ohiostar1803
- Joined
- Jul 29, 2013
- Messages
- 2
- Thread Author
- #1
We are trying to transfer files from an older computer running Windows XP Pro, 32 bit, to a new one using Windows 7 Pro, 64 bit. We are using Easy Transfer and an Inland Datalink USB cable, which was recommended by the computer store. We installed onto the XP computer what we believe is the correct Easy Transfer software. We run Easy Transfer and all is well until we get to where we plug in the cable. Neither computer detects it.
However - while there was no specific driver or software included with the cable, when plugged in, both computers show something in the appropriate drive letter in My Computer called Easy Suit CN, which we think may be software preinstalled in the cable. Clicking on that icon, on both computers, brings up a split screen that correctly shows the all files on both the Host and Remote computers. However, this software, from what we've seen, has no transfer capabilities. And of course the cable has no instructions. We are stumped.
It appears from this EasySuiteCN that the cable is functioning, just that Easy Transfer isn't. Can anyone help? Thank you, and I apologize for any mistakes in posting, it's my first post.
