Windows 7 First BSOD on Custom PC. Stumped, Help Please.
C0BRA
Well-Known Member
Hi forums,
Today, I had my very first BSOD encounter with my custom rig that I built back around mid September last year. According to the dump file, it was a DRIVER_POWER_STATE_FAILURE error and it was tied to ntoskrnl.exe. I ran memtest and it found no errors through 2 passes. I used the Driver Verifier built in to Windows and my computer would BSOD right after the "Starting Windows" screen. I've disabled it, but I'm typing this in safe mode right now. I've already taken the liberty of uploading the BSOD .dmp file to OneDrive, which will be posted below. I'm stumped and not sure what to do, but I don't think it's bad memory. I'm fairly certain it's a driver, I'm just not sure which one. Any help would be greatly appreciated.
BSOD dump file: 020216-12604-01.dmp
I guess I should mention that I'm running Windows 7 Ultimate 64-bit (but I guess that might be mostly obvious since I'm under the Windows 7 BSOD forums).
BugCheck 9F, {3, fffffa80085fa060, fffff80000b9a3d8, fffffa8008972c60}
*** WARNING: Unable to verify timestamp for AppleODD.sys
*** ERROR: Module load completed but symbols could not be loaded for AppleODD.sys
Probably caused by : AppleODD.sys
Followup: MachineOwner
as you...
C0BRA
Well-Known Member
Hope all goes well.. Post any new dump files.
Hey, thanks. So I updated it to the most recent version I could find, though in Add or Remove Programs, it still has the same date and version as the previous driver... I think my USB 3s' are just borked. But anyway, I'll be back if anything else happens. Thanks!
Neemobeer
Windows Forum Team
A more accurate way to determine which drivers you have, versions and dates is to open a command prompt and type pnputil -e this will give you big list of drivers and in some cases you may have multiple driver versions installed. You can verify which one is in use from device manager > device > properties > Driver tab
C0BRA
Well-Known Member
Hey, thanks for telling me. I'll be sure to take a look at that.
