Jose Luis9400
Active Member
I have just installed FCIV on System32, but when searched it is not found:
An image from 'FCIV not found after installacion on System32'. Windows Explorer shows no search results for 'fciv.exe' in the System32 folder.
I can see it from "cygwin":
$ ls -l 'C:\Windows\System32\fciv.exe'
-rwxr-xr-x 1 jlfdiaz Domain Users 84784 may 13 2004 'C:\Windows\System32\fciv.exe'
But not from Command:
C:\Users\jlfdiaz>dir C:\Windows\System32\fciv.exe
El volumen de la unidad C es OSDisk
El número de serie del volumen es: 0AD5-2E68
Directorio de C:\Windows\System32
No se encuentra el archivo
Any idea of why I can see the file from W7?
Thanks in advance.
Regards,
Jose Luis.
Neemobeer
Windows Forum Team
I would check and see if the System and/or Hidden attribute are set. It won't show up in file explorer or command prompt.
