 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092212-32588-01.dmp]
System Uptime:[B]0 days 1:04:53.184[/B]
BugCheck Code: [B]BugCheck 1000009F, {4, 258, fffffa8012e3db50, fffff80000ba2740}[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!KiSwapContext+7a )[/B]
BugCheck Info: [B]DRIVER_POWER_STATE_FAILURE (9f)[/B]
BUGCHECK_STR:  0x9F
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]X64_0x9F_4_nt!KiSwapContext+7a[/B]
MaxSpeed:     2930
  BIOS Version                  1802
**************************Sat Sep 22 03:02:36.873 2012 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\092212-48953-01.dmp]
System Uptime:[B]0 days 1:55:06.888[/B]
BugCheck Code: [B]BugCheck 50, {fffff8a043e86b60, 0, fffff80003ba12b0, 5}[/B]
*** WARNING: Unable to verify checksum for win32k.sys
BUGCHECK_STR:  0x50
MaxSpeed:     2930
  BIOS Version                  1802
[/font]
3rd Party Drivers:
cmudaxp.sys                   Thu Oct 28 04:27:22 2010 (4CC933EA)
usbaapl64.sys                 Tue Jan 10 19:56:04 2012 (4F0CDE24)
[/font]
Either the BIOS update or the removal of one 4GB stick of RAM has fixed the problem. If I don't blue screen by tomorrow morning, I'll put the RAM stick back in and confirm the results.
Thanks again for all your help,
Lee
