Windows 7 DTS Connect / interactive not working
Julianbl
DTS Connect / interactive not working <Solved in 7068>
Hi all!
I've just realized that DTS Interactive is no longer working after upgrading to 7.
I'm using a SoundMAX driver version 6.1.10.6260 and the sound card is onboard in the Asus Striker Extreme.
That driver is the latest one and reinstalling didn't do anything.
The symptoms are:
Only PCM audio out.
No audio when DTS Interactive is enabled. Not only no audio but, for example, wmp gives an error when trying to play a file.
Any comment or idea on how to make dts work would be really appreciated.
Regards,
Julián
up!
Just upgraded to 7048 and still can't get DTS interactive to wirk :S
Julián
DTS Interactive works on 7068
After the upgrade to 7068, DTS Interactive WORKS!!!! :D:D
Hey Julianbl,
Thanks for the info.
That's the one reason I uninstalled Windows 7 on my Home Theate PC.
