Windows 7 Exception code 0xc0000005 when shutting down 64bit application
ReReOs
Hi!
Since recently, quitting the Cubase 6 64bit result in application crash with Exception code 0xc0000005 in the event log:
Felet uppstod i programmet med namn: Cubase6.exe, version 6.0.7.364, tidsstämpel 0x4f5f87dc
, felet uppstod i modulen med namn: Cubase6.exe, version 6.0.7.364, tidsstämpel 0x4f5f87dc
Undantagskod: 0xc0000005
Felförskjutning: 0x0000000000fe3352
Process-ID: 0xfc8
Programmets starttid: 0x01d356097b404a02
Sökväg till program: C:\Program Files\Steinberg\Cubase 6\Cubase6.exe
Sökväg till modul: C:\Program Files\Steinberg\Cubase 6\Cubase6.exe
Rapport-ID: dcfdc707-c1fc-11e7-bd0e-001fd0dbecc6
System
- Provider
[ Name] Application Error
- EventID 1000
[ Qualifiers] 0
Level 2
Task 100
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2017-11-05T07:42:25.000000000Z
EventRecordID 1072390
Channel Application
Computer RMS
Security
- EventData
Cubase6.exe
6.0.7.364
4f5f87dc
Cubase6.exe
6.0.7.364
4f5f87dc
c0000005
0000000000fe3352
fc8
01d356097b404a02
It used to work for years without a problem.
On the other hand, the Cubase 6 32bit doesn’t have this problem.
Furthermore, if set the Cubase 6 64bit to ‘Windows 7’ compatibility mode, then the application is shutting down properly. But some functions are very slow then.
I’ve also re-installed Cubase 6 64bit from the original installer and updated it to the last version, but the problem is still present.
Using "Run As Administrator” doesn’t make the problem go away.
I’ve tried to disable the Hyperthreading, but it doesn’t have any impact on the problem.
I read somewhere that a possible cause is the that some bad driver has corrupted the system driver pool?
I’ve submitted the full Event Viewer administrative logs through the following link:
System specifications:
Win7 Pro 64bit SP1
6GB RAM
NVIDIA GEFORCE GT 710
Gigabyte EX58-UD4
I would appreciate if someone could help me to trace down and solve the problem.
Thanks in advance!
Error 0x0005 is access denied. So it's failing trying to access some resource. If it's a file or registry resource you maybe able to see the failure running procmon and if it is failing on a file or registry you can grant your user access to said resource. The other option is to create a memory dump on the error and we can look at that. It's likely a Windows patch may have changed something and the program can't handle the exception gracefully.
They're always mscvr##.dll
No such file in the game according to procexp though.
